Ryzen CPU - Crashes/Reboots while Idle
Hello,
I’ve been experiencing issues with frequent freezing/rebooting whenever my laptop goes idle. I’ve had little luck with setting different kernel parameters, but I believe my problem is identical to the one described on the Arch Wiki here.
Unfortunately, my BIOS doesn’t provide any AMD-related settings, so I can’t use the AMD Curve Optimizer as described in the Wiki. My understanding is that the suggested “positive offset of 4 points” means adding +12 to +20 mV to the CPU voltage supply for all P-states, at all frequencies. I believe that either amdctl or zenstates can do this via command line, but I’m not sure how to choose the correct VID values or if only changing the VID values is sufficient for this problem.
Does anyone have past experience with this? Any guidance would be greatly appreciated!
For reference, my current output from zenstates -l is below (Ryzen 7 5700U, CPU model 68h, from family 17h with 16 CPU cores):
P0 - Enabled - FID = 5A - DID = A - VID = 35 - Ratio = 18.00 - vCore = 1.21875
P1 - Enabled - FID = 66 - DID = C - VID = 60 - Ratio = 17.00 - vCore = 0.95000
P2 - Enabled - FID = 62 - DID = E - VID = 66 - Ratio = 14.00 - vCore = 0.91250
P3 - Disabled
P4 - Disabled
P5 - Disabled
P6 - Disabled
P7 - Disabled
C6 State - Package - Enabled
C6 State - Core - Enabled
can you provide
inxi -Fza
you should add theses parameters on boot kernel
in /etc/default/grub
line GRUB_CMDLINE_LINUX_DEFAULT=
“amd_iommu=on iommu=pt nowatchdog processor.max_cstate=5 rcu_nocbs=0_15 systemd.unified_cgroup_hierarchy=true scsi_mod.use_blk_mq=1”
before changing any settings, have you tried another kernel if it also shows that behaviour?
If you run the regular kernel, try the linux-lts kernel, if you already run that one, try the mainline linux kernel.
Thank you both for the prompt replies!
@Stephane here is the inxi output:
  Kernel: 5.17.1-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
    parameters: BOOT_IMAGE=/boot/vmlinuz-linux
    root=UUID=c9611b7f-f85f-415a-9920-cf8e3b495dde rw quiet loglevel=3
    nowatchdog nvme_load=YES idle=nomwait processor.max_cstate=4
    amdgpu.ppfeaturemask=0xffffffff amd_iommu=on iommu=pt amdgpu.noretry=0
    amdgpu.lockup_timeout=1000 amdgpu.gpu_recovery=1 amdgpu.audio=0
    rcu_nocbs=0-16 systemd.unified_cgroup_hierarchy=1 scsi_mod.use_blk_mq=1
    nvme_core.default_ps_max_latency_us=0 pcie_aspm=off
    sysrq_always_enabled=1
  Console: pty pts/0 wm: gnome-shell DM: GDM v: 42.0 Distro: EndeavourOS
    base: Arch Linux
  Type: Convertible System: HP product: HP ENVY x360 Convertible 15-ee1xxx
    v: Type1ProductConfigId serial: <filter> Chassis: type: 31 serial: <filter>
  Mobo: HP model: 88C2 v: 67.31 serial: <filter> UEFI: Insyde v: F.06
    date: 03/02/2022
Battery:
  ID-1: BAT1 charge: 40.7 Wh (87.7%) condition: 46.4/51.0 Wh (90.9%)
    volts: 12.4 min: 11.6 model: Hewlett-Packard PABAS0241231 type: Li-ion
    serial: <filter> status: discharging
  Device-1: hid-0018:04F3:2B08.0001-battery model: ELAN2514:00 04F3:2B08
    serial: N/A charge: N/A status: N/A
  Info: model: AMD Ryzen 7 5700U with Radeon Graphics socket: FP6 bits: 64
    type: MT MCP arch: Zen 2 family: 0x17 (23) model-id: 0x68 (104) stepping: 1
    microcode: 0x8608103
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
    L3: 8 MiB desc: 2x4 MiB
  Speed (MHz): avg: 1500 high: 1800 min/max: 1400/4370 boost: enabled
    base/boost: 1800/4350 scaling: driver: acpi-cpufreq governor: schedutil
    volts: 1.2 V ext-clock: 100 MHz cores: 1: 1400 2: 1800 3: 1800 4: 1400
    5: 1400 6: 1400 7: 1400 8: 1400 9: 1400 10: 1800 11: 1800 12: 1400
    13: 1400 14: 1400 15: 1400 16: 1400 bogomips: 57518
  Vulnerabilities:
  Type: spec_store_bypass
    mitigation: Speculative Store Bypass disabled via prctl
  Type: spectre_v1
    STIBP: conditional, RSB filling
  Device-1: AMD Lucienne vendor: Hewlett-Packard driver: amdgpu v: kernel
    pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
    active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 04:00.0 chip-ID: 1002:164c
    class-ID: 0300
  Device-2: Chicony HP Wide Vision HD Camera type: USB driver: uvcvideo
    bus-ID: 1-4:3 chip-ID: 04f2:b6b6 class-ID: 0e02 serial: <filter>
  Display: server: X.Org v: 22.1.1 with: Xwayland v: 22.1.1
    compositor: gnome-shell driver: gpu: amdgpu note:  X driver n/a
    display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.00x11.26")
    s-diag: 583mm (22.95")
  Monitor-1: eDP-1 mapped: XWAYLAND0 model: LG Display 0x064c built: 2019
    res: 1920x1080 hz: 60 dpi: 143 gamma: 1.2 size: 340x190mm (13.39x7.48")
    diag: 395mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
  OpenGL: renderer: AMD RENOIR (LLVM 13.0.1 DRM 3.44 5.17.1-arch1-1)
    v: 4.6 Mesa 22.0.1 direct render: Yes
  Device-1: AMD Renoir Radeon High Definition Audio vendor: Hewlett-Packard
    driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16
    link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637
    class-ID: 0403
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Hewlett-Packard
    driver: snd_rn_pci_acp3x v: kernel
    alternate: snd_pci_acp3x,snd_pci_acp5x,snd_pci_acp6x,snd_sof_amd_renoir
    bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-3: AMD Family 17h/19h HD Audio vendor: Hewlett-Packard
    link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3
    class-ID: 0403
  Sound Server-1: ALSA v: k5.17.1-arch1-1 running: yes
  Sound Server-2: PulseAudio v: 15.0 running: no
  Sound Server-3: PipeWire v: 0.3.49 running: yes
  Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:2723 class-ID: 0280
Bluetooth:
  Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8
    bus-ID: 3-1:2 chip-ID: 8087:0029 class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 0 state: down bt-service: disabled
  Local Storage: total: 931.51 GiB used: 10.06 GiB (1.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung
    model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
    logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter>
    rev: 4B2QEXM7 temp: 29.9 C scheme: GPT
  SMART: yes health: PASSED on: 11 hrs cycles: 28
    read-units: 128,822 [65.9 GB] written-units: 227,569 [116 GB]
  ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
    used: 10.06 GiB (1.1%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2
    maj-min: 259:2
  ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%)
    used: 296 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
    maj-min: 259:1
  Kernel: swappiness: 60 (default) cache-pressure: 100 (default)
  ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
    file: /swapfile
  System Temperatures: cpu: 40.0 C mobo: 20.0 C gpu: amdgpu temp: 34.0 C
  Fan Speeds (RPM): cpu: 0 fan-2: 0
  Processes: 350 Uptime: 3m wakeups: 363 Memory: 14.94 GiB
  used: 1.49 GiB (10.0%) Init: systemd v: 250 tool: systemctl Compilers:
  gcc: 11.2.0 Packages: pacman: 822 lib: 221 Shell: Bash (sudo) v: 5.1.16
  running-in: gnome-terminal inxi: 3.3.15
I’ve tried those adding those kernel parameters as well, but the problem still persists sadly.
@BS86 I’ve mainly been testing on 5.17.1-arch1-1, but I’ve tried using the LTS kernel 5.15.33-1.lts as well, which had the same behavior (reboots after being idle/locked/etc for a few minutes)
You have to find relevant messages in journal log for those cases, to help find the real source of the problem.
There are several workarounds for such cases, like using a service to stop/start compositor/shell etc.
Archwiki has many examples on this.
@petsam Thanks for the guidance. I admit I am an Arch noob; I’ve read the wiki pages that I’ve found so far that I thought were relevant, but I’m still just starting to find my way around the wiki. Do you have any wiki sections in mind you would recommend?
I have a journalctl log (truncated to fit in the post) from a crash (at the end, around 01:30), but I’m having a hard time determining which lines correspond to the root cause.
Apr 13 00:47:37 tom-hpenvy systemd[940]: Started Accessibility services bus.
Apr 13 00:47:37 tom-hpenvy gnome-shell[997]: Using public X11 display :0, (using :1 for managed services)
Apr 13 00:47:37 tom-hpenvy gnome-shell[997]: Using Wayland display name 'wayland-0'
Apr 13 00:47:37 tom-hpenvy gnome-shell[997]: Unset XDG_SESSION_ID, getCurrentSessionProxy() called outside a user session. Asking logind directly.
Apr 13 00:47:37 tom-hpenvy gnome-shell[997]: Will monitor session 3
Apr 13 00:47:37 tom-hpenvy dbus-daemon[956]: [session uid=1000 pid=956] Activating service name='org.gnome.Shell.CalendarServer' requested by ':1.11' (uid=1000 pid=997 comm="/usr/bin/gnome-shell")
Apr 13 00:47:37 tom-hpenvy org.gnome.Shell.CalendarServer[1061]: /usr/lib/gnome-shell-calendar-server: error while loading shared libraries: libecal-2.0.so.1: cannot open shared object file: No such file or directory
Apr 13 00:47:37 tom-hpenvy dbus-daemon[956]: [session uid=1000 pid=956] Activated service 'org.gnome.Shell.CalendarServer' failed: Process org.gnome.Shell.CalendarServer exited with status 127
Apr 13 00:47:37 tom-hpenvy systemd[940]: Started PipeWire Multimedia Service.
Apr 13 00:47:37 tom-hpenvy systemd[940]: Started PipeWire Media Session Manager.
Apr 13 00:47:37 tom-hpenvy systemd[940]: Started PipeWire PulseAudio.
Apr 13 00:47:37 tom-hpenvy pipewire-media-session[1063]: mod.rt: RTKit error: org.freedesktop.DBus.Error.ServiceUnknown
Apr 13 00:47:37 tom-hpenvy pipewire-media-session[1063]: mod.rt: could not make thread 1065 realtime using RTKit: No such file or directory
Apr 13 00:47:37 tom-hpenvy pipewire-pulse[1064]: mod.rt: RTKit error: org.freedesktop.DBus.Error.ServiceUnknown
Apr 13 00:47:37 tom-hpenvy pipewire-pulse[1064]: mod.rt: could not set nice-level to -11: No such file or directory
Apr 13 00:47:37 tom-hpenvy pipewire[1062]: mod.rt: RTKit error: org.freedesktop.DBus.Error.ServiceUnknown
Apr 13 00:47:37 tom-hpenvy pipewire[1062]: mod.rt: could not set nice-level to -11: No such file or directory
Apr 13 00:47:37 tom-hpenvy pipewire[1062]: mod.rt: could not make thread 1066 realtime using RTKit: No such file or directory
Apr 13 00:47:37 tom-hpenvy pipewire-pulse[1064]: mod.rt: could not make thread 1069 realtime using RTKit: No such file or directory
Apr 13 00:47:37 tom-hpenvy pipewire-pulse[1068]: 536870912
Apr 13 00:47:37 tom-hpenvy polkitd[471]: Registered Authentication Agent for unix-session:3 (system bus name :1.45 [/usr/bin/gnome-shell], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8)
Apr 13 00:47:37 tom-hpenvy gnome-shell[997]: Telepathy is not available, chat integration will be disabled.
Apr 13 00:47:37 tom-hpenvy dbus-daemon[956]: [session uid=1000 pid=956] Activating via systemd: service name='org.gtk.vfs.UDisks2VolumeMonitor' unit='gvfs-udisks2-volume-monitor.service' requested by ':1.11' (uid=1000 pid=997 comm="/usr/bin/gnome-shell")
Apr 13 00:47:37 tom-hpenvy systemd[940]: Starting Virtual filesystem service - disk device monitor...
Apr 13 00:47:37 tom-hpenvy dbus-daemon[461]: [system] Activating via systemd: service name='org.freedesktop.UDisks2' unit='udisks2.service' requested by ':1.49' (uid=1000 pid=1070 comm="/usr/lib/gvfs-udisks2-volume-monitor")
Apr 13 00:47:37 tom-hpenvy systemd[1]: Starting Disk Manager...
Apr 13 00:47:37 tom-hpenvy udisksd[1073]: udisks daemon version 2.9.4 starting
Apr 13 00:47:37 tom-hpenvy dbus-daemon[461]: [system] Successfully activated service 'org.freedesktop.UDisks2'
Apr 13 00:47:37 tom-hpenvy systemd[1]: Started Disk Manager.
Apr 13 00:47:37 tom-hpenvy audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 13 00:47:37 tom-hpenvy udisksd[1073]: Acquired the name org.freedesktop.UDisks2 on the system message bus
Apr 13 00:47:37 tom-hpenvy dbus-daemon[956]: [session uid=1000 pid=956] Successfully activated service 'org.gtk.vfs.UDisks2VolumeMonitor'
Apr 13 00:47:37 tom-hpenvy systemd[940]: Started Virtual filesystem service - disk device monitor.
Apr 13 00:47:37 tom-hpenvy dbus-daemon[956]: [session uid=1000 pid=956] Activating via systemd: service name='org.gtk.vfs.GPhoto2VolumeMonitor' unit='gvfs-gphoto2-volume-monitor.service' requested by ':1.11' (uid=1000 pid=997 comm="/usr/bin/gnome-shell")
Apr 13 00:47:37 tom-hpenvy systemd[940]: Starting Virtual filesystem service - digital camera monitor...
Apr 13 00:47:37 tom-hpenvy dbus-daemon[956]: [session uid=1000 pid=956] Successfully activated service 'org.gtk.vfs.GPhoto2VolumeMonitor'
Apr 13 00:47:37 tom-hpenvy systemd[940]: Started Virtual filesystem service - digital camera monitor.
Apr 13 00:47:37 tom-hpenvy dbus-daemon[956]: [session uid=1000 pid=956] Activating via systemd: service name='org.gtk.vfs.AfcVolumeMonitor' unit='gvfs-afc-volume-monitor.service' requested by ':1.11' (uid=1000 pid=997 comm="/usr/bin/gnome-shell")
Apr 13 00:47:37 tom-hpenvy systemd[940]: Starting Virtual filesystem service - Apple File Conduit monitor...
Apr 13 00:47:37 tom-hpenvy dbus-daemon[956]: [session uid=1000 pid=956] Successfully activated service 'org.gtk.vfs.AfcVolumeMonitor'
Apr 13 00:47:37 tom-hpenvy systemd[940]: Started Virtual filesystem service - Apple File Conduit monitor.
Apr 13 00:47:37 tom-hpenvy dbus-daemon[956]: [session uid=1000 pid=956] Activating via systemd: service name='org.gtk.vfs.MTPVolumeMonitor' unit='gvfs-mtp-volume-monitor.service' requested by ':1.11' (uid=1000 pid=997 comm="/usr/bin/gnome-shell")
Apr 13 00:47:37 tom-hpenvy systemd[940]: Starting Virtual filesystem service - Media Transfer Protocol monitor...
Apr 13 00:47:37 tom-hpenvy dbus-daemon[956]: [session uid=1000 pid=956] Successfully activated service 'org.gtk.vfs.MTPVolumeMonitor'
Apr 13 00:47:37 tom-hpenvy systemd[940]: Started Virtual filesystem service - Media Transfer Protocol monitor.
Apr 13 00:47:37 tom-hpenvy dbus-daemon[956]: [session uid=1000 pid=956] Activating service name='org.gnome.Shell.Notifications' requested by ':1.11' (uid=1000 pid=997 comm="/usr/bin/gnome-shell")
Apr 13 00:47:37 tom-hpenvy at-spi-bus-launcher[1050]: dbus-daemon[1050]: Activating service name='org.a11y.atspi.Registry' requested by ':1.0' (uid=1000 pid=997 comm="/usr/bin/gnome-shell")
Apr 13 00:47:37 tom-hpenvy at-spi-bus-launcher[1050]: dbus-daemon[1050]: Successfully activated service 'org.a11y.atspi.Registry'
Apr 13 00:47:37 tom-hpenvy gnome-shell[997]: Could not issue 'GetUnit' systemd call
Apr 13 00:47:37 tom-hpenvy at-spi-bus-launcher[1103]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
Apr 13 00:47:37 tom-hpenvy pipewire-media-session[1063]: ms.mod.alsa-monitor: can't make factory instance: No such file or directory
Apr 13 00:47:37 tom-hpenvy systemd[940]: Started GNOME Shell on Wayland.
