Not sure if this is the right place to ask the question but I was wondering if there was a way to monitor AMD ryzen 7000 (7600 in particular on AM5) power draw or PPT. “sensors” seems to have a reading for the IGPU but I doubt it’s reading is correct. For example, I’m actually using a dedicated GPU and the IGPU utilization is at 0%. However the power draw shows as high as 20 W. This reading also goes down to a much lower value when a CPU load is placed making it look like the power is being diverted. I get a reading for CPU power draw when I run phoronics test bench sensors as super user but I do not know if that is accurate since it only gives a reading at one moment in time.
