RTL8852BE wifi not working
Hello
unfortunately my wifi RTL8852BE Wireless Network Adapter is not working
I’ve read another post about the RTL8852AE but I have no internet connection, no Ethernet or USB wifi stick
have you a suggestion?
thanks :slight_smile:
Phone’s USB tethering?
AUR has this: rtl8852be-dkms-git. To install it, run
yay -S rtl8852be-dkms-git
Try to get/order a cheap USB stick like TP-Link TL-WN725N
or make some manual copies from here
[https://github.com/lwfinger/rtw89]
yes, I was considering this solution :slight_smile: to buy a cheap USB stick
do you have some experience with this one?
with 721 only. Smooth case. Amazon writes Operating System Mac OS X 10.7 Lion, Linux, and some other minor operating systems like Ẉ* I do not dare to write here
care ful . Amazon no alway get info correct, it say " linux " but half time you need aur/git ( no work out of box ) that why i keep real old belkin ( only 2.4ghz) . out of box so far it found , or buy usb3/usb-c adapter for wire connection ( these thing all Linux usr should have in bag/draw ) IMO
The RTL8852BE requires that you install the package as noted by @manuel above.