Apr 13 00:47:37 tom-hpenvy systemd[940]: Reached target GNOME Session is initialized.
Apr 13 00:47:37 tom-hpenvy systemd[940]: GNOME session X11 services is inactive.
Apr 13 00:47:37 tom-hpenvy systemd[940]: Dependency failed for GNOME XSettings service.
Apr 13 00:47:37 tom-hpenvy systemd[940]: org.gnome.SettingsDaemon.XSettings.service: Job org.gnome.SettingsDaemon.XSettings.service/start failed with result 'dependency'.
Apr 13 00:47:37 tom-hpenvy systemd[940]: gnome-session-x11-services-ready.target: Job gnome-session-x11-services-ready.target/verify-active failed with result 'dependency'.
Apr 13 00:47:37 tom-hpenvy systemd[940]: Reached target GNOME Session (session: gnome).
Apr 13 00:47:37 tom-hpenvy systemd[940]: Reached target GNOME XSettings target.
Apr 13 00:47:37 tom-hpenvy systemd[940]: Starting Signal initialization done to GNOME Session Manager...
Apr 13 00:47:37 tom-hpenvy systemd[940]: Starting GNOME accessibility service...
Apr 13 00:47:37 tom-hpenvy gnome-shell[997]: Error loading calendars: Error calling StartServiceByName for org.gnome.Shell.CalendarServer: Process org.gnome.Shell.CalendarServer exited with status 127
Apr 13 00:47:37 tom-hpenvy systemd[940]: Starting GNOME color management service...
Apr 13 00:47:37 tom-hpenvy systemd[940]: Starting GNOME date & time service...
Apr 13 00:47:37 tom-hpenvy systemd[940]: Starting GNOME maintenance of expirable data service...
Apr 13 00:47:37 tom-hpenvy systemd[940]: Starting GNOME keyboard configuration service...
Apr 13 00:47:37 tom-hpenvy systemd[940]: Starting GNOME keyboard shortcuts service...
Apr 13 00:47:37 tom-hpenvy systemd[940]: Starting GNOME power management service...
Apr 13 00:47:37 tom-hpenvy systemd[940]: Starting GNOME printer notifications service...
Apr 13 00:47:37 tom-hpenvy systemd[940]: Starting GNOME RFKill support service...
Apr 13 00:47:37 tom-hpenvy systemd[940]: Starting GNOME FreeDesktop screensaver service...
Apr 13 00:47:37 tom-hpenvy systemd[940]: Starting GNOME file sharing service...
Apr 13 00:47:37 tom-hpenvy systemd[940]: Starting GNOME smartcard service...
Apr 13 00:47:37 tom-hpenvy gnome-shell[997]: Failed to launch ibus-daemon: Failed to execute child process “ibus-daemon” (No such file or directory)
Apr 13 00:47:37 tom-hpenvy systemd[940]: Starting GNOME sound sample caching service...
Apr 13 00:47:37 tom-hpenvy systemd[940]: Starting GNOME USB protection service...
Apr 13 00:47:37 tom-hpenvy systemd[940]: Starting GNOME Wacom tablet support service...
Apr 13 00:47:37 tom-hpenvy dbus-daemon[956]: [session uid=1000 pid=956] Successfully activated service 'org.gnome.Shell.Notifications'
Apr 13 00:47:37 tom-hpenvy gnome-session-binary[982]: Entering running state
Apr 13 00:47:37 tom-hpenvy systemd[940]: Finished Signal initialization done to GNOME Session Manager.
Apr 13 00:47:37 tom-hpenvy dbus-daemon[956]: [session uid=1000 pid=956] Activating service name='org.gnome.ScreenSaver' requested by ':1.36' (uid=1000 pid=1149 comm="/usr/lib/gsd-usb-protection")
Apr 13 00:47:37 tom-hpenvy kernel: rfkill: input handler disabled
Apr 13 00:47:37 tom-hpenvy systemd[940]: Started GNOME FreeDesktop screensaver service.
Apr 13 00:47:37 tom-hpenvy systemd[940]: Started GNOME date & time service.
Apr 13 00:47:37 tom-hpenvy systemd[940]: Started GNOME USB protection service.
Apr 13 00:47:37 tom-hpenvy systemd[940]: Started GNOME file sharing service.
Apr 13 00:47:37 tom-hpenvy systemd[940]: Started GNOME accessibility service.
Apr 13 00:47:37 tom-hpenvy systemd[940]: Started GNOME printer notifications service.
Apr 13 00:47:37 tom-hpenvy systemd[940]: Started GNOME smartcard service.
Apr 13 00:47:37 tom-hpenvy systemd[940]: Started GNOME sound sample caching service.
Apr 13 00:47:37 tom-hpenvy systemd[940]: Started GNOME maintenance of expirable data service.
Apr 13 00:47:37 tom-hpenvy systemd[940]: Started GNOME RFKill support service.
Apr 13 00:47:37 tom-hpenvy systemd[940]: Started Application launched by gnome-session-binary.
Apr 13 00:47:37 tom-hpenvy systemd[940]: Reached target GNOME accessibility target.
Apr 13 00:47:37 tom-hpenvy systemd[940]: Reached target GNOME date & time target.
Apr 13 00:47:37 tom-hpenvy systemd[940]: Reached target GNOME maintenance of expirable data target.
Apr 13 00:47:37 tom-hpenvy systemd[940]: Reached target GNOME printer notifications target.
Apr 13 00:47:37 tom-hpenvy systemd[940]: Reached target GNOME RFKill support target.
Apr 13 00:47:37 tom-hpenvy systemd[940]: Reached target GNOME FreeDesktop screensaver target.
Apr 13 00:47:37 tom-hpenvy systemd[940]: Reached target GNOME file sharing target.
Apr 13 00:47:37 tom-hpenvy systemd[940]: Reached target GNOME smartcard target.
Apr 13 00:47:37 tom-hpenvy systemd[940]: Reached target GNOME sound sample caching target.
Apr 13 00:47:37 tom-hpenvy systemd[940]: Reached target GNOME USB protection target.
Apr 13 00:47:37 tom-hpenvy gnome-session[982]: gnome-session-binary[982]: GnomeDesktop-WARNING: Could not create transient scope for PID 1169: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Process with ID 1169 does not exist.
Apr 13 00:47:37 tom-hpenvy gnome-session[982]: gnome-session-binary[982]: GnomeDesktop-WARNING: Could not create transient scope for PID 1172: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Process with ID 1172 does not exist.
Apr 13 00:47:37 tom-hpenvy gnome-session-binary[982]: GnomeDesktop-WARNING: Could not create transient scope for PID 1169: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Process with ID 1169 does not exist.
Apr 13 00:47:37 tom-hpenvy gnome-session-binary[982]: GnomeDesktop-WARNING: Could not create transient scope for PID 1172: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Process with ID 1172 does not exist.
Apr 13 00:47:37 tom-hpenvy dbus-daemon[956]: [session uid=1000 pid=956] Successfully activated service 'org.gnome.ScreenSaver'
Apr 13 00:47:37 tom-hpenvy gsd-usb-protect[1149]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Apr 13 00:47:37 tom-hpenvy NetworkManager[468]: <info>  [1649825257.5930] agent-manager: agent[ada6c6edb836c555,:1.45/org.gnome.Shell.NetworkAgent/1000]: agent registered
Apr 13 00:47:37 tom-hpenvy systemd[940]: Started GNOME keyboard configuration service.
Apr 13 00:47:37 tom-hpenvy systemd[940]: Reached target GNOME keyboard configuration target.
Apr 13 00:47:37 tom-hpenvy systemd[940]: Started GNOME color management service.
Apr 13 00:47:37 tom-hpenvy systemd[940]: Reached target GNOME color management target.
Apr 13 00:47:37 tom-hpenvy systemd[940]: Started GNOME keyboard shortcuts service.
Apr 13 00:47:37 tom-hpenvy systemd[940]: Reached target GNOME keyboard shortcuts target.
Apr 13 00:47:37 tom-hpenvy systemd[940]: Started GNOME power management service.
Apr 13 00:47:37 tom-hpenvy systemd[940]: Reached target GNOME power management target.
Apr 13 00:47:37 tom-hpenvy systemd[940]: Started GNOME Wacom tablet support service.
Apr 13 00:47:37 tom-hpenvy systemd[940]: Reached target GNOME Wacom tablet support target.
Apr 13 00:47:37 tom-hpenvy systemd[940]: Reached target GNOME Session.
Apr 13 00:47:37 tom-hpenvy systemd[940]: Reached target GNOME Wayland Session (session: gnome).
Apr 13 00:47:37 tom-hpenvy systemd[940]: Reached target Current graphical user session.
Apr 13 00:47:37 tom-hpenvy gsd-wacom[1155]: file ../libwacom-2.2.0/libwacom/libwacom.c: line 1005 (libwacom_set_default_match): should not be reached
Apr 13 00:47:37 tom-hpenvy gsd-media-keys[1128]: Failed to grab accelerator for keybinding settings:hibernate
Apr 13 00:47:37 tom-hpenvy gsd-media-keys[1128]: Failed to grab accelerator for keybinding settings:playback-repeat
Apr 13 00:47:38 tom-hpenvy welcome.desktop[1143]: Welcome app is disabled. To start it anyway, use option --enable (temporarily: --once).
Apr 13 00:47:38 tom-hpenvy gnome-shell[997]: GNOME Shell started at Wed Apr 13 2022 00:47:37 GMT-0400 (Eastern Daylight Time)
Apr 13 00:47:38 tom-hpenvy gnome-shell[997]: Registering session with GDM
Apr 13 00:47:38 tom-hpenvy gsd-a11y-settin[767]: Error releasing name org.gnome.SettingsDaemon.A11ySettings: The connection is closed
Apr 13 00:47:38 tom-hpenvy gsd-print-notif[766]: Error releasing name org.gnome.SettingsDaemon.PrintNotifications: The connection is closed
Apr 13 00:47:38 tom-hpenvy audit[629]: USER_END pid=629 uid=0 auid=120 ses=1 msg='op=PAM:session_close grantors=pam_loginuid,pam_keyinit,pam_succeed_if,pam_permit,pam_systemd,pam_env acct="gdm" exe="/usr/lib/gdm-session-worker" hostname=tom-hpenvy addr=? terminal=/dev/tty1 res=success'
Apr 13 00:47:38 tom-hpenvy audit[629]: CRED_DISP pid=629 uid=0 auid=120 ses=1 msg='op=PAM:setcred grantors=pam_permit acct="gdm" exe="/usr/lib/gdm-session-worker" hostname=tom-hpenvy addr=? terminal=/dev/tty1 res=success'
Apr 13 00:47:38 tom-hpenvy gdm-launch-environment][629]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Apr 13 00:47:38 tom-hpenvy systemd-logind[463]: Session 1 logged out. Waiting for processes to exit.
Apr 13 00:47:38 tom-hpenvy gsd-color[1119]: failed to connect to device: Failed to connect to missing device /org/freedesktop/ColorManager/devices/xrandr_LG_Display_gdm_120
Apr 13 00:47:38 tom-hpenvy polkitd[471]: Unregistered Authentication Agent for unix-session:1 (system bus name :1.18, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8) (disconnected from bus)
Apr 13 00:47:38 tom-hpenvy systemd[1]: session-1.scope: Deactivated successfully.
Apr 13 00:47:38 tom-hpenvy systemd[1]: session-1.scope: Consumed 2.279s CPU time.
Apr 13 00:47:38 tom-hpenvy systemd-logind[463]: Removed session 1.
Apr 13 00:47:38 tom-hpenvy gdm[496]: Gdm: Child process -642 was already dead.
Apr 13 00:47:49 tom-hpenvy systemd[1]: Stopping User Manager for UID 120...
Apr 13 00:47:49 tom-hpenvy systemd[634]: Activating special unit Exit the Session...
Apr 13 00:47:49 tom-hpenvy systemd[634]: Stopped target Main User Target.
Apr 13 00:47:49 tom-hpenvy systemd[634]: Stopping D-Bus User Message Bus...
Apr 13 00:47:49 tom-hpenvy systemd[634]: Stopping PipeWire PulseAudio...
Apr 13 00:47:49 tom-hpenvy systemd[634]: Stopped D-Bus User Message Bus.
Apr 13 00:47:49 tom-hpenvy systemd[634]: Stopped PipeWire PulseAudio.
Apr 13 00:47:49 tom-hpenvy systemd[634]: Stopping PipeWire Media Session Manager...
Apr 13 00:47:49 tom-hpenvy systemd[634]: Stopped PipeWire Media Session Manager.
Apr 13 00:47:49 tom-hpenvy systemd[634]: Stopping PipeWire Multimedia Service...
Apr 13 00:47:49 tom-hpenvy systemd[634]: Stopped PipeWire Multimedia Service.
Apr 13 00:47:49 tom-hpenvy systemd[634]: Removed slice User Core Session Slice.
Apr 13 00:47:49 tom-hpenvy systemd[634]: Stopped target Basic System.
Apr 13 00:47:49 tom-hpenvy systemd[634]: Stopped target Paths.
Apr 13 00:47:49 tom-hpenvy systemd[634]: Stopped target Sockets.
Apr 13 00:47:49 tom-hpenvy systemd[634]: Stopped target Timers.
Apr 13 00:47:49 tom-hpenvy systemd[634]: Closed D-Bus User Message Bus Socket.
Apr 13 00:47:49 tom-hpenvy systemd[634]: Closed GnuPG network certificate management daemon.
Apr 13 00:47:49 tom-hpenvy systemd[634]: Closed GCR ssh-agent wrapper.
Apr 13 00:47:49 tom-hpenvy systemd[634]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
Apr 13 00:47:49 tom-hpenvy systemd[634]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
Apr 13 00:47:49 tom-hpenvy systemd[634]: Closed GnuPG cryptographic agent (ssh-agent emulation).
Apr 13 00:47:49 tom-hpenvy systemd[634]: Closed GnuPG cryptographic agent and passphrase cache.
Apr 13 00:47:49 tom-hpenvy systemd[634]: Closed p11-kit server.
Apr 13 00:47:49 tom-hpenvy systemd[634]: Closed PipeWire PulseAudio.
Apr 13 00:47:49 tom-hpenvy systemd[634]: Closed PipeWire Multimedia System Socket.
Apr 13 00:47:49 tom-hpenvy systemd[634]: Removed slice User Application Slice.
Apr 13 00:47:49 tom-hpenvy systemd[634]: Reached target Shutdown.
Apr 13 00:47:49 tom-hpenvy systemd[634]: Finished Exit the Session.
Apr 13 00:47:49 tom-hpenvy systemd[634]: Reached target Exit the Session.
Apr 13 00:47:49 tom-hpenvy systemd[635]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[gdm] ruser=[<unknown>] rhost=[<unknown>]
Apr 13 00:47:49 tom-hpenvy systemd[1]: user@120.service: Deactivated successfully.
Apr 13 00:47:49 tom-hpenvy systemd[1]: Stopped User Manager for UID 120.
Apr 13 00:47:49 tom-hpenvy audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@120 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 13 00:47:49 tom-hpenvy kernel: kauditd_printk_skb: 9 callbacks suppressed
Apr 13 00:47:49 tom-hpenvy kernel: audit: type=1131 audit(1649825269.049:87): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@120 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 13 00:47:49 tom-hpenvy systemd[1]: Stopping User Runtime Directory /run/user/120...
Apr 13 00:47:49 tom-hpenvy systemd[1]: run-user-120.mount: Deactivated successfully.
Apr 13 00:47:49 tom-hpenvy systemd[1]: user-runtime-dir@120.service: Deactivated successfully.
Apr 13 00:47:49 tom-hpenvy systemd[1]: Stopped User Runtime Directory /run/user/120.
Apr 13 00:47:49 tom-hpenvy audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@120 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 13 00:47:49 tom-hpenvy kernel: audit: type=1131 audit(1649825269.056:88): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@120 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 13 00:47:49 tom-hpenvy systemd[1]: Removed slice User Slice of UID 120.
Apr 13 00:47:49 tom-hpenvy systemd[1]: user-120.slice: Consumed 2.450s CPU time.
Apr 13 00:47:55 tom-hpenvy systemd-timesyncd[456]: Initial synchronization to time server 222.166.0.136:123 (2.arch.pool.ntp.org).
Apr 13 00:47:57 tom-hpenvy systemd[940]: Started Application launched by gsd-media-keys.
Apr 13 00:47:57 tom-hpenvy dbus-daemon[956]: [session uid=1000 pid=956] Activating via systemd: service name='org.gnome.Terminal' unit='gnome-terminal-server.service' requested by ':1.51' (uid=1000 pid=1381 comm="gnome-terminal")
Apr 13 00:47:57 tom-hpenvy systemd[940]: Created slice Slice /app/org.gnome.Terminal.
