Have any of you ever worked with linkwarden? Do you have any experience?
I would like to test it, but I have no idea what a Docker is or does. I have no experience with this. Can someone explain to me what a Docker does?
Docker is a container, it runs whatever (pi-hole, mariadb, web server etc), with limited access to your main system, sort of like a jail.
I run my own home page (Homaar), Google free Google search (Whoogle) and a pi-hole instance (TBH I am thinking of dumping this, browser extensions are much better, in the last 6 months, it blocked under a hundred requests).
With Docker you can run Applications in a Container. And as @xircon said with limited access to the host system (that all is configured in the yaml file)
If you wait until I get home, I can share a simple docker-compose install script that just runs Whoogle, you will need to install docker and docker compose, but it doesn’t interfere with anything (you just point your browser to localhost:<port>).
That would be great! I have to read up on the article first so that I know how to install Docker and Linkwarden
~/linkwarden cd into it.yay -S docker docker-compose
docker-compose.ymlRun:
docker compose up -d
And that should get it up and running, then follow their instructions to access.
Thank you very much! Gonna try this but I don’t think so tonight.
I will give you feedback as soon as everything is installed and running ![]()
services:
whoogle-search:
image: ${WHOOGLE_IMAGE:-benbusby/whoogle-search}
container_name: whoogle-search
restart: unless-stopped
pids_limit: 50
mem_limit: 256mb
memswap_limit: 256mb
# user debian-tor from tor package
user: whoogle
security_opt:
- no-new-privileges
cap_drop:
- ALL
tmpfs:
- /config/:size=10M,uid=927,gid=927,mode=1700
- /var/lib/tor/:size=15M,uid=927,gid=927,mode=1700
- /run/tor/:size=1M,uid=927,gid=927,mode=1700
#environment: # Uncomment to configure environment variables
# Basic auth configuration, uncomment to enable
#- WHOOGLE_USER=<auth username>
#- WHOOGLE_PASS=<auth password>
# Proxy configuration, uncomment to enable
#- WHOOGLE_PROXY_USER=<proxy username>
#- WHOOGLE_PROXY_PASS=<proxy password>
#- WHOOGLE_PROXY_TYPE=<proxy type (http|https|socks4|socks5)
#- WHOOGLE_PROXY_LOC=<proxy host/ip>
# Site alternative configurations, uncomment to enable
# Note: If not set, the feature will still be available
# with default values.
#- WHOOGLE_ALT_TW=farside.link/nitter
#- WHOOGLE_ALT_YT=farside.link/invidious
#- WHOOGLE_ALT_IG=farside.link/bibliogram/u
#- WHOOGLE_ALT_RD=farside.link/libreddit
#- WHOOGLE_ALT_MD=farside.link/scribe
#- WHOOGLE_ALT_TL=farside.link/lingva
#- WHOOGLE_ALT_IMG=farside.link/rimgo
#- WHOOGLE_ALT_WIKI=farside.link/wikiless
#- WHOOGLE_ALT_IMDB=farside.link/libremdb
#- WHOOGLE_ALT_QUORA=farside.link/quetre
#- WHOOGLE_ALT_SO=farside.link/anonymousoverflow
#env_file: # Alternatively, load variables from whoogle.env
#- whoogle.env
ports:
- 5000:5000
access via browser localhost:5000
