Hello all. My resize keybinding is not working.
I am using Xfce4 with i3 as window manager. My old Xfce keybinds are all deleted.
My config is here:
$Mod4+R wasn’t working, so to be sure it wasn’t a conflicting keybind I changed it to:
$Mod4+Shift+R (which does not activate the mode either.)
Can anyone spot what I’ve done wrong?
# resize window (you can also use the mouse for that):
mode "resize" {
# These bindings trigger as soon as you enter the resize mode
# Pressing left will shrink the window’s width.
# Pressing right will grow the window’s width.
# Pressing up will shrink the window’s height.
# Pressing down will grow the window’s height.
# bindsym j resize shrink width 10 px or 10 ppt
# bindsym k resize grow height 10 px or 10 ppt
# bindsym l resize shrink height 10 px or 10 ppt
# bindsym ntilde resize grow width 10 px or 10 ppt
# same bindings, but for the arrow keys
bindsym Left resize shrink width 10 px or 10 ppt
bindsym Down resize grow height 10 px or 10 ppt
bindsym Up resize shrink height 10 px or 10 ppt
bindsym Right resize grow width 10 px or 10 ppt
# back to normal: Enter or Escape
bindsym Return mode "default"
bindsym Escape mode "default"
bindsym $mod+r mode "resize"
I pasted exactly that and it still isn’t working. I tried a few more tweaks but no dice. I’ll probably have to start over again after backing up my config which is fine, and expected
I feel like I was having a similar issue, and what resolved it was mapping the $mod+ctrl+[arrow-keys]
Obviously you’d need to map each arrow key, and I’m not sure if that is the proper syntax for the control key, but just use the preset stuff and replace/add ctrl as appropriate.
I’m out of town and don’t have access to my config files, but I’ll see if you fixed it when I get home tomorrow and share the exact snippet.
Here’s from mine (sorry I didn’t see this thread earlier)
mode "resize" {
bindsym Right resize shrink width 10 px or 10 ppt
bindsym Left resize grow width 10 px or 10 ppt
Ah yeah, I forgot there is a “resize mode”. I don’t remember how I did it but I mapped the keys so that I don’t need to enter into resize mode. Holding down the super key and control, and then using arrows just does it. I couldn’t get the resize mode to work either, plus it seemed inefficient.
That will work, I think. But for me it would only be a temporary fix. If I’m using a tiling window manager, I want to minimize my interaction with the mouse.
That’s the thing right there. I knew someone would pop up with it eventually.
I would prefer not to use my mouse for anything, but unfortunately every app has different keybindings so any new app requires a mouse at least at first.
I was just trying to quote your post without repeating the whole thing. I meant your code is exactly what I was talking about and what I use. Not sure what my comment says in my config, I don’t have it handy.