Apr 13 00:47:57 tom-hpenvy systemd[940]: Starting GNOME Terminal Server...
Apr 13 00:47:57 tom-hpenvy dbus-daemon[956]: [session uid=1000 pid=956] Successfully activated service 'org.gnome.Terminal'
Apr 13 00:47:57 tom-hpenvy systemd[940]: Started GNOME Terminal Server.
Apr 13 00:47:57 tom-hpenvy systemd[940]: Started VTE child process 1406 launched by gnome-terminal-server process 1388.
Apr 13 00:48:07 tom-hpenvy systemd[1]: systemd-localed.service: Deactivated successfully.
Apr 13 00:48:07 tom-hpenvy audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 13 00:48:07 tom-hpenvy kernel: audit: type=1131 audit(1649825287.660:89): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 13 00:48:07 tom-hpenvy systemd[1]: systemd-hostnamed.service: Deactivated successfully.
Apr 13 00:48:07 tom-hpenvy audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 13 00:48:07 tom-hpenvy kernel: audit: type=1131 audit(1649825287.717:90): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 13 00:48:07 tom-hpenvy audit: BPF prog-id=0 op=UNLOAD
Apr 13 00:48:07 tom-hpenvy kernel: audit: type=1334 audit(1649825287.754:91): prog-id=0 op=UNLOAD
Apr 13 00:48:07 tom-hpenvy kernel: audit: type=1334 audit(1649825287.754:92): prog-id=0 op=UNLOAD
Apr 13 00:48:07 tom-hpenvy kernel: audit: type=1334 audit(1649825287.754:93): prog-id=0 op=UNLOAD
Apr 13 00:48:07 tom-hpenvy kernel: audit: type=1334 audit(1649825287.861:94): prog-id=0 op=UNLOAD
Apr 13 00:48:07 tom-hpenvy kernel: audit: type=1334 audit(1649825287.861:95): prog-id=0 op=UNLOAD
Apr 13 00:48:07 tom-hpenvy kernel: audit: type=1334 audit(1649825287.861:96): prog-id=0 op=UNLOAD
Apr 13 00:48:26 tom-hpenvy geoclue[738]: Service not used for 60 seconds. Shutting down..
Apr 13 00:48:26 tom-hpenvy systemd[1]: geoclue.service: Deactivated successfully.
Apr 13 00:48:26 tom-hpenvy audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=geoclue comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 13 00:48:26 tom-hpenvy kernel: audit: type=1131 audit(1649825306.849:97): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=geoclue comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 13 00:48:37 tom-hpenvy dbus-daemon[956]: [session uid=1000 pid=956] Activating via systemd: service name='org.gtk.vfs.Metadata' unit='gvfs-metadata.service' requested by ':1.11' (uid=1000 pid=997 comm="/usr/bin/gnome-shell")
Apr 13 00:48:37 tom-hpenvy systemd[940]: Starting Virtual filesystem metadata service...
Apr 13 00:48:37 tom-hpenvy dbus-daemon[956]: [session uid=1000 pid=956] Successfully activated service 'org.gtk.vfs.Metadata'
Apr 13 00:48:37 tom-hpenvy systemd[940]: Started Virtual filesystem metadata service.
Apr 13 00:48:48 tom-hpenvy gnome-shell[997]: *** BUG ***
Apr 13 00:48:48 tom-hpenvy gnome-shell[997]: In pixman_region32_init_rect: Invalid rectangle passed
Apr 13 00:48:48 tom-hpenvy gnome-shell[997]: Set a breakpoint on '_pixman_log_error' to debug
Apr 13 00:49:13 tom-hpenvy systemd-timesyncd[456]: Timed out waiting for reply from 222.166.0.136:123 (2.arch.pool.ntp.org).
Apr 13 00:49:23 tom-hpenvy systemd-timesyncd[456]: Timed out waiting for reply from 129.70.132.37:123 (2.arch.pool.ntp.org).
Apr 13 00:49:25 tom-hpenvy systemd-timesyncd[456]: Initial synchronization to time server 213.109.127.82:123 (2.arch.pool.ntp.org).
Apr 13 00:51:09 tom-hpenvy systemd[940]: Started VTE child process 1446 launched by gnome-terminal-server process 1388.
Apr 13 00:53:18 tom-hpenvy systemd[940]: Starting EOS update notifier service...
Apr 13 00:53:24 tom-hpenvy eos-update-notifier[1468]: Checking for updates ...
Apr 13 00:53:28 tom-hpenvy systemd[940]: Finished EOS update notifier service.
Apr 13 00:53:28 tom-hpenvy systemd[940]: eos-update-notifier.service: Consumed 1.510s CPU time.
Apr 13 00:53:28 tom-hpenvy gnome-shell[997]: *** BUG ***
Apr 13 00:53:28 tom-hpenvy gnome-shell[997]: In pixman_region32_init_rect: Invalid rectangle passed
Apr 13 00:53:28 tom-hpenvy gnome-shell[997]: Set a breakpoint on '_pixman_log_error' to debug
Apr 13 00:53:34 tom-hpenvy systemd[940]: Started VTE child process 1601 launched by gnome-terminal-server process 1388.
Apr 13 00:53:34 tom-hpenvy dbus-daemon[461]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.65' (uid=0 pid=1612 comm="sudo pacman -S -y -u --config /etc/pacman.conf --")
Apr 13 00:53:34 tom-hpenvy dbus-daemon[461]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Apr 13 00:53:34 tom-hpenvy sudo[1612]: pam_systemd_home(sudo:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Apr 13 00:53:36 tom-hpenvy audit[1612]: USER_AUTH pid=1612 uid=1000 auid=1000 ses=4 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="tom" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Apr 13 00:53:36 tom-hpenvy kernel: audit: type=1100 audit(1649825616.789:98): pid=1612 uid=1000 auid=1000 ses=4 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="tom" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Apr 13 00:53:36 tom-hpenvy kernel: audit: type=1101 audit(1649825616.789:99): pid=1612 uid=1000 auid=1000 ses=4 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="tom" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Apr 13 00:53:36 tom-hpenvy audit[1612]: USER_ACCT pid=1612 uid=1000 auid=1000 ses=4 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="tom" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Apr 13 00:53:36 tom-hpenvy sudo[1612]:      tom : TTY=pts/2 ; PWD=/home/tom ; USER=root ; COMMAND=/usr/bin/pacman -S -y -u --config /etc/pacman.conf --
Apr 13 00:53:36 tom-hpenvy audit[1612]: CRED_REFR pid=1612 uid=1000 auid=1000 ses=4 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Apr 13 00:53:36 tom-hpenvy sudo[1612]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1000)
Apr 13 00:53:36 tom-hpenvy audit[1612]: USER_START pid=1612 uid=1000 auid=1000 ses=4 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Apr 13 00:53:36 tom-hpenvy kernel: audit: type=1110 audit(1649825616.792:100): pid=1612 uid=1000 auid=1000 ses=4 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Apr 13 00:53:36 tom-hpenvy kernel: audit: type=1105 audit(1649825616.792:101): pid=1612 uid=1000 auid=1000 ses=4 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Apr 13 00:53:46 tom-hpenvy wpa_supplicant[612]: wlan0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-64 noise=9999 txrate=117000
Apr 13 00:54:02 tom-hpenvy systemd[1]: Reloading.
Apr 13 00:54:02 tom-hpenvy audit: BPF prog-id=30 op=LOAD
Apr 13 00:54:02 tom-hpenvy audit: BPF prog-id=0 op=UNLOAD
Apr 13 00:54:02 tom-hpenvy audit: BPF prog-id=31 op=LOAD
Apr 13 00:54:02 tom-hpenvy kernel: audit: type=1334 audit(1649825642.458:102): prog-id=30 op=LOAD
Apr 13 00:54:02 tom-hpenvy kernel: audit: type=1334 audit(1649825642.458:103): prog-id=0 op=UNLOAD
Apr 13 00:54:02 tom-hpenvy kernel: audit: type=1334 audit(1649825642.458:104): prog-id=31 op=LOAD
Apr 13 00:54:02 tom-hpenvy kernel: audit: type=1334 audit(1649825642.458:105): prog-id=32 op=LOAD
Apr 13 00:54:02 tom-hpenvy kernel: audit: type=1334 audit(1649825642.458:106): prog-id=0 op=UNLOAD
Apr 13 00:54:02 tom-hpenvy kernel: audit: type=1334 audit(1649825642.458:107): prog-id=0 op=UNLOAD
Apr 13 00:54:02 tom-hpenvy kernel: audit: type=1334 audit(1649825642.461:108): prog-id=33 op=LOAD
Apr 13 00:54:02 tom-hpenvy kernel: audit: type=1334 audit(1649825642.461:109): prog-id=0 op=UNLOAD
Apr 13 00:54:02 tom-hpenvy audit: BPF prog-id=32 op=LOAD
Apr 13 00:54:02 tom-hpenvy audit: BPF prog-id=33 op=LOAD
Apr 13 00:54:02 tom-hpenvy audit: BPF prog-id=34 op=LOAD
Apr 13 00:54:02 tom-hpenvy audit: BPF prog-id=35 op=LOAD
Apr 13 00:54:02 tom-hpenvy audit: BPF prog-id=36 op=LOAD
Apr 13 00:54:02 tom-hpenvy audit: BPF prog-id=37 op=LOAD
Apr 13 00:54:02 tom-hpenvy audit: BPF prog-id=38 op=LOAD
Apr 13 00:54:02 tom-hpenvy audit: BPF prog-id=39 op=LOAD
Apr 13 00:54:02 tom-hpenvy audit: BPF prog-id=40 op=LOAD
Apr 13 00:54:02 tom-hpenvy audit: BPF prog-id=41 op=LOAD
Apr 13 00:54:02 tom-hpenvy audit: BPF prog-id=42 op=LOAD
Apr 13 00:54:02 tom-hpenvy kernel: audit: type=1334 audit(1649825642.461:110): prog-id=34 op=LOAD
Apr 13 00:54:02 tom-hpenvy kernel: audit: type=1334 audit(1649825642.461:111): prog-id=35 op=LOAD
Apr 13 00:54:10 tom-hpenvy wpa_supplicant[612]: wlan0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-64 noise=9999 txrate=117000
Apr 13 00:54:13 tom-hpenvy sudo[1612]: pam_unix(sudo:session): session closed for user root
Apr 13 00:54:13 tom-hpenvy audit[1612]: USER_END pid=1612 uid=1000 auid=1000 ses=4 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Apr 13 00:54:13 tom-hpenvy audit[1612]: CRED_DISP pid=1612 uid=1000 auid=1000 ses=4 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Apr 13 00:54:13 tom-hpenvy kernel: kauditd_printk_skb: 16 callbacks suppressed
Apr 13 00:54:13 tom-hpenvy kernel: audit: type=1106 audit(1649825653.993:128): pid=1612 uid=1000 auid=1000 ses=4 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Apr 13 00:54:13 tom-hpenvy kernel: audit: type=1104 audit(1649825653.993:129): pid=1612 uid=1000 auid=1000 ses=4 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Apr 13 00:57:23 tom-hpenvy dbus-daemon[461]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.66' (uid=0 pid=7155 comm="sudo dmesg")
Apr 13 00:57:23 tom-hpenvy dbus-daemon[461]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Apr 13 00:57:23 tom-hpenvy sudo[7155]: pam_systemd_home(sudo:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Apr 13 00:57:25 tom-hpenvy audit[7155]: USER_AUTH pid=7155 uid=1000 auid=1000 ses=4 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="tom" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 13 00:57:25 tom-hpenvy audit[7155]: USER_ACCT pid=7155 uid=1000 auid=1000 ses=4 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="tom" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 13 00:57:25 tom-hpenvy sudo[7155]:      tom : TTY=pts/1 ; PWD=/home/tom ; USER=root ; COMMAND=/usr/bin/dmesg
Apr 13 00:57:25 tom-hpenvy audit[7155]: CRED_REFR pid=7155 uid=1000 auid=1000 ses=4 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 13 00:57:25 tom-hpenvy audit[7155]: USER_START pid=7155 uid=1000 auid=1000 ses=4 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 13 00:57:25 tom-hpenvy sudo[7155]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1000)
Apr 13 00:57:25 tom-hpenvy kernel: audit: type=1100 audit(1649825845.654:130): pid=7155 uid=1000 auid=1000 ses=4 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="tom" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 13 00:57:25 tom-hpenvy kernel: audit: type=1101 audit(1649825845.654:131): pid=7155 uid=1000 auid=1000 ses=4 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="tom" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 13 00:57:25 tom-hpenvy kernel: audit: type=1110 audit(1649825845.654:132): pid=7155 uid=1000 auid=1000 ses=4 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 13 00:57:25 tom-hpenvy kernel: audit: type=1105 audit(1649825845.654:133): pid=7155 uid=1000 auid=1000 ses=4 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 13 00:57:25 tom-hpenvy sudo[7155]: pam_unix(sudo:session): session closed for user root
Apr 13 00:57:25 tom-hpenvy audit[7155]: USER_END pid=7155 uid=1000 auid=1000 ses=4 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 13 00:57:25 tom-hpenvy audit[7155]: CRED_DISP pid=7155 uid=1000 auid=1000 ses=4 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 13 00:57:25 tom-hpenvy kernel: audit: type=1106 audit(1649825845.674:134): pid=7155 uid=1000 auid=1000 ses=4 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 13 00:57:25 tom-hpenvy kernel: audit: type=1104 audit(1649825845.674:135): pid=7155 uid=1000 auid=1000 ses=4 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 13 00:57:38 tom-hpenvy dbus-daemon[461]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.67' (uid=0 pid=7159 comm="sudo dmesg")
Apr 13 00:57:38 tom-hpenvy dbus-daemon[461]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Apr 13 00:57:38 tom-hpenvy sudo[7159]: pam_systemd_home(sudo:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Apr 13 00:57:38 tom-hpenvy audit[7159]: USER_ACCT pid=7159 uid=1000 auid=1000 ses=4 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="tom" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 13 00:57:38 tom-hpenvy sudo[7159]:      tom : TTY=pts/1 ; PWD=/home/tom ; USER=root ; COMMAND=/usr/bin/dmesg
Apr 13 00:57:38 tom-hpenvy audit[7159]: CRED_REFR pid=7159 uid=1000 auid=1000 ses=4 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 13 00:57:38 tom-hpenvy kernel: audit: type=1101 audit(1649825858.898:136): pid=7159 uid=1000 auid=1000 ses=4 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="tom" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 13 00:57:38 tom-hpenvy kernel: audit: type=1110 audit(1649825858.898:137): pid=7159 uid=1000 auid=1000 ses=4 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 13 00:57:38 tom-hpenvy audit[7159]: USER_START pid=7159 uid=1000 auid=1000 ses=4 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 13 00:57:38 tom-hpenvy sudo[7159]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1000)
Apr 13 00:57:38 tom-hpenvy kernel: audit: type=1105 audit(1649825858.901:138): pid=7159 uid=1000 auid=1000 ses=4 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 13 00:57:38 tom-hpenvy sudo[7159]: pam_unix(sudo:session): session closed for user root
Apr 13 00:57:38 tom-hpenvy audit[7159]: USER_END pid=7159 uid=1000 auid=1000 ses=4 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 13 00:57:38 tom-hpenvy audit[7159]: CRED_DISP pid=7159 uid=1000 auid=1000 ses=4 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 13 00:57:38 tom-hpenvy kernel: audit: type=1106 audit(1649825858.908:139): pid=7159 uid=1000 auid=1000 ses=4 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 13 00:57:38 tom-hpenvy kernel: audit: type=1104 audit(1649825858.908:140): pid=7159 uid=1000 auid=1000 ses=4 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 13 00:59:52 tom-hpenvy systemd[940]: vte-spawn-a212659c-d571-4bbf-8e49-e8af4d15d255.scope: Consumed 17.256s CPU time.
