# nvme list
Node Generic SN Model Namespace Usage Format FW Rev
/dev/nvme2n1 /dev/ng2n1 S4EVNF0M84XXXXX Samsung SSD 970 EVO Plus 500GB 1 391,41 GB / 500,11 GB 512 B + 0 B 2B2QEXM7
/dev/nvme1n1 /dev/ng1n1 50026B72826XXXXX KINGSTON SA2000M81000G 1 405,31 GB / 1,00 TB 512 B + 0 B S5Z42109
/dev/nvme0n1 /dev/ng0n1 S4EWNG0M20XXXXX Samsung SSD 970 EVO Plus 1TB 1 656,47 GB / 1,00 TB 512 B + 0 B 2B2QEXM7
There is a new firmware 4B2QEXM7 available. Samsung even provides an ISO file to boot this from USB:
Unfortunately this is not working. It only works with a PS/2 keyboard which I do not have. So I was following these instructions here to boot with my normal EndeavourOS USB stick and start the firmware upgrade from there:
But this is not working either. It says it does not find any Samsung drive to update.
Does anybody have an idea what to do here?
I am afraid I have to go back to Windows and try that. But how? I need to boot into Windows with an external drive and run the Windows version of the Samsung software. How to I get this “Windows on an external drive”?
Interesting, I have a 970 evo plus too. When at Home I will try on my system to upgrade my SSD.
But as I understand it, the ISO will not work because of the Keyboard Problem, so ok.
Unter the second link the procedure is explained that you can “unzip” the ISO and install the Firmware from Linux. But the drives need to be unmounted.
Have I understood it correctly that you did try it from the endeavourOS Live System?
Final Question, is there something special with the new firmware, so that it needs an upgrade?
It there is a good reason, I would go over my shadow and boot to windows (because of HomeOffice and some games I still keep a Windows installation) to make the upgrade, when I can’t find a proper working solution.
I tried also with Ubuntu live system because that was the system where I could find the most success stories. But it did not work for me.
Samsung does not provide a change.log. But I hope it will fix for example that the error_log of the drives is filling up with every boot for no good reason. Fixing messages like this in the journal: “missing or invalid SUBNQN field.”
I used popsicle to write the iso to usb and that worked for the boot process.
But unfortunately this Samsung iso needs a PS/2 keyboard to go any further. And this is what I do not have.
I’ve got the same disk in my laptop.
I just tried fwupdmgr and it correctly recognized the disk, the current firmware and that it was updatable.
However, after refreshing its database and trying to get the updates, it says updates no available for the device.
You might want to give it a try and see if you get different result?
fwupdmgr get-device
─SSD 970 EVO Plus 1TB:
│ Summary: NVM Express solid state drive
│ Current version: 3B2QEXM7
│ Vendor: Samsung
│ • Updatable
│ • System requires external power source
│ • Needs a reboot after installation
│ • Device is usable for the duration of the update
│ • Signed Payload
fwupdmgr get-updates
Devices with no available firmware updates:
• SSD 970 EVO Plus 1TB
EndeavourOS➜ ~ ᐅ fwupdmgr get-updates
• 0000:00:1f.5
• SSD 970 EVO Plus 500GB
• System Firmware
• Unifying Receiver
Devices with the latest available firmware version:
• UEFI dbx
________________________________________________
I would interpret the fact that fwupdmgr recognizes the disk and classify it as updatable as it is a supported device and it should be able to get the updates for it.
If that is correct, I don’t understand why it is failing given there is apparently an update for this disk.
anyone check to see if the exe for it is dos compatible? I use dos for most of my firmware updates but most of my stuff has DOS compatible EXEs for that
I tried this from a Live EnOS’ ISO. It seems that it might have worked if I were to answer yes in the last step. I didn’t since I hadn’t backed up my data and took the warning seriously.
