Greetings lovely community,
I feel like I may have done something wrong on my end from earlier today messing around with reflector
(see link: How to setup reflector-auto? - #22 by Scotty_Trees), but anyways, normally I run sudo pacman -Syu
to check for updates. I know you can also run -Syyu or -Syuu to like rebuild your package database I think? Maybe I just have them all confused a bit at the moment, but for the -Syyu command here’s my output. Let me know if there’s anything I need to refresh, or reload or fix. Any help is always very much appreciated!
[scott@endeavourOS ~]$ sudo pacman -Syyu
core 136.1 KiB 252 KiB/s 00:01 [-----------------------] 100%
extra 1568.4 KiB 703 KiB/s 00:02 [-----------------------] 100%
community 5.6 MiB 1201 KiB/s 00:05 [-----------------------] 100%
multilib 151.5 KiB 237 KiB/s 00:01 [-----------------------] 100%
endeavouros 18.6 KiB 13.4 KiB/s 00:01 [-----------------------] 100%
warning: e2fsprogs: local (1.46.3-2) is newer than core (1.46.3-1)
warning: gtkd: local (3.9.0-13) is newer than community (3.9.0-12)
warning: hwinfo: local (21.76-1) is newer than community (21.75-1)
warning: libinput: local (1.18.1-1) is newer than extra (1.18.0-1)
warning: liblphobos: local (2:1.27.0-1) is newer than community (2:1.26.0-4)
warning: nodejs: local (16.6.1-1) is newer than community (16.6.0-1)
warning: python-google-auth: local (1.30.0-1) is newer than community (1.29.0-1)
warning: re2: local (1:20210801-1) is newer than extra (1:20210601-1)
warning: tilix: local (1.9.4-4) is newer than community (1.9.4-3)
there is nothing to do