Apr 13 00:59:58 tom-hpenvy dbus-daemon[461]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.68' (uid=0 pid=7189 comm="sudo pacman -S -y -u --config /etc/pacman.conf --")
Apr 13 00:59:58 tom-hpenvy dbus-daemon[461]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Apr 13 00:59:58 tom-hpenvy sudo[7189]: pam_systemd_home(sudo:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Apr 13 01:00:00 tom-hpenvy audit[7189]: USER_AUTH pid=7189 uid=1000 auid=1000 ses=4 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="tom" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Apr 13 01:00:00 tom-hpenvy audit[7189]: USER_ACCT pid=7189 uid=1000 auid=1000 ses=4 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="tom" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Apr 13 01:00:00 tom-hpenvy kernel: audit: type=1100 audit(1649826000.340:141): pid=7189 uid=1000 auid=1000 ses=4 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="tom" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Apr 13 01:00:00 tom-hpenvy kernel: audit: type=1101 audit(1649826000.340:142): pid=7189 uid=1000 auid=1000 ses=4 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="tom" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Apr 13 01:00:00 tom-hpenvy kernel: audit: type=1110 audit(1649826000.344:143): pid=7189 uid=1000 auid=1000 ses=4 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Apr 13 01:00:00 tom-hpenvy audit[7189]: CRED_REFR pid=7189 uid=1000 auid=1000 ses=4 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Apr 13 01:00:00 tom-hpenvy sudo[7189]:      tom : TTY=pts/0 ; PWD=/home/tom/logs ; USER=root ; COMMAND=/usr/bin/pacman -S -y -u --config /etc/pacman.conf --
Apr 13 01:00:00 tom-hpenvy sudo[7189]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1000)
Apr 13 01:00:00 tom-hpenvy audit[7189]: USER_START pid=7189 uid=1000 auid=1000 ses=4 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Apr 13 01:00:00 tom-hpenvy kernel: audit: type=1105 audit(1649826000.347:144): pid=7189 uid=1000 auid=1000 ses=4 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Apr 13 01:00:00 tom-hpenvy kernel: atkbd serio0: Unknown key pressed (translated set 2, code 0xab on isa0060/serio0).
Apr 13 01:00:00 tom-hpenvy kernel: atkbd serio0: Use 'setkeycodes e02b <keycode>' to make it known.
Apr 13 01:00:00 tom-hpenvy kernel: atkbd serio0: Unknown key released (translated set 2, code 0xab on isa0060/serio0).
Apr 13 01:00:01 tom-hpenvy kernel: atkbd serio0: Unknown key pressed (translated set 2, code 0xab on isa0060/serio0).
Apr 13 01:00:01 tom-hpenvy kernel: atkbd serio0: Use 'setkeycodes e02b <keycode>' to make it known.
Apr 13 01:00:01 tom-hpenvy kernel: atkbd serio0: Unknown key released (translated set 2, code 0xab on isa0060/serio0).
Apr 13 01:00:02 tom-hpenvy kernel: atkbd serio0: Unknown key released (translated set 2, code 0xab on isa0060/serio0).
Apr 13 01:00:02 tom-hpenvy kernel: atkbd serio0: Use 'setkeycodes e02b <keycode>' to make it known.
Apr 13 01:00:02 tom-hpenvy kernel: atkbd serio0: Unknown key pressed (translated set 2, code 0xab on isa0060/serio0).
Apr 13 01:00:02 tom-hpenvy sudo[7189]: pam_unix(sudo:session): session closed for user root
Apr 13 01:00:02 tom-hpenvy audit[7189]: USER_END pid=7189 uid=1000 auid=1000 ses=4 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Apr 13 01:00:02 tom-hpenvy audit[7189]: CRED_DISP pid=7189 uid=1000 auid=1000 ses=4 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Apr 13 01:00:02 tom-hpenvy kernel: audit: type=1106 audit(1649826002.874:145): pid=7189 uid=1000 auid=1000 ses=4 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Apr 13 01:00:02 tom-hpenvy kernel: audit: type=1104 audit(1649826002.874:146): pid=7189 uid=1000 auid=1000 ses=4 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Apr 13 01:00:03 tom-hpenvy kernel: atkbd serio0: Unknown key pressed (translated set 2, code 0xab on isa0060/serio0).
Apr 13 01:00:03 tom-hpenvy kernel: atkbd serio0: Use 'setkeycodes e02b <keycode>' to make it known.
Apr 13 01:00:03 tom-hpenvy kernel: atkbd serio0: Unknown key released (translated set 2, code 0xab on isa0060/serio0).
Apr 13 01:02:36 tom-hpenvy systemd[1]: Starting Cleanup of Temporary Directories...
Apr 13 01:02:36 tom-hpenvy systemd[1]: systemd-tmpfiles-clean.service: Deactivated successfully.
Apr 13 01:02:36 tom-hpenvy systemd[1]: Finished Cleanup of Temporary Directories.
Apr 13 01:02:36 tom-hpenvy audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 13 01:02:36 tom-hpenvy audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 13 01:02:36 tom-hpenvy kernel: audit: type=1130 audit(1649826156.838:147): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 13 01:02:36 tom-hpenvy kernel: audit: type=1131 audit(1649826156.838:148): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 13 01:15:12 tom-hpenvy dbus-daemon[461]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.70' (uid=0 pid=7254 comm="gdm-session-worker [pam/gdm-password]")
Apr 13 01:15:12 tom-hpenvy dbus-daemon[461]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Apr 13 01:15:12 tom-hpenvy gdm-password][7254]: pam_systemd_home(gdm-password:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Apr 13 01:15:16 tom-hpenvy gdm-password][7254]: gkr-pam: unlocked login keyring
Apr 13 01:15:16 tom-hpenvy audit[7254]: USER_AUTH pid=7254 uid=0 auid=1000 ses=3 msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="tom" exe="/usr/lib/gdm-session-worker" hostname=tom-hpenvy addr=? terminal=/dev/tty1 res=success'
Apr 13 01:15:16 tom-hpenvy audit[7254]: USER_ACCT pid=7254 uid=0 auid=1000 ses=3 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="tom" exe="/usr/lib/gdm-session-worker" hostname=tom-hpenvy addr=? terminal=/dev/tty1 res=success'
Apr 13 01:15:16 tom-hpenvy kernel: audit: type=1100 audit(1649826916.389:149): pid=7254 uid=0 auid=1000 ses=3 msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="tom" exe="/usr/lib/gdm-session-worker" hostname=tom-hpenvy addr=? terminal=/dev/tty1 res=success'
Apr 13 01:15:16 tom-hpenvy kernel: audit: type=1101 audit(1649826916.389:150): pid=7254 uid=0 auid=1000 ses=3 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="tom" exe="/usr/lib/gdm-session-worker" hostname=tom-hpenvy addr=? terminal=/dev/tty1 res=success'
Apr 13 01:15:16 tom-hpenvy audit[7254]: CRED_REFR pid=7254 uid=0 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="tom" exe="/usr/lib/gdm-session-worker" hostname=tom-hpenvy addr=? terminal=/dev/tty1 res=success'
Apr 13 01:15:16 tom-hpenvy kernel: audit: type=1110 audit(1649826916.392:151): pid=7254 uid=0 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="tom" exe="/usr/lib/gdm-session-worker" hostname=tom-hpenvy addr=? terminal=/dev/tty1 res=success'
Apr 13 01:15:16 tom-hpenvy dbus-daemon[956]: [session uid=1000 pid=956] Activating service name='org.gnome.Shell.CalendarServer' requested by ':1.11' (uid=1000 pid=997 comm="/usr/bin/gnome-shell")
Apr 13 01:15:16 tom-hpenvy dbus-daemon[956]: [session uid=1000 pid=956] Activated service 'org.gnome.Shell.CalendarServer' failed: Process org.gnome.Shell.CalendarServer exited with status 127
Apr 13 01:15:16 tom-hpenvy org.gnome.Shell.CalendarServer[7260]: /usr/lib/gnome-shell-calendar-server: error while loading shared libraries: libecal-2.0.so.1: cannot open shared object file: No such file or directory
Apr 13 01:15:16 tom-hpenvy gnome-shell[997]: Error loading calendars: Error calling StartServiceByName for org.gnome.Shell.CalendarServer: Process org.gnome.Shell.CalendarServer exited with status 127
Apr 13 01:15:16 tom-hpenvy NetworkManager[468]: <info>  [1649826916.5643] agent-manager: agent[ada6c6edb836c555,:1.45/org.gnome.Shell.NetworkAgent/1000]: agent registered
Apr 13 01:29:23 tom-hpenvy wpa_supplicant[612]: wlan0: WPA: Group rekeying completed with 00:7f:28:bb:c6:cc [GTK=CCMP]
Apr 13 01:30:28 tom-hpenvy dbus-daemon[461]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.72' (uid=0 pid=7287 comm="gdm-session-worker [pam/gdm-password]")
Apr 13 01:30:28 tom-hpenvy dbus-daemon[461]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Apr 13 01:30:28 tom-hpenvy gdm-password][7287]: pam_systemd_home(gdm-password:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Apr 13 01:30:32 tom-hpenvy gdm-password][7287]: gkr-pam: unlocked login keyring
Apr 13 01:30:32 tom-hpenvy audit[7287]: USER_AUTH pid=7287 uid=0 auid=1000 ses=3 msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="tom" exe="/usr/lib/gdm-session-worker" hostname=tom-hpenvy addr=? terminal=/dev/tty1 res=success'
Apr 13 01:30:32 tom-hpenvy kernel: audit: type=1100 audit(1649827832.233:152): pid=7287 uid=0 auid=1000 ses=3 msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="tom" exe="/usr/lib/gdm-session-worker" hostname=tom-hpenvy addr=? terminal=/dev/tty1 res=success'
Apr 13 01:30:32 tom-hpenvy audit[7287]: USER_ACCT pid=7287 uid=0 auid=1000 ses=3 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="tom" exe="/usr/lib/gdm-session-worker" hostname=tom-hpenvy addr=? terminal=/dev/tty1 res=success'
Apr 13 01:30:32 tom-hpenvy audit[7287]: CRED_REFR pid=7287 uid=0 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="tom" exe="/usr/lib/gdm-session-worker" hostname=tom-hpenvy addr=? terminal=/dev/tty1 res=success'
Apr 13 01:30:32 tom-hpenvy kernel: audit: type=1101 audit(1649827832.236:153): pid=7287 uid=0 auid=1000 ses=3 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="tom" exe="/usr/lib/gdm-session-worker" hostname=tom-hpenvy addr=? terminal=/dev/tty1 res=success'
Apr 13 01:30:32 tom-hpenvy kernel: audit: type=1110 audit(1649827832.236:154): pid=7287 uid=0 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="tom" exe="/usr/lib/gdm-session-worker" hostname=tom-hpenvy addr=? terminal=/dev/tty1 res=success'
Apr 13 01:30:32 tom-hpenvy dbus-daemon[956]: [session uid=1000 pid=956] Activating service name='org.gnome.Shell.CalendarServer' requested by ':1.11' (uid=1000 pid=997 comm="/usr/bin/gnome-shell")
Apr 13 01:30:32 tom-hpenvy dbus-daemon[956]: [session uid=1000 pid=956] Activated service 'org.gnome.Shell.CalendarServer' failed: Process org.gnome.Shell.CalendarServer exited with status 127
Apr 13 01:30:32 tom-hpenvy org.gnome.Shell.CalendarServer[7293]: /usr/lib/gnome-shell-calendar-server: error while loading shared libraries: libecal-2.0.so.1: cannot open shared object file: No such file or directory
Apr 13 01:30:32 tom-hpenvy gnome-shell[997]: Error loading calendars: Error calling StartServiceByName for org.gnome.Shell.CalendarServer: Process org.gnome.Shell.CalendarServer exited with status 127
Apr 13 01:30:32 tom-hpenvy NetworkManager[468]: <info>  [1649827832.3922] agent-manager: agent[ada6c6edb836c555,:1.45/org.gnome.Shell.NetworkAgent/1000]: agent registered
Apr 13 01:30:47 tom-hpenvy gnome-shell[997]: *** BUG ***
Apr 13 01:30:47 tom-hpenvy gnome-shell[997]: In pixman_region32_init_rect: Invalid rectangle passed
Apr 13 01:30:49 tom-hpenvy dbus-daemon[461]: [system] Activating via systemd: service name='org.freedesktop.ModemManager1' unit='dbus-org.freedesktop.ModemManager1.service' requested by ':1.74' (uid=1000 pid=7340 comm="gnome-control-center")
Have you checked if there is a Bios update? Also try this kernel parameter.
idle=nomwait
about this
  • you have only 16 threads 0 to 15 ( not 16 )
  • why pcie_aspm=off ?
Why? You have not posted any relevant error messages from your log, that point towards HW problems. :thinking:
These seem like something is not configured well or some requirements/packages missing:
At some time in those messages, it seems a shutdown action is requested/activated. (I am not sure though…).
In general, it looks to me like a Gnome desktop issue, not a hardware problem.
I suggest you try installing and logging into another DE, like xfce, or other, to confirm it is or not related to Gnome. It could be because of the recent new Gnome upgrade issues. :person_shrugging:
@Stephane Thank you for noticing that typo! I’ve corrected it to 15 now. I added pcie_aspm=off originally when I thought there could be a problem with the NVMe SSD powersaving causing issues.
@petsam Thank you for your insight! You are correct that the kernel error messages shown on that wiki page are not the same as what I’m seeing in my logs; I thought it was the same issue because the symptoms are the same as what I’m experiencing but it is very possible that I’m jumping to conclusions. I will try a different DE as per your suggestion and see if the issues persist.
@ricklinux Thanks for your response; I did check for BIOS updates recently from the manufacturer’s website (HP) and installed one that was released in March this year. I’ve also tried adding the idle=nomwait parameter and I did not notice any change, but I’ve kept it just in case.
Have you tried disabling these? zenstates.py --c6-disable
:point_up_2:
I don’t think Gnome is the desktop to be on right now if you want to solve this issue as there are many bugs currently. Also i see you have many kernel parameters that i don’t think are needed for amdgpu and the Ryzen 5700U.
I have both an HP running 4700U and a Lenovo Running a 5700U and have no issues. I only have one kernel parameter for keyboard backlight error message. I am running on KDE Plasma.
The kernel parameter i think i would keep is
idle=nomwait
Possibly these if needed. You have to determine if the lockup or freezing is being caused by the nvme drive APST
Also some of these were required for some older Ryzen processors but newer Ryzen i don’t think so.
rcu_nocbs=0-15 (changed to 15)
nvme_core.default_ps_max_latency_us=0
As far as I’m concerned the 5700U shouldn’t have many issues. I would be starting with a fresh slate and ONLY use kernel parameters if they are needed and they actually fix the issue you have identified. I see you have a lot of kernel parameters that i think are unnecessary for amdgpu. There are likely some specific parameters needed for the envy but you need to identify the issue and what kernel parameter to try that may solve it.
@EOS Thank you for the suggestion! It still crashes currently with c6 disabled, but I will keep experimenting with this.
@ricklinux Thank you for your insight! I have switched to KDE Plasma and started fresh with the kernel parameters except for those few, as you suggested.
This combined with the disabled c6 states certainly seems to help, but it still has the same behavior (crashes ~50% of the time instead of ~100% of the time after left idle for 15-30 min).
I’ve been storing journalctl logs and looking through them, but I’m having a hard time discerning which lines relate to the root cause. For example, here are some recent crash logs but it doesn’t like like there are errors around the crash times. Could there be causes aren’t reflected in these logs?
Log 1: Crash around 12:00
Apr 15 11:41:36 tom-hpenvy audit[1223]: USER_ACCT pid=1223 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="tom" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 15 11:41:36 tom-hpenvy sudo[1223]:      tom : TTY=pts/1 ; PWD=/home/tom ; USER=root ; COMMAND=/usr/bin/zenstates --list
Apr 15 11:41:36 tom-hpenvy audit[1223]: CRED_REFR pid=1223 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 15 11:41:36 tom-hpenvy kernel: audit: type=1101 audit(1650037296.316:92): pid=1223 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="tom" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 15 11:41:36 tom-hpenvy kernel: audit: type=1110 audit(1650037296.316:93): pid=1223 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 15 11:41:36 tom-hpenvy sudo[1223]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1000)
Apr 15 11:41:36 tom-hpenvy audit[1223]: USER_START pid=1223 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 15 11:41:36 tom-hpenvy kernel: audit: type=1105 audit(1650037296.326:94): pid=1223 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 15 11:41:36 tom-hpenvy sudo[1223]: pam_unix(sudo:session): session closed for user root
Apr 15 11:41:36 tom-hpenvy audit[1223]: USER_END pid=1223 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 15 11:41:36 tom-hpenvy audit[1223]: CRED_DISP pid=1223 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 15 11:41:36 tom-hpenvy kernel: audit: type=1106 audit(1650037296.346:95): pid=1223 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 15 11:41:36 tom-hpenvy kernel: audit: type=1104 audit(1650037296.346:96): pid=1223 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 15 11:41:57 tom-hpenvy baloo_file[828]: 215052530089001730 "/home/tom/logs/crashlog_april15_idle_1130ish.txt" renaming "crashlog_april15_idle.txt" to "crashlog_april15_idle_1130ish.txt"
Apr 15 11:42:23 tom-hpenvy dbus-daemon[473]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.60' (uid=0 pid=1245 comm="sudo zenstates --list")
Apr 15 11:42:23 tom-hpenvy dbus-daemon[473]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Apr 15 11:42:23 tom-hpenvy sudo[1245]: pam_systemd_home(sudo:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Apr 15 11:42:23 tom-hpenvy audit[1245]: USER_ACCT pid=1245 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="tom" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 15 11:42:23 tom-hpenvy sudo[1245]:      tom : TTY=pts/1 ; PWD=/home/tom/logs ; USER=root ; COMMAND=/usr/bin/zenstates --list
Apr 15 11:42:23 tom-hpenvy audit[1245]: CRED_REFR pid=1245 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 15 11:42:23 tom-hpenvy sudo[1245]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1000)
Apr 15 11:42:23 tom-hpenvy audit[1245]: USER_START pid=1245 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 15 11:42:23 tom-hpenvy kernel: audit: type=1101 audit(1650037343.226:97): pid=1245 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="tom" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 15 11:42:23 tom-hpenvy kernel: audit: type=1110 audit(1650037343.226:98): pid=1245 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 15 11:42:23 tom-hpenvy kernel: audit: type=1105 audit(1650037343.226:99): pid=1245 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 15 11:42:23 tom-hpenvy sudo[1245]: pam_unix(sudo:session): session closed for user root
Apr 15 11:42:23 tom-hpenvy audit[1245]: USER_END pid=1245 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 15 11:42:23 tom-hpenvy audit[1245]: CRED_DISP pid=1245 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 15 11:42:23 tom-hpenvy kernel: audit: type=1106 audit(1650037343.256:100): pid=1245 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 15 11:42:23 tom-hpenvy kernel: audit: type=1104 audit(1650037343.256:101): pid=1245 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 15 11:42:27 tom-hpenvy systemd[683]: Started Firefox - Web Browser.
