yeah, it does! It tells me the name of my device and that it was added. I’ll install the normal roccat swarm later. My only problem is that after I redirect my mouse, it steals my ability to do stuff on the main system, including close the “select usb device menu” xDDD
That’s because the mouse is now “redirected” to the Windows VM. Host doesn’t see it while VM is running.
Hitting Esc will do the job
So redirect mouse first haha
Small update on my side: The Roccat Swarm I software does find my keyboard but needs a firmware update and spice keeps stopping the USB redirection whenever I do it :I
Well, in that case, the only thing you could try is to fix the permanent redirection that used to cause permission errors, and see if that does the trick.
Basically, as suggested in the wiki, you’ll need to add new udev rules for your devices. After that, VM will be able to automatically pick your mouse/keyboard at boot time and “keep” as long as VM is running (just like with the temp redirection, such devices won’t be available in main system)
https://wiki.archlinux.org/title/Udev#Allowing_regular_users_to_use_devices
I fear I’m too unskilled at this to figure out what to do with this information, I’ve been pretty much bullshitting linux since I was 15 and I still have barely a quarter idea how anything works LOL. I’ll see and ask my friends who can do things, thanks for all the help!!! Will update the thread if it works or not
It’s not that hard, tbh, and that’s coming from someone who’s no “expert” either
Can you post the output of lsusb
command?
