Info: Quad Core model: AMD Ryzen 3 3100 bits: 64 type: MT MCP arch: Zen 2
rev: 0 L2 cache: 2 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 57491
Speed: 3588 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz):
1: 3588 2: 3674 3: 3890 4: 3109 5: 3590 6: 3596 7: 3888 8: 3112
4 cores, 8 threads.
well yah thats what i meant but still i thought it was 4 core/4 threads. thats how it was advertised. no hyperthreading
All modern processors can have two threads per core, so yeah, it is hyperthreading.
I thought intel went away from hyper threading due to security risks?
Did you get this CPU already and up & running?
Right now, they LITERALLY can’t go away from it and continue to sell processors. Since AMD’s all have SMT as well, and are being literally made on a process node that’s MULTIPLE generations newer (even if it’s not the best 7nm and is only about inline with the density of Intel 10nm), they couldn’t hope to compete if they had to bring all the physical cores to bear. Rocket Lake even shows how hard it is to compete w/ still being on 14nm since on the desktop their top chips will only have 8 cores, DOWN 2 cores from Comet Lake.
Or put another way, ALMOST EVERY Intel chip right now outside of the Atom designs has hyperthreading available, and enabled.
I did. It’s working but in the old ab350m -ds3h. With 32 gb ram.
The new mb broke while I was screwing down the heat sink. My screwdriver slipped of hot the mother board and took out a capacitor thingy hooziwidget something or other. Since Amazon sent a replacement and refunded my money previously there’s no further remedy to be had there.
I’m pretty sure I did less damage to computers in all my whole life than I have these past couple of days and crochet may be the better option.
If there is ever to be a next computer I will by one fully assembled
System: Kernel: 5.11.8-lqx1-1-lqx x86_64 bits: 64 compiler: gcc v: 10.2.1 Desktop: MATE 1.24.1 Distro: Archish Linux
base: Arch Linux
Machine: Type: Desktop System: Gigabyte product: AB350M-DS3H v: N/A serial: N/A
Mobo: Gigabyte model: AB350M-DS3H-CF v: x.x serial: N/A UEFI [Legacy]: American Megatrends v: F50d date: 07/02/2020
Battery: Device-1: hidpp_battery_0 model: Logitech M570 charge: 100% status: Discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Keyboard K360 charge: 100% (should be ignored)
status: Discharging
Device-3: sony_controller_battery_07:4f:94:76:63:25 model: N/A charge: N/A status: Discharging
Memory: RAM: total: 31.37 GiB used: 12.52 GiB (39.9%)
Array-1: capacity: 128 GiB slots: 4 EC: None max module size: 32 GiB note: est.
Device-1: DIMM 0 size: No Module Installed
Device-2: DIMM 1 size: 16 GiB speed: 3200 MT/s type: DDR4
Device-3: DIMM 0 size: No Module Installed
Device-4: DIMM 1 size: 16 GiB speed: 3200 MT/s type: DDR4
CPU: Info: Quad Core model: AMD Ryzen 3 3100 bits: 64 type: MT MCP arch: Zen 2 rev: 0 L2 cache: 2 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 57494
Speed: 3718 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz): 1: 3718 2: 3715 3: 3722 4: 3717 5: 3716
6: 3716 7: 3715 8: 3719
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX 470/480/570/570X/580/580X/590] vendor: ASRock
driver: amdgpu v: kernel bus ID: 09:00.0
Display: server: X.org 1.20.10 driver: loaded: amdgpu,ati unloaded: fbdev,modesetting,vesa
resolution: <missing: xdpyinfo>
OpenGL: renderer: Radeon RX 570 Series (POLARIS10 DRM 3.40.0 5.11.8-lqx1-1-lqx LLVM 11.1.0) v: 4.6 Mesa 20.3.4
direct render: Yes
Audio: Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] vendor: ASRock driver: snd_hda_intel v: kernel