Apr 15 11:42:27 tom-hpenvy dbus-daemon[705]: [session uid=1000 pid=705] Activating via systemd: service name='org.a11y.Bus' unit='at-spi-dbus-bus.service' requested by ':1.44' (uid=1000 pid=1248 comm="/usr/lib/firefox/firefox")
Apr 15 11:42:27 tom-hpenvy systemd[683]: Starting Accessibility services bus...
Apr 15 11:42:27 tom-hpenvy dbus-daemon[705]: [session uid=1000 pid=705] Successfully activated service 'org.a11y.Bus'
Apr 15 11:42:27 tom-hpenvy systemd[683]: Started Accessibility services bus.
Apr 15 11:42:39 tom-hpenvy kded5[756]: Registering ":1.46/StatusNotifierItem" to system tray
Apr 15 11:43:04 tom-hpenvy kwin_x11[759]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 11742, resource id: 48234540, major code: 15 (QueryTree), minor code: 0
Apr 15 11:43:05 tom-hpenvy kwin_x11[759]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 11927, resource id: 29360311, major code: 18 (ChangeProperty), minor code: 0
Apr 15 11:43:05 tom-hpenvy systemd[683]: app-firefox-a7ce4bbbf2374b5abcb49fa5a1d0cf4f.scope: Consumed 17.913s CPU time.
Apr 15 11:44:11 tom-hpenvy dbus-daemon[473]: [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.26' (uid=1000 pid=826 comm="/usr/lib/org_kde_powerdevil") (using servicehelper)
Apr 15 11:44:11 tom-hpenvy dbus-daemon[473]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
Apr 15 11:44:41 tom-hpenvy dbus-daemon[473]: [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.26' (uid=1000 pid=826 comm="/usr/lib/org_kde_powerdevil") (using servicehelper)
Apr 15 11:44:41 tom-hpenvy dbus-daemon[473]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
Apr 15 11:45:11 tom-hpenvy dbus-daemon[473]: [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.26' (uid=1000 pid=826 comm="/usr/lib/org_kde_powerdevil") (using servicehelper)
Apr 15 11:45:11 tom-hpenvy dbus-daemon[473]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
Apr 15 11:47:11 tom-hpenvy systemd[683]: Starting EOS update notifier service...
Apr 15 11:47:17 tom-hpenvy eos-update-notifier[1760]: Checking for updates ...
Apr 15 11:47:21 tom-hpenvy eos-update-notifier[1760]: Checking AUR updates ...
Apr 15 11:47:22 tom-hpenvy systemd[683]: Finished EOS update notifier service.
Apr 15 11:48:11 tom-hpenvy kscreenlocker_greet[1831]: Qt: Session management error: networkIdsList argument is NULL
Apr 15 11:48:11 tom-hpenvy kscreenlocker_greet[1831]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/VirtualKeyboard.qml:8:1: module "QtQuick.VirtualKeyboard" is not installed
Apr 15 11:48:11 tom-hpenvy kscreenlocker_greet[1831]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/UserList.qml:42:9: Unable to assign [undefined] to bool
Apr 15 11:56:11 tom-hpenvy systemd[1]: Starting Cleanup of Temporary Directories...
Apr 15 11:56:11 tom-hpenvy systemd[1]: systemd-tmpfiles-clean.service: Deactivated successfully.
Apr 15 11:56:11 tom-hpenvy systemd[1]: Finished Cleanup of Temporary Directories.
Apr 15 11:56:11 tom-hpenvy audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 15 11:56:11 tom-hpenvy audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 15 11:56:11 tom-hpenvy kernel: audit: type=1130 audit(1650038171.454:102): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 15 11:56:11 tom-hpenvy kernel: audit: type=1131 audit(1650038171.454:103): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success
Log 2: Crash around 20:41
Apr 15 18:16:02 tom-hpenvy kernel: audit: type=1106 audit(1650060962.409:166): pid=8815 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 15 18:16:02 tom-hpenvy kernel: audit: type=1104 audit(1650060962.409:167): pid=8815 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 15 18:16:04 tom-hpenvy kwin_x11[787]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1317, resource id: 10839623, major code: 20 (GetProperty), minor code: 0
Apr 15 18:16:06 tom-hpenvy kwin_x11[787]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2634, resource id: 10839663, major code: 20 (GetProperty), minor code: 0
Apr 15 18:26:21 tom-hpenvy kwin_x11[787]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 54041, resource id: 48234710, major code: 15 (QueryTree), minor code: 0
Apr 15 18:26:22 tom-hpenvy kwin_x11[787]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 54258, resource id: 31457742, major code: 18 (ChangeProperty), minor code: 0
Apr 15 18:26:23 tom-hpenvy systemd[711]: app-firefox-9562483979a3426d9b3ede37ef20897e.scope: Consumed 1h 4min 22.268s CPU time.
Apr 15 18:27:23 tom-hpenvy dbus-daemon[550]: [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.26' (uid=1000 pid=864 comm="/usr/lib/org_kde_powerdevil") (using servicehelper)
Apr 15 18:27:23 tom-hpenvy dbus-daemon[550]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
Apr 15 18:27:53 tom-hpenvy dbus-daemon[550]: [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.26' (uid=1000 pid=864 comm="/usr/lib/org_kde_powerdevil") (using servicehelper)
Apr 15 18:27:53 tom-hpenvy dbus-daemon[550]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
Apr 15 18:28:23 tom-hpenvy dbus-daemon[550]: [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.26' (uid=1000 pid=864 comm="/usr/lib/org_kde_powerdevil") (using servicehelper)
Apr 15 18:28:23 tom-hpenvy dbus-daemon[550]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
Apr 15 18:29:24 tom-hpenvy wpa_supplicant[599]: wlan0: WPA: Group rekeying completed with 00:7f:28:bb:c6:cc [GTK=CCMP]
Apr 15 18:31:23 tom-hpenvy kscreenlocker_greet[9213]: Qt: Session management error: networkIdsList argument is NULL
Apr 15 18:31:24 tom-hpenvy kscreenlocker_greet[9213]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "en_US" . Search paths ("/usr/share/qt/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
Apr 15 18:31:24 tom-hpenvy kscreenlocker_greet[9213]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/UserList.qml:42:9: Unable to assign [undefined] to bool
Apr 15 19:29:24 tom-hpenvy wpa_supplicant[599]: wlan0: WPA: Group rekeying completed with 00:7f:28:bb:c6:cc [GTK=CCMP]
Apr 15 19:34:26 tom-hpenvy dbus-daemon[550]: [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.26' (uid=1000 pid=864 comm="/usr/lib/org_kde_powerdevil") (using servicehelper)
Apr 15 19:34:26 tom-hpenvy dbus-daemon[550]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
Apr 15 19:34:31 tom-hpenvy dbus-daemon[550]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.284' (uid=1000 pid=9299 comm="kcheckpass -m classic -S 31")
Apr 15 19:34:31 tom-hpenvy dbus-daemon[550]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Apr 15 19:34:31 tom-hpenvy kcheckpass[9299]: pam_systemd_home(kde:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Apr 15 19:34:31 tom-hpenvy audit[9301]: USER_AUTH pid=9301 uid=1000 auid=1000 ses=2 msg='op=PAM:unix_chkpwd acct="tom" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
Apr 15 19:34:31 tom-hpenvy kernel: audit: type=1100 audit(1650065671.647:168): pid=9301 uid=1000 auid=1000 ses=2 msg='op=PAM:unix_chkpwd acct="tom" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
Apr 15 19:34:31 tom-hpenvy kwin_x11[787]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 59330, resource id: 48234550, major code: 18 (ChangeProperty), minor code: 0
Apr 15 19:34:46 tom-hpenvy dbus-daemon[550]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.285' (uid=0 pid=9304 comm="sudo zenstates --list")
Apr 15 19:34:46 tom-hpenvy dbus-daemon[550]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Apr 15 19:34:46 tom-hpenvy sudo[9304]: pam_systemd_home(sudo:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Apr 15 19:34:50 tom-hpenvy audit[9304]: USER_AUTH pid=9304 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="tom" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 15 19:34:50 tom-hpenvy audit[9304]: USER_ACCT pid=9304 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="tom" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 15 19:34:50 tom-hpenvy sudo[9304]:      tom : TTY=pts/1 ; PWD=/home/tom ; USER=root ; COMMAND=/usr/bin/zenstates --list
Apr 15 19:34:50 tom-hpenvy audit[9304]: CRED_REFR pid=9304 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 15 19:34:50 tom-hpenvy kernel: audit: type=1100 audit(1650065690.770:169): pid=9304 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="tom" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 15 19:34:50 tom-hpenvy kernel: audit: type=1101 audit(1650065690.770:170): pid=9304 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="tom" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 15 19:34:50 tom-hpenvy kernel: audit: type=1110 audit(1650065690.770:171): pid=9304 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 15 19:34:50 tom-hpenvy sudo[9304]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1000)
Apr 15 19:34:50 tom-hpenvy audit[9304]: USER_START pid=9304 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 15 19:34:50 tom-hpenvy kernel: audit: type=1105 audit(1650065690.774:172): pid=9304 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 15 19:34:50 tom-hpenvy sudo[9304]: pam_unix(sudo:session): session closed for user root
Apr 15 19:34:50 tom-hpenvy audit[9304]: USER_END pid=9304 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 15 19:34:50 tom-hpenvy audit[9304]: CRED_DISP pid=9304 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 15 19:34:50 tom-hpenvy kernel: audit: type=1106 audit(1650065690.800:173): pid=9304 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 15 19:34:50 tom-hpenvy kernel: audit: type=1104 audit(1650065690.800:174): pid=9304 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 15 19:35:04 tom-hpenvy dbus-daemon[733]: [session uid=1000 pid=733] Activating service name='org.gnome.Nautilus' requested by ':1.18' (uid=1000 pid=861 comm="/usr/bin/plasmashell")
Apr 15 19:35:04 tom-hpenvy kwin_x11[787]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 62869, resource id: 31457771, major code: 18 (ChangeProperty), minor code: 0
Apr 15 19:35:04 tom-hpenvy dbus-daemon[733]: [session uid=1000 pid=733] Successfully activated service 'org.gnome.Nautilus'
Apr 15 19:35:04 tom-hpenvy nautilus[9314]: Using GtkSettings:gtk-application-prefer-dark-theme together with HdyStyleManager is unsupported. Please use HdyStyleManager:color-scheme instead.
Apr 15 19:35:04 tom-hpenvy at-spi-bus-launcher[9327]: dbus-daemon[9327]: Activating service name='org.a11y.atspi.Registry' requested by ':1.0' (uid=1000 pid=9314 comm="/usr/bin/nautilus --gapplication-service")
Apr 15 19:35:04 tom-hpenvy at-spi-bus-launcher[9327]: dbus-daemon[9327]: Successfully activated service 'org.a11y.atspi.Registry'
Apr 15 19:35:04 tom-hpenvy at-spi-bus-launcher[9330]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
Apr 15 19:35:04 tom-hpenvy dbus-daemon[550]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.286' (uid=1000 pid=9314 comm="/usr/bin/nautilus --gapplication-service")
Apr 15 19:35:04 tom-hpenvy audit: BPF prog-id=26 op=LOAD
Apr 15 19:35:04 tom-hpenvy audit: BPF prog-id=27 op=LOAD
Apr 15 19:35:04 tom-hpenvy audit: BPF prog-id=28 op=LOAD
Apr 15 19:35:04 tom-hpenvy systemd[1]: Starting Hostname Service...
Apr 15 19:35:04 tom-hpenvy kernel: audit: type=1334 audit(1650065704.970:175): prog-id=26 op=LOAD
Apr 15 19:35:04 tom-hpenvy kernel: audit: type=1334 audit(1650065704.970:176): prog-id=27 op=LOAD
Apr 15 19:35:04 tom-hpenvy kernel: audit: type=1334 audit(1650065704.970:177): prog-id=28 op=LOAD
Apr 15 19:35:05 tom-hpenvy dbus-daemon[550]: [system] Successfully activated service 'org.freedesktop.hostname1'
Apr 15 19:35:05 tom-hpenvy systemd[1]: Started Hostname Service.
Apr 15 19:35:05 tom-hpenvy audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 15 19:35:05 tom-hpenvy kernel: audit: type=1130 audit(1650065705.004:178): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 15 19:35:12 tom-hpenvy kwin_x11[787]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 65234, resource id: 48234506, major code: 15 (QueryTree), minor code: 0
Apr 15 19:35:15 tom-hpenvy plasmashell[861]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:366: Unable to assign [undefined] to QString
Apr 15 19:35:15 tom-hpenvy kwin_x11[787]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 369, resource id: 31457780, major code: 18 (ChangeProperty), minor code: 0
Apr 15 19:35:15 tom-hpenvy systemd[711]: Started System Settings - System Settings.
Apr 15 19:35:15 tom-hpenvy systemsettings[9346]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ApplicationItem.qml:151:9: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 13. Use 'sequences: [ <key> ]' to bind to all of them.
Apr 15 19:35:15 tom-hpenvy systemsettings[9346]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ApplicationItem.qml:147:9: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 14. Use 'sequences: [ <key> ]' to bind to all of them.
Apr 15 19:35:15 tom-hpenvy systemsettings[9346]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
Apr 15 19:35:15 tom-hpenvy kwin_x11[787]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 999, resource id: 56623116, major code: 18 (ChangeProperty), minor code: 0
Apr 15 19:35:15 tom-hpenvy plasma-discover[9377]: qrc:/qml/DiscoverWindow.qml:116:19: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 15. Use 'sequences: [ <key> ]' to bind to all of them.
Apr 15 19:35:15 tom-hpenvy plasma-discover[9377]: QObject::startTimer: Timers cannot have negative intervals
Apr 15 19:35:15 tom-hpenvy plasma-discover[9377]: file:///usr/lib/qt/qml/org/kde/kirigami.2/private/globaltoolbar/ToolBarPageHeader.qml:41:13: Unable to assign [undefined] to double
Apr 15 19:35:15 tom-hpenvy plasma-discover[9377]: file:///usr/lib/qt/qml/org/kde/kirigami.2/private/globaltoolbar/ToolBarPageHeader.qml:40:13: Unable to assign [undefined] to double
Apr 15 19:35:15 tom-hpenvy plasma-discover[9377]: file:///usr/lib/qt/qml/org/kde/kirigami.2/private/globaltoolbar/ToolBarPageHeader.qml:39:13: Unable to assign [undefined] to double
Apr 15 19:35:15 tom-hpenvy plasma-discover[9377]: file:///usr/lib/qt/qml/org/kde/kirigami.2/private/globaltoolbar/ToolBarPageHeader.qml:38:13: Unable to assign [undefined] to bool
Apr 15 19:35:15 tom-hpenvy kwin_x11[787]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1390, resource id: 10860898, major code: 3 (GetWindowAttributes), minor code: 0
Apr 15 19:35:15 tom-hpenvy kwin_x11[787]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1413, resource id: 54525978, major code: 18 (ChangeProperty), minor code: 0
Apr 15 19:35:17 tom-hpenvy kwin_x11[787]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2174, resource id: 31457786, major code: 18 (ChangeProperty), minor code: 0
Apr 15 19:35:17 tom-hpenvy systemd[711]: Started Firefox - Web Browser.
