sudo systemctl status smb.service
● smb.service - Samba SMB Daemon
Loaded: loaded (/usr/lib/systemd/system/smb.service; disabled; vendor preset: disabled)
Active: active (running) since Wed 2022-01-12 13:34:46 EET; 21s ago
Docs: man:smbd(8)
man:samba(7)
man:smb.conf(5)
Main PID: 8996 (smbd)
Status: "smbd: ready to serve connections..."
Tasks: 4 (limit: 7085)
Memory: 28.1M
CPU: 270ms
CGroup: /system.slice/smb.service
├─8996 /usr/bin/smbd --foreground --no-process-group
├─9002 /usr/bin/smbd --foreground --no-process-group
├─9003 /usr/bin/smbd --foreground --no-process-group
└─9004 /usr/lib/samba/samba/samba-bgqd --ready-signal-fd=47 --parent-watch-fd=13 --debuglevel=0 -F
12 13:34:44 ende systemd[1]: Starting Samba SMB Daemon...
12 13:34:46 ende smbd[8996]: [2022/01/12 13:34:46.109334, 0] ../../source3/smbd/server.c:1739(main)
12 13:34:46 ende smbd[8996]: smbd version 4.15.3 started.
12 13:34:46 ende smbd[8996]: Copyright Andrew Tridgell and the Samba Team 1992-2021
12 13:34:46 ende smbd[8996]: [2022/01/12 13:34:46.260853, 0] ../../lib/param/loadparm.c:747(lpcfg_map_parameter)
12 13:34:46 ende smbd[8996]: Unknown parameter encountered: "auth methods"
12 13:34:46 ende smbd[8996]: [2022/01/12 13:34:46.260963, 0] ../../lib/param/loadparm.c:1751(lpcfg_do_global_parameter)
12 13:34:46 ende smbd[8996]: Ignoring unknown parameter "auth methods"
12 13:34:46 ende systemd[1]: Started Samba SMB Daemon.
12 13:34:
Yesterday, immediately after setting up the samba, it worked and today, after rebooting the system, it does not view computers on the network
smb.conf
[global]
security = user
workgroup = WORKGROUP
server string = Samba
guest account = ende
map to guest = Bad User
auth methods = guest, sam_ignoredomain
create mask = 0664
directory mask = 0775
hide dot files = yes
[shared]
comment = Public Folder
path = /home/ende/public
browseable = Yes
guest ok = Yes
public = yes
writeable = Yes
read only = no
guest ok = yes
create mask = 0666