bus ID: 09:00.1
Device-2: Advanced Micro Devices [AMD] Starship/Matisse HD Audio vendor: Gigabyte driver: snd_hda_intel v: kernel
bus ID: 0b:00.4
Sound Server: ALSA v: k5.11.8-lqx1-1-lqx
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte driver: r8169 v: kernel
port: f000 bus ID: 05:00.0
IF: eth0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: f000 bus ID: 08:00.0
Bluetooth: Device-1: Intel type: USB driver: btusb v: 0.8 bus ID: 1-11:3
Report: ID: hci0 state: up running pscan bt-v: 3.0 lmp-v: 5.2 address: <filter>
Drives: Local Storage: total: 2.39 TiB used: 604.41 GiB (24.7%)
ID-1: /dev/nvme0n1 vendor: Sabrent model: Rocket Q size: 931.51 GiB temp: 41.9 C
ID-2: /dev/sda vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB
ID-3: /dev/sdb vendor: Micron model: MT-128 size: 119.24 GiB
ID-4: /dev/sdc vendor: SanDisk model: Ultra II 500GB size: 465.76 GiB
Partition: ID-1: / size: 48.97 GiB used: 29.3 GiB (59.8%) fs: ext4 dev: /dev/nvme0n1p6
Swap: ID-1: swap-1 type: partition size: 32 GiB used: 0 KiB (0.0%) dev: /dev/sdb2
Sensors: System Temperatures: cpu: 79.0 C mobo: N/A gpu: amdgpu temp: 69.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1480
Info: Processes: 360 Uptime: 4h 27m Init: N/A rc: OpenRC v: 0.42.1 runlevel: default Compilers: gcc: 10.2.0 clang: 11.1.0
Packages: 932 Shell: Bash v: 5.1.4 inxi: 3.3.01
Sorry that happened. I also slipped with the screw driver and it bounced off the board on my Ryzen. I was lucky i didn’t put a big scrape or gouge in it. It happens to the best of us. How does this Ryzen 3 work? I’m sure it’s way better than most Intel i3 dual cores. lol
Keep the faith … and don’t give up. Set backs happen. It’s okay. You just have to pick up the pieces and carry on.
recheck all options in UEFI
??? I prefer to not use uefi
i have this
inxi -Fza
Kernel: 5.11.6-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64
root=UUID=aa940861-9549-4d9c-8a95-6e556d073aa5 rw quiet noapic
processor.max_cstate=5 iommu=pt rcu_nocbs=0_11
systemd.unified_cgroup_hierarchy=true scsi_mod.use_blk_mq=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4 vt: 7
dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop System: Gigabyte product: X570 AORUS PRO v: -CF
serial: <filter>
Mobo: Gigabyte model: X570 AORUS PRO serial: <filter>
UEFI: American Megatrends v: F30 date: 09/15/2020
with 4 SSD
for 2 SSD there is a openmandriva ( version Zen ) installed , and EndeavourOs ,
on each SSD with their own Grub for distribution DE
( 2 SSD is on Raid1 GhostBSD )
change is easy with F12 , and boot on another disk
same config UEFI is applied for all
and??? I prefer to not use uefi
and??? Why? I’m interested in knowing why.
then read this about “bios”
https://www.phoronix.com/scan.php?page=news_item&px=Intel-Legacy-BIOS-EOL-2020
Oh boy intel said they are doing something let me just stop everything because intel says so. This is the same intel who said they were ending hyperthreading because of security issues?
for any manufacturer motherboard
validate a cpu and boot with UEFI & “bios” means
→ validate in Secureboot Efi no Csm
→ validate in Secureboot Efi with Csm
→ validate in no Secureboot Efi with Csm
→ validate in no Secureboot Efi with no Csm
that 4 validations in ANY CASE EACH TIME
suppress CSM & Legacy
only 2 validations
since 2015 all motherboards are in EFI ( maybe some workstation may have keep bios )
So what
I run UEFI, but I like old BIOS better. I almost only run business computers so I at least avoid all the graphics that motherboards have nowadays in the BIOS. I want it clean and tidy!