Apr 15 19:35:18 tom-hpenvy kwin_x11[787]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2829, resource id: 10860993, major code: 3 (GetWindowAttributes), minor code: 0
Apr 15 19:35:18 tom-hpenvy kwin_x11[787]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2830, resource id: 10860993, major code: 14 (GetGeometry), minor code: 0
Apr 15 19:35:25 tom-hpenvy kwin_x11[787]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5700, resource id: 52428981, major code: 18 (ChangeProperty), minor code: 0
Apr 15 19:35:25 tom-hpenvy systemd[711]: app-systemsettings-d0f463c660da4d11aaa71c5d530c081f.scope: Consumed 1.201s CPU time.
Apr 15 19:35:25 tom-hpenvy kwin_x11[787]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5718, resource id: 31457787, major code: 18 (ChangeProperty), minor code: 0
Apr 15 19:35:35 tom-hpenvy systemd[1]: systemd-hostnamed.service: Deactivated successfully.
Apr 15 19:35:35 tom-hpenvy audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 15 19:35:35 tom-hpenvy kernel: audit: type=1131 audit(1650065735.057:179): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 15 19:35:35 tom-hpenvy audit: BPF prog-id=0 op=UNLOAD
Apr 15 19:35:35 tom-hpenvy kernel: audit: type=1334 audit(1650065735.177:180): prog-id=0 op=UNLOAD
Apr 15 19:35:35 tom-hpenvy kernel: audit: type=1334 audit(1650065735.177:181): prog-id=0 op=UNLOAD
Apr 15 19:35:35 tom-hpenvy kernel: audit: type=1334 audit(1650065735.177:182): prog-id=0 op=UNLOAD
Apr 15 19:41:59 tom-hpenvy kwin_x11[787]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 36873, resource id: 56623148, major code: 15 (QueryTree), minor code: 0
Apr 15 19:42:00 tom-hpenvy kwin_x11[787]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 37066, resource id: 31457788, major code: 18 (ChangeProperty), minor code: 0
Apr 15 19:42:00 tom-hpenvy systemd[711]: app-firefox-d84c23e08f2542ee82c6db50b1b1b96d.scope: Consumed 6min 5.943s CPU time.
Apr 15 19:43:02 tom-hpenvy dbus-daemon[550]: [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.26' (uid=1000 pid=864 comm="/usr/lib/org_kde_powerdevil") (using servicehelper)
Apr 15 19:43:02 tom-hpenvy dbus-daemon[550]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
Apr 15 19:43:32 tom-hpenvy dbus-daemon[550]: [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.26' (uid=1000 pid=864 comm="/usr/lib/org_kde_powerdevil") (using servicehelper)
Apr 15 19:43:32 tom-hpenvy dbus-daemon[550]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
Apr 15 19:44:02 tom-hpenvy dbus-daemon[550]: [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.26' (uid=1000 pid=864 comm="/usr/lib/org_kde_powerdevil") (using servicehelper)
Apr 15 19:44:02 tom-hpenvy dbus-daemon[550]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
Apr 15 19:47:02 tom-hpenvy kscreenlocker_greet[10341]: Qt: Session management error: networkIdsList argument is NULL
Apr 15 19:47:02 tom-hpenvy kscreenlocker_greet[10341]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "en_US" . Search paths ("/usr/share/qt/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
Apr 15 19:47:02 tom-hpenvy kscreenlocker_greet[10341]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/UserList.qml:42:9: Unable to assign [undefined] to bool
Apr 15 20:29:24 tom-hpenvy wpa_supplicant[599]: wlan0: WPA: Group rekeying completed with 00:7f:28:bb:c6:cc [GTK=CCMP]
Apr 15 20:40:52 tom-hpenvy dbus-daemon[550]: [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.26' (uid=1000 pid=864 comm="/usr/lib/org_kde_powerdevil") (using servicehelper)
Apr 15 20:40:52 tom-hpenvy dbus-daemon[550]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
Log 3: Crash around 11:30
Apr 15 10:33:04 tom-hpenvy kernel: audit: type=1106 audit(1650033184.356:101): pid=1930 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 15 10:33:04 tom-hpenvy kernel: audit: type=1104 audit(1650033184.356:102): pid=1930 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 15 10:33:04 tom-hpenvy audit[1930]: CRED_DISP pid=1930 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 15 10:34:27 tom-hpenvy dbus-daemon[546]: [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.26' (uid=1000 pid=853 comm="/usr/lib/org_kde_powerdevil") (using servicehelper)
Apr 15 10:34:27 tom-hpenvy dbus-daemon[546]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
Apr 15 10:34:57 tom-hpenvy dbus-daemon[546]: [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.26' (uid=1000 pid=853 comm="/usr/lib/org_kde_powerdevil") (using servicehelper)
Apr 15 10:34:57 tom-hpenvy dbus-daemon[546]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
Apr 15 10:35:27 tom-hpenvy dbus-daemon[546]: [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.26' (uid=1000 pid=853 comm="/usr/lib/org_kde_powerdevil") (using servicehelper)
Apr 15 10:35:27 tom-hpenvy dbus-daemon[546]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
Apr 15 10:36:54 tom-hpenvy systemd[704]: Starting EOS update notifier service...
Apr 15 10:37:02 tom-hpenvy eos-update-notifier[1955]: Checking for updates ...
Apr 15 10:37:05 tom-hpenvy eos-update-notifier[1955]: Checking AUR updates ...
Apr 15 10:37:06 tom-hpenvy systemd[704]: Finished EOS update notifier service.
Apr 15 10:38:27 tom-hpenvy kscreenlocker_greet[2025]: Qt: Session management error: networkIdsList argument is NULL
Apr 15 10:38:27 tom-hpenvy kscreenlocker_greet[2025]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/VirtualKeyboard.qml:8:1: module "QtQuick.VirtualKeyboard" is not installed
Apr 15 10:38:27 tom-hpenvy kscreenlocker_greet[2025]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/UserList.qml:42:9: Unable to assign [undefined] to bool
Apr 15 10:45:54 tom-hpenvy systemd[1]: Starting Cleanup of Temporary Directories...
Apr 15 10:45:54 tom-hpenvy systemd[1]: systemd-tmpfiles-clean.service: Deactivated successfully.
Apr 15 10:45:54 tom-hpenvy systemd[1]: Finished Cleanup of Temporary Directories.
Apr 15 10:45:54 tom-hpenvy audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 15 10:45:54 tom-hpenvy audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 15 10:45:54 tom-hpenvy kernel: audit: type=1130 audit(1650033954.589:103): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 15 10:45:54 tom-hpenvy kernel: audit: type=1131 audit(1650033954.589:104): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 15 11:05:20 tom-hpenvy dbus-daemon[546]: [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.26' (uid=1000 pid=853 comm="/usr/lib/org_kde_powerdevil") (using servicehelper)
Apr 15 11:05:20 tom-hpenvy dbus-daemon[546]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
Apr 15 11:05:26 tom-hpenvy dbus-daemon[546]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.89' (uid=1000 pid=2085 comm="kcheckpass -m classic -S 27")
Apr 15 11:05:26 tom-hpenvy dbus-daemon[546]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Apr 15 11:05:26 tom-hpenvy kcheckpass[2085]: pam_systemd_home(kde:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Apr 15 11:05:26 tom-hpenvy audit[2087]: USER_AUTH pid=2087 uid=1000 auid=1000 ses=2 msg='op=PAM:unix_chkpwd acct="tom" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
Apr 15 11:05:26 tom-hpenvy kernel: audit: type=1100 audit(1650035126.642:105): pid=2087 uid=1000 auid=1000 ses=2 msg='op=PAM:unix_chkpwd acct="tom" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
Apr 15 11:05:26 tom-hpenvy kwin_x11[780]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 22638, resource id: 48234550, major code: 18 (ChangeProperty), minor code: 0
Apr 15 11:06:17 tom-hpenvy plasmashell[849]: kf.sonnet.core: No language dictionaries for the language: "en_US" trying to load en_US as default
Apr 15 11:06:18 tom-hpenvy systemd[704]: Started Firefox - Web Browser.
Apr 15 11:06:19 tom-hpenvy kwin_x11[780]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 25005, resource id: 10487603, major code: 3 (GetWindowAttributes), minor code: 0
Apr 15 11:06:19 tom-hpenvy kwin_x11[780]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 25006, resource id: 10487603, major code: 14 (GetGeometry), minor code: 0
Apr 15 11:06:31 tom-hpenvy kernel: atkbd serio0: Unknown key pressed (translated set 2, code 0xab on isa0060/serio0).
Apr 15 11:06:31 tom-hpenvy kernel: atkbd serio0: Use 'setkeycodes e02b <keycode>' to make it known.
Apr 15 11:06:31 tom-hpenvy kernel: atkbd serio0: Unknown key released (translated set 2, code 0xab on isa0060/serio0).
Apr 15 11:06:31 tom-hpenvy dbus-daemon[546]: [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.26' (uid=1000 pid=853 comm="/usr/lib/org_kde_powerdevil") (using servicehelper)
Apr 15 11:06:31 tom-hpenvy dbus-daemon[546]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
Apr 15 11:07:12 tom-hpenvy kwin_x11[780]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 41799, resource id: 48234540, major code: 15 (QueryTree), minor code: 0
Apr 15 11:07:12 tom-hpenvy kwin_x11[780]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 42013, resource id: 25166096, major code: 18 (ChangeProperty), minor code: 0
Apr 15 11:07:13 tom-hpenvy systemd[704]: app-firefox-78a2df7b481349b9a1e8a83808913754.scope: Consumed 49.279s CPU time.
Apr 15 11:07:15 tom-hpenvy kernel: atkbd serio0: Unknown key pressed (translated set 2, code 0xab on isa0060/serio0).
Apr 15 11:07:15 tom-hpenvy kernel: atkbd serio0: Use 'setkeycodes e02b <keycode>' to make it known.
Apr 15 11:07:15 tom-hpenvy kernel: atkbd serio0: Unknown key released (translated set 2, code 0xab on isa0060/serio0).
Apr 15 11:07:15 tom-hpenvy dbus-daemon[546]: [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.26' (uid=1000 pid=853 comm="/usr/lib/org_kde_powerdevil") (using servicehelper)
Apr 15 11:07:15 tom-hpenvy dbus-daemon[546]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
Apr 15 11:07:16 tom-hpenvy kernel: atkbd serio0: Unknown key pressed (translated set 2, code 0xab on isa0060/serio0).
Apr 15 11:07:16 tom-hpenvy kernel: atkbd serio0: Use 'setkeycodes e02b <keycode>' to make it known.
Apr 15 11:07:16 tom-hpenvy kernel: atkbd serio0: Unknown key released (translated set 2, code 0xab on isa0060/serio0).
Apr 15 11:07:17 tom-hpenvy pipewire-pulse[1124]: mod.protocol-pulse: client 0x557318c2ddd0 [libcanberra]: ERROR command:18 (PLAY_SAMPLE) tag:16 error:25 (Input/output error)
Apr 15 11:07:23 tom-hpenvy kwin_x11[780]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 44375, resource id: 25166103, major code: 14 (GetGeometry), minor code: 0
Apr 15 11:08:33 tom-hpenvy dbus-daemon[546]: [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.26' (uid=1000 pid=853 comm="/usr/lib/org_kde_powerdevil") (using servicehelper)
Apr 15 11:08:33 tom-hpenvy dbus-daemon[546]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
Apr 15 11:09:03 tom-hpenvy dbus-daemon[546]: [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.26' (uid=1000 pid=853 comm="/usr/lib/org_kde_powerdevil") (using servicehelper)
Apr 15 11:09:03 tom-hpenvy dbus-daemon[546]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
Apr 15 11:09:33 tom-hpenvy dbus-daemon[546]: [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.26' (uid=1000 pid=853 comm="/usr/lib/org_kde_powerdevil") (using servicehelper)
Apr 15 11:09:33 tom-hpenvy dbus-daemon[546]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
Apr 15 11:12:33 tom-hpenvy kscreenlocker_greet[2702]: Qt: Session management error: networkIdsList argument is NULL
Apr 15 11:12:33 tom-hpenvy kscreenlocker_greet[2702]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/VirtualKeyboard.qml:8:1: module "QtQuick.VirtualKeyboard" is not installed
Apr 15 11:12:34 tom-hpenvy kscreenlocker_greet[2702]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/UserList.qml:42:9: Unable to assign [undefined] to bool
I’ll make sure you noticed that it has to be disabled on every boot?
It will not survive beyond reboot.
automating_disabling_of_c6
Did it make a difference? Does it do the same if you are on an ISO CD?
There are no clear signs of the actual failure or source of crash.
This kind of issue needs long time to track down. Maybe a hardware problem but no sign of what HW exactly, motherboard, disk, network card…
If it is caused from a software function, it should have a pattern, like triggering in the same time left in idle, or similar.
High temperature because of dirt in cooler fans is a common problem, or a failing disk.
That’s only be personal experience :person_shrugging: .
Edit: You may try other kernels.
I agree with you on this. The newer Ryzen Cpu 5700U series is very reliable and shouldn’t not give this kind of trouble.
@twx
You don’t have settings changed in the Bios?
@EOS Thank you, yes so far I’ve been manually disabling c6 via terminal after every boot. I switched to KDE Plasma (no tweaks/adjustments) with X11 from Gnome, and it seemed to help but not entirely.
@petsam @ricklinux I see, thank you for your insights. I don’t have anything changed in the BIOS from the manufacturer defaults except for secure boot (disabled).
Interestingly, I read some posts about similar issues on the Manjaro forums and tried adding a kernel parameter acpi_osi='Windows 2019' based on this post. This together with the disabled c6 state allows the laptop to consistently idle (tested up to 3 hours) without crashing/rebooting.
Unfortunately, ~50% of the time after returning from idle it will freeze + reboot as before after launching an application (e.g. system settings, Firefox); so far tested on most recent mainline kernel + LTS kernel. i.e. The typical observed behavior is:
  1. Turn on laptop, use for 10-30 minutes without any problems
  2. Close all applications except terminal, leave idle for 1.5-3 hours
  3. Wake up laptop from idle, use for 10-30 minutes without any problems
  4. Repeat step 2
  5. Wake up laptop from idle, launch system settings/Firefox, no problems for ~30 sec then freeze + reboot
I’ve stored some journalctl logs from these crashes and only see some errors/warnings related to plasma and org.freedesktop.home. From doing some searches online, it seems that these types of warnings are typically harmless, but I’m not sure. Would it help to reinstall EndeavorOS with just XFCE or some other DE?
Log 1: crash around 18:30
Apr 17 16:33:58 tom-hpenvy audit[7113]: USER_ACCT pid=7113 uid=1001 auid=1001 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="tom2" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 17 16:33:58 tom-hpenvy sudo[7113]:     tom2 : TTY=pts/1 ; PWD=/home/tom2 ; USER=root ; COMMAND=/usr/bin/zenstates --list
Apr 17 16:33:58 tom-hpenvy audit[7113]: CRED_REFR pid=7113 uid=1001 auid=1001 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 17 16:33:58 tom-hpenvy sudo[7113]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
Apr 17 16:33:58 tom-hpenvy audit[7113]: USER_START pid=7113 uid=1001 auid=1001 ses=2 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 17 16:33:58 tom-hpenvy kernel: audit: type=1100 audit(1650227638.772:138): pid=7113 uid=1001 auid=1001 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="tom2" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 17 16:33:58 tom-hpenvy kernel: audit: type=1101 audit(1650227638.782:139): pid=7113 uid=1001 auid=1001 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="tom2" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 17 16:33:58 tom-hpenvy kernel: audit: type=1110 audit(1650227638.782:140): pid=7113 uid=1001 auid=1001 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 17 16:33:58 tom-hpenvy kernel: audit: type=1105 audit(1650227638.782:141): pid=7113 uid=1001 auid=1001 ses=2 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 17 16:33:58 tom-hpenvy sudo[7113]: pam_unix(sudo:session): session closed for user root
Apr 17 16:33:58 tom-hpenvy audit[7113]: USER_END pid=7113 uid=1001 auid=1001 ses=2 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 17 16:33:58 tom-hpenvy audit[7113]: CRED_DISP pid=7113 uid=1001 auid=1001 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 17 16:33:58 tom-hpenvy kernel: audit: type=1106 audit(1650227638.812:142): pid=7113 uid=1001 auid=1001 ses=2 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 17 16:33:58 tom-hpenvy kernel: audit: type=1104 audit(1650227638.812:143): pid=7113 uid=1001 auid=1001 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 17 16:33:59 tom-hpenvy plasmashell[831]: kf.sonnet.core: No language dictionaries for the language: "en_US" trying to load en_US as default
Apr 17 16:34:00 tom-hpenvy systemd[678]: Started systemsettings.
Apr 17 16:34:01 tom-hpenvy systemsettings[7115]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ApplicationItem.qml:151:9: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 13. Use 'sequences: [ <key> ]' to bind to all of them.
Apr 17 16:34:01 tom-hpenvy systemsettings[7115]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ApplicationItem.qml:147:9: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 14. Use 'sequences: [ <key> ]' to bind to all of them.
