I’ve installed endeavouros, but my… rather huge issue is that the resolution is stuck at on 1024x768. I’ve reinstalled the nvidia drivers, and tried xrandr but it showed this on the output step. I’m using the grub bootloader with KDE plastma as my DE, SDDM as my DM
[juno@juno-b450 ~]$ xrandr --output HDMI-A-1 --mode 1920x1080_60.00
X Error of failed request: BadValue (integer parameter out of range for operation)
Major opcode of failed request: 140 (RANDR)
Minor opcode of failed request: 21 (RRSetCrtcConfig)
Value in failed request: 0x0
Serial number of failed request: 22
Current serial number in output stream: 22
nvidia-settings doesn’t have the options it should be having (it only has system information with graphics information under it, GPU 0(NVIDIA GeForce RTX 3060) with Thermal Settings under it, application profiles, and nvidia-setttings configuration.
This is my infi -Fxz
Kernel: 6.6.52-1-lts arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
Desktop: KDE Plasma v: 6.1.5 Distro: EndeavourOS base: Arch Linux
Type: Desktop Mobo: ARKTEK model: B450 v: Ver:1.31
serial: UEFI: American Megatrends LLC. v: 5.17
date: 09/05/2022
Info: 6-core model: AMD Ryzen 5 5500 bits: 64 type: MT MCP arch: Zen 3
rev: 0 cache: L1: 384 KiB L2: 3 MiB L3: 16 MiB
Speed (MHz): avg: 1271 high: 3076 min/max: 400/4267 cores: 1: 2958 2: 400
3: 3024 4: 2994 5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 3076
bogomips: 86271
Device-1: NVIDIA GA106 [GeForce RTX 3060] driver: nvidia v: 560.35.03
arch: Ampere bus-ID: 01:00.0
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.2
compositor: kwin_wayland driver: X: loaded: nvidia gpu: nvidia
resolution: 1024x768
API: EGL v: 1.5 drivers: nvidia,swrast platforms:
active: gbm,wayland,x11,surfaceless,device inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 560.35.03
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3060/PCIe/SSE2
API: Vulkan v: 1.3.295 drivers: nvidia surfaces: xcb,xlib,wayland
devices: 1
Device-1: NVIDIA GA106 High Definition Audio driver: snd_hda_intel v: kernel
bus-ID: 01:00.1
Device-2: AMD Family 17h/19h HD Audio driver: snd_hda_intel v: kernel
bus-ID: 0b:00.6
API: ALSA v: k6.6.52-1-lts status: kernel-api
Server-1: PipeWire v: 1.2.4 status: active
Device-1: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
driver: r8169 v: kernel port: e000 bus-ID: 06:00.0
IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac:
Local Storage: total: 1.17 TiB used: 9.56 GiB (0.8%)
ID-1: /dev/nvme0n1 vendor: Patriot model: M.2 P300 256GB size: 238.47 GiB
temp: 44.9 C
ID-2: /dev/sda vendor: Seagate model: ST1000VM002-1CT162 size: 931.51 GiB
ID-3: /dev/sdb vendor: Kingston model: DataTraveler 3.0 size: 28.82 GiB
type: USB
ID-1: / size: 215.89 GiB used: 9.56 GiB (4.4%) fs: ext4 dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 1022 MiB used: 288 KiB (0.0%) fs: vfat
dev: /dev/nvme0n1p1
ID-1: swap-1 type: partition size: 17.06 GiB used: 0 KiB (0.0%)
dev: /dev/nvme0n1p3
System Temperatures: cpu: 40.1 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 16 GiB available: 15.51 GiB used: 3.21 GiB (20.7%)
Processes: 292 Uptime: 5m Init: systemd
Packages: 1000 Compilers: gcc: 14.2.1 Shell: Bash v: 5.2.32 inxi: 3.3.35
I would like to note, on a previous install, nouveau drivers worked fine and the resolution was 1920x1080, but I don’t want to use nouveau drivers, and can’t, because the performance hit is just too much to overlook, especially on my more graphics intensive games, not to mention it has a few general bugs.
I’m genuinely going insane trying to fix this, I have been at it for hours.
