I’m trying to use a better gui for restic.
restatic seems similar to vorta for borg which is okay.
I can’t seem to install it following below instructions.
$ git clone https://github.com/Mebus/restatic
$ cd restatic
$ pip install .
$ restatic
I manage to download it. I’ve even got the pip command to work after a lot of headache.
But then nothing runs when I enter ‘restatic’.
Any advice please?
[adminuser@adminuser-81vv Downloads]$ cd restatic/
[adminuser@adminuser-81vv restatic]$ ls
appdmg.json build Makefile README.md restatic.spec setup.py tests
bin LICENSE.txt MANIFEST.in requirements-dev.txt setup.cfg src Vagrantfile
[adminuser@adminuser-81vv restatic]$ pip install .
Defaulting to user installation because normal site-packages is not writeable
Processing /home/adminuser/Downloads/restatic
Preparing metadata (setup.py) ... done
Requirement already satisfied: appdirs in /usr/lib/python3.11/site-packages (from restatic==0.1.2) (1.4.4)
Requirement already satisfied: paramiko in /usr/lib/python3.11/site-packages (from restatic==0.1.2) (2.11.1)
Requirement already satisfied: pyqt5 in /usr/lib/python3.11/site-packages (from restatic==0.1.2) (5.15.9)
Requirement already satisfied: peewee in /usr/lib/python3.11/site-packages (from restatic==0.1.2) (3.16.3)
Requirement already satisfied: python-dateutil in /usr/lib/python3.11/site-packages (from restatic==0.1.2) (2.8.2)
Requirement already satisfied: keyring in /home/adminuser/.local/lib/python3.11/site-packages (from restatic==0.1.2) (24.2.0)
Requirement already satisfied: apscheduler in /home/adminuser/.local/lib/python3.11/site-packages (from restatic==0.1.2) (3.10.4)
Requirement already satisfied: psutil in /usr/lib/python3.11/site-packages (from restatic==0.1.2) (5.9.5)
Requirement already satisfied: six>=1.4.0 in /usr/lib/python3.11/site-packages (from apscheduler->restatic==0.1.2) (1.16.0)
Requirement already satisfied: pytz in /usr/lib/python3.11/site-packages (from apscheduler->restatic==0.1.2) (2023.3.post1)
Requirement already satisfied: tzlocal!=3.*,>=2.0 in /home/adminuser/.local/lib/python3.11/site-packages (from apscheduler->restatic==0.1.2) (5.0.1)
Requirement already satisfied: jaraco.classes in /home/adminuser/.local/lib/python3.11/site-packages (from keyring->restatic==0.1.2) (3.3.0)
Requirement already satisfied: importlib-metadata>=4.11.4 in /usr/lib/python3.11/site-packages (from keyring->restatic==0.1.2) (5.0.0)
Requirement already satisfied: SecretStorage>=3.2 in /usr/lib/python3.11/site-packages (from keyring->restatic==0.1.2) (3.3.3)
Requirement already satisfied: jeepney>=0.4.2 in /usr/lib/python3.11/site-packages (from keyring->restatic==0.1.2) (0.8.0)
Requirement already satisfied: bcrypt>=3.1.3 in /usr/lib/python3.11/site-packages (from paramiko->restatic==0.1.2) (4.0.1)
Requirement already satisfied: cryptography>=2.5 in /usr/lib/python3.11/site-packages (from paramiko->restatic==0.1.2) (41.0.3)
Requirement already satisfied: pynacl>=1.0.1 in /usr/lib/python3.11/site-packages (from paramiko->restatic==0.1.2) (1.4.0)
Requirement already satisfied: PyQt5-sip<13,>=12.11 in /usr/lib/python3.11/site-packages (from pyqt5->restatic==0.1.2) (12.12.2)
Requirement already satisfied: cffi>=1.12 in /usr/lib/python3.11/site-packages (from cryptography>=2.5->paramiko->restatic==0.1.2) (1.15.1)
Requirement already satisfied: zipp>=0.5 in /usr/lib/python3.11/site-packages (from importlib-metadata>=4.11.4->keyring->restatic==0.1.2) (3.16.2)
Requirement already satisfied: more-itertools in /usr/lib/python3.11/site-packages (from jaraco.classes->keyring->restatic==0.1.2) (10.1.0)
Requirement already satisfied: pycparser in /usr/lib/python3.11/site-packages (from cffi>=1.12->cryptography>=2.5->paramiko->restatic==0.1.2) (2.21)
Building wheels for collected packages: restatic
Building wheel for restatic (setup.py) ... done
Created wheel for restatic: filename=restatic-0.1.2-py3-none-any.whl size=131446 sha256=ab485fc9e2867c3979cb789848fbd8b99cef610481d7a1288c12d106c992f6e6
Stored in directory: /tmp/pip-ephem-wheel-cache-y3zjuejl/wheels/21/ed/8b/d4f2b668c02fecaa2364fd5da2acddd91c848924a293141b3f
Successfully built restatic
Installing collected packages: restatic
Attempting uninstall: restatic
Found existing installation: restatic 0.1.2
Uninstalling restatic-0.1.2:
Successfully uninstalled restatic-0.1.2
Successfully installed restatic-0.1.2
[adminuser@adminuser-81vv restatic]$ restatic
bash: restatic: command not found
appdmg.json bin build LICENSE.txt Makefile MANIFEST.in README.md requirements-dev.txt restatic.spec setup.cfg setup.py src tests Vagrantfile