Apr 17 16:34:01 tom-hpenvy systemsettings[7115]: QFSFileEngine::open: No file name specified
Apr 17 16:34:01 tom-hpenvy systemsettings[7115]: kf.coreaddons.desktopparser: Error: Failed to open  ""
Apr 17 16:34:01 tom-hpenvy systemsettings[7115]: QFileDevice::seek: IODevice is not open
Apr 17 16:34:01 tom-hpenvy systemsettings[7115]: qml: The item SubCategoryPage_QMLTYPE_83(0x561ecd4ff920) is already in the PageRow
Apr 17 16:34:03 tom-hpenvy systemsettings[7115]: qml: The item SubCategoryPage_QMLTYPE_83(0x561ecd4ff920) is already in the PageRow
Apr 17 16:34:07 tom-hpenvy kwin_x11[754]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 30046, resource id: 48234643, major code: 18 (ChangeProperty), minor code: 0
Apr 17 16:34:07 tom-hpenvy systemd[678]: app-systemsettings-2c715cffb1f144bc8844af192784c40e.scope: Consumed 1.017s CPU time.
Apr 17 16:35:11 tom-hpenvy dbus-daemon[469]: [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.26' (uid=1001 pid=832 comm="/usr/lib/org_kde_powerdevil") (using servicehelper)
Apr 17 16:35:11 tom-hpenvy dbus-daemon[469]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
Apr 17 16:35:41 tom-hpenvy dbus-daemon[469]: [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.26' (uid=1001 pid=832 comm="/usr/lib/org_kde_powerdevil") (using servicehelper)
Apr 17 16:35:41 tom-hpenvy dbus-daemon[469]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
Apr 17 16:36:11 tom-hpenvy dbus-daemon[469]: [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.26' (uid=1001 pid=832 comm="/usr/lib/org_kde_powerdevil") (using servicehelper)
Apr 17 16:36:11 tom-hpenvy dbus-daemon[469]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
Apr 17 16:39:12 tom-hpenvy kscreenlocker_greet[7177]: Qt: Session management error: networkIdsList argument is NULL
Apr 17 16:39:12 tom-hpenvy kscreenlocker_greet[7177]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "en_US" . Search paths ("/usr/share/qt/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
Apr 17 16:39:12 tom-hpenvy kscreenlocker_greet[7177]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/UserList.qml:42:9: Unable to assign [undefined] to bool
Apr 17 17:29:24 tom-hpenvy wpa_supplicant[547]: wlan0: WPA: Group rekeying completed with 00:7f:28:bb:c6:cc [GTK=CCMP]
Apr 17 18:01:53 tom-hpenvy audit: BPF prog-id=29 op=LOAD
Apr 17 18:01:53 tom-hpenvy systemd[1]: Starting Update locate database...
Apr 17 18:01:53 tom-hpenvy kernel: audit: type=1334 audit(1650232913.708:144): prog-id=29 op=LOAD
Apr 17 18:01:54 tom-hpenvy systemd[1]: updatedb.service: Deactivated successfully.
Apr 17 18:01:54 tom-hpenvy systemd[1]: Finished Update locate database.
Apr 17 18:01:54 tom-hpenvy audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=updatedb comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 17 18:01:54 tom-hpenvy audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=updatedb comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 17 18:01:54 tom-hpenvy kernel: audit: type=1130 audit(1650232914.428:145): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=updatedb comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 17 18:01:54 tom-hpenvy kernel: audit: type=1131 audit(1650232914.428:146): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=updatedb comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 17 18:01:54 tom-hpenvy audit: BPF prog-id=0 op=UNLOAD
Apr 17 18:01:54 tom-hpenvy kernel: audit: type=1334 audit(1650232914.668:147): prog-id=0 op=UNLOAD
Apr 17 18:27:42 tom-hpenvy dbus-daemon[469]: [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.26' (uid=1001 pid=832 comm="/usr/lib/org_kde_powerdevil") (using servicehelper)
Apr 17 18:27:42 tom-hpenvy dbus-daemon[469]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
Apr 17 18:27:46 tom-hpenvy dbus-daemon[469]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.252' (uid=1001 pid=7307 comm="kcheckpass -m classic -S 31")
Apr 17 18:27:46 tom-hpenvy dbus-daemon[469]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Apr 17 18:27:46 tom-hpenvy kcheckpass[7307]: pam_systemd_home(kde:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Apr 17 18:27:46 tom-hpenvy audit[7309]: USER_AUTH pid=7309 uid=1001 auid=1001 ses=2 msg='op=PAM:unix_chkpwd acct="tom2" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
Apr 17 18:27:46 tom-hpenvy kernel: audit: type=1100 audit(1650234466.547:148): pid=7309 uid=1001 auid=1001 ses=2 msg='op=PAM:unix_chkpwd acct="tom2" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
Apr 17 18:27:46 tom-hpenvy kwin_x11[754]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 37572, resource id: 48234550, major code: 18 (ChangeProperty), minor code: 0
Apr 17 18:28:15 tom-hpenvy dbus-daemon[469]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.253' (uid=0 pid=7321 comm="sudo zenstates --list")
Apr 17 18:28:15 tom-hpenvy dbus-daemon[469]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Apr 17 18:28:17 tom-hpenvy audit[7321]: USER_AUTH pid=7321 uid=1001 auid=1001 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="tom2" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 17 18:28:17 tom-hpenvy audit[7321]: USER_ACCT pid=7321 uid=1001 auid=1001 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="tom2" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Log 2: crash around 00:27
Apr 17 23:04:41 tom-hpenvy dbus-daemon[454]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
Apr 17 23:04:45 tom-hpenvy dbus-daemon[454]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.165' (uid=1001 pid=4785 comm="kcheckpass -m classic -S 30")
Apr 17 23:04:45 tom-hpenvy dbus-daemon[454]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Apr 17 23:04:45 tom-hpenvy kcheckpass[4785]: pam_systemd_home(kde:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Apr 17 23:04:45 tom-hpenvy audit[4787]: USER_AUTH pid=4787 uid=1001 auid=1001 ses=2 msg='op=PAM:unix_chkpwd acct="tom2" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
Apr 17 23:04:45 tom-hpenvy kernel: audit: type=1100 audit(1650251085.655:107): pid=4787 uid=1001 auid=1001 ses=2 msg='op=PAM:unix_chkpwd acct="tom2" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
Apr 17 23:04:45 tom-hpenvy kwin_x11[770]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 20846, resource id: 48234550, major code: 18 (ChangeProperty), minor code: 0
Apr 17 23:04:55 tom-hpenvy plasmashell[848]: kf.sonnet.core: No language dictionaries for the language: "en_US" trying to load en_US as default
Apr 17 23:04:56 tom-hpenvy systemd[693]: Started System Settings - System Settings.
Apr 17 23:04:56 tom-hpenvy systemsettings[4791]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ApplicationItem.qml:151:9: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 13. Use 'sequences: [ <key> ]' to bind to all of them.
Apr 17 23:04:56 tom-hpenvy systemsettings[4791]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ApplicationItem.qml:147:9: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 14. Use 'sequences: [ <key> ]' to bind to all of them.
Apr 17 23:04:56 tom-hpenvy systemsettings[4791]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
Apr 17 23:04:56 tom-hpenvy kwin_x11[770]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 24192, resource id: 52428812, major code: 18 (ChangeProperty), minor code: 0
Apr 17 23:04:56 tom-hpenvy plasma-discover[4820]: qrc:/qml/DiscoverWindow.qml:116:19: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 15. Use 'sequences: [ <key> ]' to bind to all of them.
Apr 17 23:04:56 tom-hpenvy plasma-discover[4820]: QObject::startTimer: Timers cannot have negative intervals
Apr 17 23:04:57 tom-hpenvy plasma-discover[4820]: file:///usr/lib/qt/qml/org/kde/kirigami.2/private/globaltoolbar/ToolBarPageHeader.qml:41:13: Unable to assign [undefined] to double
Apr 17 23:04:57 tom-hpenvy plasma-discover[4820]: file:///usr/lib/qt/qml/org/kde/kirigami.2/private/globaltoolbar/ToolBarPageHeader.qml:40:13: Unable to assign [undefined] to double
Apr 17 23:04:57 tom-hpenvy plasma-discover[4820]: file:///usr/lib/qt/qml/org/kde/kirigami.2/private/globaltoolbar/ToolBarPageHeader.qml:39:13: Unable to assign [undefined] to double
Apr 17 23:04:57 tom-hpenvy plasma-discover[4820]: file:///usr/lib/qt/qml/org/kde/kirigami.2/private/globaltoolbar/ToolBarPageHeader.qml:38:13: Unable to assign [undefined] to bool
Apr 17 23:04:57 tom-hpenvy kwin_x11[770]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 24248, resource id: 50331669, major code: 18 (ChangeProperty), minor code: 0
Apr 17 23:04:57 tom-hpenvy plasmashell[848]: kf.sonnet.core: No language dictionaries for the language: "en_US" trying to load en_US as default
Apr 17 23:04:58 tom-hpenvy systemd[693]: Started Firefox - Web Browser.
Apr 17 23:04:58 tom-hpenvy kwin_x11[770]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 25316, resource id: 31457722, major code: 18 (ChangeProperty), minor code: 0
Apr 17 23:05:26 tom-hpenvy kwin_x11[770]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 37354, resource id: 52428844, major code: 15 (QueryTree), minor code: 0
Apr 17 23:05:27 tom-hpenvy kwin_x11[770]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 37596, resource id: 31457723, major code: 18 (ChangeProperty), minor code: 0
Apr 17 23:05:27 tom-hpenvy systemd[693]: app-firefox-a3bd943722df4c579b3d7605a6ff0cc4.scope: Consumed 50.650s CPU time.
Apr 17 23:05:28 tom-hpenvy kwin_x11[770]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 37763, resource id: 48234654, major code: 18 (ChangeProperty), minor code: 0
Apr 17 23:05:28 tom-hpenvy systemd[693]: app-systemsettings-d7bad7461a9c48a5ba17f8c3110e45b6.scope: Consumed 1.307s CPU time.
Apr 17 23:05:28 tom-hpenvy kwin_x11[770]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 37772, resource id: 31457724, major code: 18 (ChangeProperty), minor code: 0
Apr 17 23:05:28 tom-hpenvy plasmashell[848]: kf.sonnet.core: No language dictionaries for the language: "en_US" trying to load en_US as default
Apr 17 23:05:29 tom-hpenvy systemd[693]: Started Firefox - Web Browser.
Apr 17 23
:06:58 tom-hpenvy plasmashell[848]: kf.sonnet.core: No language dictionaries for the language: "en_US" trying to load en_US as default
Apr 17 23:06:58 tom-hpenvy plasmashell[848]: kf.sonnet.core: No language dictionaries for the language: "en_US"
Apr 17 23:06:59 tom-hpenvy systemd[693]: Started System Settings - System Settings.
Apr 17 23:06:59 tom-hpenvy systemsettings[6362]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ApplicationItem.qml:151:9: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 13. Use 'sequences: [ <key> ]' to bind to all of them.
Apr 17 23:06:59 tom-hpenvy systemsettings[6362]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ApplicationItem.qml:147:9: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 14. Use 'sequences: [ <key> ]' to bind to all of them.
Apr 17 23:06:59 tom-hpenvy systemsettings[6362]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
Apr 17 23:06:59 tom-hpenvy kwin_x11[770]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 9792, resource id: 56623116, major code: 18 (ChangeProperty), minor code: 0
Apr 17 23:07:00 tom-hpenvy plasma-discover[6391]: qrc:/qml/DiscoverWindow.qml:116:19: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 15. Use 'sequences: [ <key> ]' to bind to all of them.
Apr 17 23:07:00 tom-hpenvy plasma-discover[6391]: QObject::startTimer: Timers cannot have negative intervals
Apr 17 23:07:00 tom-hpenvy plasma-discover[6391]: file:///usr/lib/qt/qml/org/kde/kirigami.2/private/globaltoolbar/ToolBarPageHeader.qml:41:13: Unable to assign [undefined] to double
Apr 17 23:07:00 tom-hpenvy plasma-discover[6391]: file:///usr/lib/qt/qml/org/kde/kirigami.2/private/globaltoolbar/ToolBarPageHeader.qml:40:13: Unable to assign [undefined] to double
Apr 17 23:07:00 tom-hpenvy plasma-discover[6391]: file:///usr/lib/qt/qml/org/kde/kirigami.2/private/globaltoolbar/ToolBarPageHeader.qml:39:13: Unable to assign [undefined] to double
Apr 17 23:07:00 tom-hpenvy plasma-discover[6391]: file:///usr/lib/qt/qml/org/kde/kirigami.2/private/globaltoolbar/ToolBarPageHeader.qml:38:13: Unable to assign [undefined] to bool
Apr 17 23:07:00 tom-hpenvy kwin_x11[770]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 9886, resource id: 54525973, major code: 18 (ChangeProperty), minor code: 0
Apr 17 23:07:02 tom-hpenvy kwin_x11[770]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 11106, resource id: 52428958, major code: 18 (ChangeProperty), minor code: 0
Apr 17 23:07:02 tom-hpenvy systemd[693]: app-systemsettings-98b881a860e44c2aa4b250f440b8658d.scope: Consumed 1.129s CPU time.
Apr 17 23:07:02 tom-hpenvy kwin_x11[770]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 11116, resource id: 31457761, major code: 18 (ChangeProperty), minor code: 0
Apr 17 23:07:03 tom-hpenvy kwin_x11[770]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 11734, resource id: 10487164, major code: 3 (GetWindowAttributes), minor code: 0
Apr 17 23:07:03 tom-hpenvy kwin_x11[770]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 11735, resource id: 10487164, major code: 14 (GetGeometry), minor code: 0
Apr 17 23:07:03 tom-hpenvy kwin_x11[770]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 11738, resource id: 10487164, major code: 3 (GetWindowAttributes), minor code: 0
Apr 17 23:07:03 tom-hpenvy kwin_x11[770]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 11739, resource id: 10487164, major code: 14 (GetGeometry), minor code: 0
Apr 17 23:08:45 tom-hpenvy kwin_x11[770]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 55921, resource id: 48234540, major code: 15 (QueryTree), minor code: 0
Apr 17 23:08:46 tom-hpenvy kwin_x11[770]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 56068, resource id: 31457766, major code: 18 (ChangeProperty), minor code: 0
Apr 17 23:08:46 tom-hpenvy plasmashell[848]: kf.sonnet.core: No language dictionaries for the language: "en_US" trying to load en_US as default
Apr 17 23:08:46 tom-hpenvy systemd[693]: app-firefox-6c032cde54b4467b9fe0ad901ef534d0.scope: Consumed 4min 4.764s CPU time.
Apr 17 23:08:47 tom-hpenvy systemd[693]: Started System Settings - System Settings.
Apr 17 23:08:47 tom-hpenvy systemsettings[7651]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ApplicationItem.qml:151:9: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 13. Use 'sequences: [ <key> ]' to bind to all of them.
Apr 17 23:08:47 tom-hpenvy systemsettings[7651]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ApplicationItem.qml:147:9: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 14. Use 'sequences: [ <key> ]' to bind to all of them.
Apr 17 23:08:47 tom-hpenvy systemsettings[7651]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
Apr 17 23:08:47 tom-hpenvy kwin_x11[770]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 57534, resource id: 52428812, major code: 18 (ChangeProperty), minor code: 0
Apr 17 23:08:47 tom-hpenvy plasma-discover[7681]: qrc:/qml/DiscoverWindow.qml:116:19: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 15. Use 'sequences: [ <key> ]' to bind to all of them.
Apr 17 23:08:47 tom-hpenvy plasma-discover[7681]: QObject::startTimer: Timers cannot have negative intervals
Apr 17 23:08:47 tom-hpenvy plasma-discover[7681]: file:///usr/lib/qt/qml/org/kde/kirigami.2/private/globaltoolbar/ToolBarPageHeader.qml:41:13: Unable to assign [undefined] to double
Apr 17 23:08:47 tom-hpenvy plasma-discover[7681]: file:///usr/lib/qt/qml/org/kde/kirigami.2/private/globaltoolbar/ToolBarPageHeader.qml:40:13: Unable to assign [undefined] to double
Apr 17 23:08:47 tom-hpenvy plasma-discover[7681]: file:///usr/lib/qt/qml/org/kde/kirigami.2/private/globaltoolbar/ToolBarPageHeader.qml:39:13: Unable to assign [undefined] to double
Apr 17 23:08:47 tom-hpenvy plasma-discover[7681]: file:///usr/lib/qt/qml/org/kde/kirigami.2/private/globaltoolbar/ToolBarPageHeader.qml:38:13: Unable to assign [undefined] to bool
Apr 17 23:08:47 tom-hpenvy kwin_x11[770]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 57598, resource id: 50331669, major code: 18 (ChangeProperty), minor code: 0
Apr 17 23:08:49 tom-hpenvy systemsettings[7651]: kf.coreaddons: "Could not load plugin from kcm_kaccounts: The shared library was not found."
Apr 17 23:08:49 tom-hpenvy systemsettings[7651]: kf.i18n: "0 instead of 1 arguments to message {Are you sure you wis...} supplied before conversion."
Apr 17 23:08:49 tom-hpenvy systemsettings[7651]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
Apr 17 23:08:49 tom-hpenvy systemsettings[7651]: file:///usr/share/kpackage/kcms/kcm_kaccounts/contents/ui/MessageBoxSheet.qml:38:17: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Apr 17 23:08:49 tom-hpenvy systemsettings[7651]: file:///usr/share/kpackage/kcms/kcm_kaccounts/contents/ui/Accounts.qml:87: ReferenceError: noAccountsLayout is not defined
Apr 17 23:08:49 tom-hpenvy systemsettings[7651]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ApplicationItem.qml:151:9: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 13. Use 'sequences: [ <key> ]' to bind to all of them.
Apr 17 23:08:49 tom-hpenvy systemsettings[7651]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ApplicationItem.qml:147:9: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 14. Use 'sequences: [ <key> ]' to bind to all of them.
Apr 17 23:08:50 tom-hpenvy kwin_x11[770]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 58020, resource id: 48234664, major code: 18 (ChangeProperty), minor code: 0
Apr 17 23:08:50 tom-hpenvy systemd[693]: app-systemsettings-ddcf75506f93431f878a7a3a0a055103.scope: Consumed 1.209s CPU time.
Apr 17 23:08:50 tom-hpenvy kwin_x11[770]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 58042, resource id: 31457781, major code: 18 (ChangeProperty), minor code: 0
Apr 17 23:08:55 tom-hpenvy dbus-daemon[454]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.237' (uid=0 pid=7740 comm="sudo journalctl -b-e")
Apr 17 23:08:55 tom-hpenvy dbus-daemon[454]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Apr 17 23:08:55 tom-hpenvy sudo[7740]: pam_systemd_home(sudo:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Apr 17 23:08:57 tom-hpenvy sudo[7740]: pam_unix(sudo:auth): conversation failed
Apr 17 23:08:57 tom-hpenvy audit[7740]: USER_AUTH pid=7740 uid=1001 auid=1001 ses=2 msg='op=PAM:authentication grantors=? acct="tom2" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=failed'
Apr 17 23:08:57 tom-hpenvy sudo[7740]: pam_unix(sudo:auth): auth could not identify password for [tom2]
Apr 17 23:08:57 tom-hpenvy kernel: audit: type=1100 audit(1650251337.061:108): pid=7740 uid=1001 auid=1001 ses=2 msg='op=PAM:authentication grantors=? acct="tom2" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=failed'
Apr 17 23:09:00 tom-hpenvy dbus-daemon[454]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.238' (uid=0 pid=7741 comm="sudo journalctl -b -e")
Apr 17 23:09:00 tom-hpenvy dbus-daemon[454]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Apr 17 23:09:00 tom-hpenvy sudo[7741]: pam_systemd_home(sudo:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Apr 17 23:09:03 tom-hpenvy audit[7741]: USER_AUTH pid=7741 uid=1001 auid=1001 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="tom2" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 17 23:09:03 tom-hpenvy audit[7741]: USER_ACCT pid=7741 uid=1001 auid=1001 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="tom2" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 17 23:09:03 tom-hpenvy sudo[7741]:     tom2 : TTY=pts/1 ; PWD=/home/tom2 ; USER=root ; COMMAND=/usr/bin/journalctl -b -e
Apr 17 23:09:03 tom-hpenvy audit[7741]: CRED_REFR pid=7741 uid=1001 auid=1001 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 17 23:09:03 tom-hpenvy sudo[7741]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
Apr 17 23:09:03 tom-hpenvy audit[7741]: USER_START pid=7741 uid=1001 auid=1001 ses=2 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 17 23:09:03 tom-hpenvy kernel: audit: type=1100 audit(1650251343.178:109): pid=7741 uid=1001 auid=1001 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="tom2" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 17 23:09:03 tom-hpenvy kernel: audit: type=1101 audit(1650251343.178:110): pid=7741 uid=1001 auid=1001 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="tom2" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 17 23:09:03 tom-hpenvy kernel: audit: type=1110 audit(1650251343.178:111): pid=7741 uid=1001 auid=1001 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 17 23:09:03 tom-hpenvy kernel: audit: type=1105 audit(1650251343.178:112): pid=7741 uid=1001 auid=1001 ses=2 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 17 23:09:13 tom-hpenvy audit[7741]: USER_END pid=7741 uid=1001 auid=1001 ses=2 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 17 23:09:13 tom-hpenvy audit[7741]: CRED_DISP pid=7741 uid=1001 auid=1001 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 17 23:09:13 tom-hpenvy sudo[7741]: pam_unix(sudo:session): session closed for user root
Apr 17 23:09:13 tom-hpenvy kernel: audit: type=1106 audit(1650251353.605:113): pid=7741 uid=1001 auid=1001 ses=2 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 17 23:09:13 tom-hpenvy kernel: audit: type=1104 audit(1650251353.605:114): pid=7741 uid=1001 auid=1001 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 17 23:09:19 tom-hpenvy dbus-daemon[454]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.239' (uid=0 pid=7746 comm="sudo zenstates --list")
Apr 17 23:09:19 tom-hpenvy audit[7746]: USER_ACCT pid=7746 uid=1001 auid=1001 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="tom2" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 17 23:09:19 tom-hpenvy dbus-daemon[454]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Apr 17 23:09:19 tom-hpenvy sudo[7746]: pam_systemd_home(sudo:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Apr 17 23:09:19 tom-hpenvy audit[7746]: CRED_REFR pid=7746 uid=1001 auid=1001 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 17 23:09:19 tom-hpenvy sudo[7746]:     tom2 : TTY=pts/1 ; PWD=/home/tom2 ; USER=root ; COMMAND=/usr/bin/zenstates --list
Apr 17 23:09:19 tom-hpenvy sudo[7746]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
Apr 17 23:09:19 tom-hpenvy audit[7746]: USER_START pid=7746 uid=1001 auid=1001 ses=2 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 17 23:09:19 tom-hpenvy kernel: audit: type=1101 audit(1650251359.348:115): pid=7746 uid=1001 auid=1001 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="tom2" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 17 23:09:19 tom-hpenvy kernel: audit: type=1110 audit(1650251359.348:116): pid=7746 uid=1001 auid=1001 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 17 23:09:19 tom-hpenvy kernel: audit: type=1105 audit(1650251359.348:117): pid=7746 uid=1001 auid=1001 ses=2 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 17 23:09:19 tom-hpenvy sudo[7746]: pam_unix(sudo:session): session closed for user root
Apr 17 23:09:19 tom-hpenvy audit[7746]: USER_END pid=7746 uid=1001 auid=1001 ses=2 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 17 23:09:19 tom-hpenvy audit[7746]: CRED_DISP pid=7746 uid=1001 auid=1001 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 17 23:09:19 tom-hpenvy kernel: audit: type=1106 audit(1650251359.375:118): pid=7746 uid=1001 auid=1001 ses=2 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 17 23:09:19 tom-hpenvy kernel: audit: type=1104 audit(1650251359.375:119): pid=7746 uid=1001 auid=1001 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Apr 17 23:09:37 tom-hpenvy kernel: atkbd serio0: Unknown key pressed (translated set 2, code 0xab on isa0060/serio0).
Apr 17 23:09:37 tom-hpenvy kernel: atkbd serio0: Use 'setkeycodes e02b <keycode>' to make it known.
Apr 17 23:09:37 tom-hpenvy kernel: atkbd serio0: Unknown key released (translated set 2, code 0xab on isa0060/serio0).
Apr 17 23:09:37 tom-hpenvy dbus-daemon[454]: [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.26' (uid=1001 pid=845 comm="/usr/lib/org_kde_powerdevil") (using servicehelper)
Apr 17 23:09:37 tom-hpenvy dbus-daemon[454]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
Apr 17 23:09:38 tom-hpenvy kernel: atkbd serio0: Unknown key pressed (translated set 2, code 0xab on isa0060/serio0).
Apr 17 23:09:38 tom-hpenvy kernel: atkbd serio0: Use 'setkeycodes e02b <keycode>' to make it known.
Apr 17 23:09:38 tom-hpenvy kernel: atkbd serio0: Unknown key released (translated set 2, code 0xab on isa0060/serio0).
Apr 17 23:09:39 tom-hpenvy kernel: atkbd serio0: Unknown key pressed (translated set 2, code 0xab on isa0060/serio0).
Apr 17 23:09:39 tom-hpenvy kernel: atkbd serio0: Use 'setkeycodes e02b <keycode>' to make it known.
Apr 17 23:09:39 tom-hpenvy kernel: atkbd serio0: Unknown key released (translated set 2, code 0xab on isa0060/serio0).
Apr 17 23:10:39 tom-hpenvy dbus-daemon[454]: [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.26' (uid=1001 pid=845 comm="/usr/lib/org_kde_powerdevil") (using servicehelper)
Apr 17 23:10:39 tom-hpenvy dbus-daemon[454]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
Apr 17 23:11:09 tom-hpenvy dbus-daemon[454]: [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.26' (uid=1001 pid=845 comm="/usr/lib/org_kde_powerdevil") (using servicehelper)
Apr 17 23:11:09 tom-hpenvy dbus-daemon[454]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
Apr 17 23:11:39 tom-hpenvy dbus-daemon[454]: [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.26' (uid=1001 pid=845 comm="/usr/lib/org_kde_powerdevil") (using servicehelper)
Apr 17 23:11:39 tom-hpenvy dbus-daemon[454]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
Apr 17 23:14:39 tom-hpenvy kscreenlocker_greet[7788]: Qt: Session management error: networkIdsList argument is NULL
Apr 17 23:14:39 tom-hpenvy kscreenlocker_greet[7788]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "en_US" . Search paths ("/usr/share/qt/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
Apr 17 23:14:39 tom-hpenvy kscreenlocker_greet[7788]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/UserList.qml:42:9: Unable to assign [undefined] to bool
Apr 17 23:29:24 tom-hpenvy wpa_supplicant[583]: wlan0: WPA: Group rekeying completed with 00:7f:28:bb:c6:cc [GTK=CCMP]
Apr 18 00:00:14 tom-hpenvy systemd[693]: Starting EOS update notifier service...
Apr 18 00:00:14 tom-hpenvy systemd[1]: Rotate log files was skipped because of a failed condition check (ConditionACPower=true).
Apr 18 00:00:14 tom-hpenvy kernel: audit: type=1130 audit(1650254414.897:120): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=shadow comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 18 00:00:14 tom-hpenvy audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=shadow comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 18 00:00:14 tom-hpenvy systemd[1]: Started Verify integrity of password and group files.
Apr 18 00:00:14 tom-hpenvy systemd[1]: shadow.service: Deactivated successfully.
Apr 18 00:00:14 tom-hpenvy audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=shadow comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 18 00:00:14 tom-hpenvy kernel: audit: type=1131 audit(1650254414.910:121): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=shadow comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 18 00:00:20 tom-hpenvy eos-update-notifier[7855]: Checking for updates ...
Apr 18 00:00:23 tom-hpenvy eos-update-notifier[7855]: Checking AUR updates ...
Apr 18 00:00:24 tom-hpenvy systemd[693]: Finished EOS update notifier service.
Apr 18 00:21:24 tom-hpenvy systemd[1]: Starting Discard unused blocks on filesystems from /etc/fstab...
Apr 18 00:21:31 tom-hpenvy fstrim[7945]: /: 901.2 GiB (967698587648 bytes) trimmed on /dev/nvme0n1p2
Apr 18 00:21:31 tom-hpenvy fstrim[7945]: /boot/efi: 299.1 MiB (313638912 bytes) trimmed on /dev/nvme0n1p1
Apr 18 00:21:31 tom-hpenvy systemd[1]: fstrim.service: Deactivated successfully.
Apr 18 00:21:31 tom-hpenvy systemd[1]: Finished Discard unused blocks on filesystems from /etc/fstab.
Apr 18 00:21:31 tom-hpenvy audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=fstrim comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 18 00:21:31 tom-hpenvy audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=fstrim comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 18 00:21:31 tom-hpenvy kernel: audit: type=1130 audit(1650255691.237:122): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=fstrim comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 18 00:21:31 tom-hpenvy kernel: audit: type=1131 audit(1650255691.237:123): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=fstrim comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 18 00:26:26 tom-hpenvy dbus-daemon[454]: [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.26' (uid=1001 pid=845 comm="/usr/lib/org_kde_powerdevil") (using servicehelper)
Apr 18 00:26:26 tom-hpenvy dbus-daemon[454]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
Apr 18 00:26:30 tom-hpenvy dbus-daemon[454]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.256' (uid=1001 pid=7961 comm="kcheckpass -m classic -S 30")
Apr 18 00:26:30 tom-hpenvy dbus-daemon[454]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Apr 18 00:26:30 tom-hpenvy kcheckpass[7961]: pam_systemd_home(kde:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Apr 18 00:26:30 tom-hpenvy audit[7963]: USER_AUTH pid=7963 uid=1001 auid=1001 ses=2 msg='op=PAM:unix_chkpwd acct="tom2" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
Apr 18 00:26:30 tom-hpenvy kernel: audit: type=1100 audit(1650255990.701:124): pid=7963 uid=1001 auid=1001 ses=2 msg='op=PAM:unix_chkpwd acct="tom2" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
Apr 18 00:26:30 tom-hpenvy kwin_x11[770]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 9034, resource id: 48234554, major code: 18 (ChangeProperty), minor code: 0
Apr 18 00:26:41 tom-hpenvy kwin_x11[770]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 11067, resource id: 31457796, major code: 14 (GetGeometry), minor code: 0
Apr 18 00:26:42 tom-hpenvy plasmashell[848]: kf.sonnet.core: No language dictionaries for the language: "en_US" trying to load en_US as default
Apr 18 00:26:42 tom-hpenvy kwin_x11[770]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 11536, resource id: 31457803, major code: 18 (ChangeProperty), minor code: 0
Apr 18 00:26:42 tom-hpenvy systemd[693]: Started System Settings - System Settings.
Apr 18 00:26:43 tom-hpenvy systemsettings[7967]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ApplicationItem.qml:151:9: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 13. Use 'sequences: [ <key> ]' to bind to all of them.
Apr 18 00:26:43 tom-hpenvy systemsettings[7967]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ApplicationItem.qml:147:9: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 14. Use 'sequences: [ <key> ]' to bind to all of them.
Apr 18 00:26:43 tom-hpenvy systemsettings[7967]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
Apr 18 00:26:43 tom-hpenvy kwin_x11[770]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 12157, resource id: 52428812, major code: 18 (ChangeProperty), minor code: 0
Apr 18 00:26:43 tom-hpenvy plasma-discover[7997]: qrc:/qml/DiscoverWindow.qml:116:19: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 15. Use 'sequences: [ <key> ]' to bind to all of them.
Apr 18 00:26:43 tom-hpenvy plasma-discover[7997]: QObject::startTimer: Timers cannot have negative intervals
Apr 18 00:26:43 tom-hpenvy plasma-discover[7997]: file:///usr/lib/qt/qml/org/kde/kirigami.2/private/globaltoolbar/ToolBarPageHeader.qml:41:13: Unable to assign [undefined] to double
Apr 18 00:26:43 tom-hpenvy plasma-discover[7997]: file:///usr/lib/qt/qml/org/kde/kirigami.2/private/globaltoolbar/ToolBarPageHeader.qml:40:13: Unable to assign [undefined] to double
Apr 18 00:26:43 tom-hpenvy plasma-discover[7997]: file:///usr/lib/qt/qml/org/kde/kirigami.2/private/globaltoolbar/ToolBarPageHeader.qml:39:13: Unable to assign [undefined] to double
Apr 18 00:26:43 tom-hpenvy plasma-discover[7997]: file:///usr/lib/qt/qml/org/kde/kirigami.2/private/globaltoolbar/ToolBarPageHeader.qml:38:13: Unable to assign [undefined] to bool
Apr 18 00:26:43 tom-hpenvy kwin_x11[770]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 12219, resource id: 50331669, major code: 18 (ChangeProperty), minor code: 0
Apr 18 00:26:44 tom-hpenvy plasmashell[848]: kf.sonnet.core: No language dictionaries for the language: "en_US" trying to load en_US as default
Apr 18 00:26:45 tom-hpenvy systemd[693]: Started Firefox - Web Browser.
EDIT: I realize the original issue (crash + reboot during idle) is technically resolved, so if it’s better to put this in a new post I can of course do so.
Check here if the C6 is still disabled. I think it is not.
That’s why the link I gave earlier has its own script named:
On Sleep # Disable c6 coming out of sleep
