I have to reinstall my system. Mainly because my /efi only has 500mb. A bit too small.
Now to my actual problem:
How can I save the ports/settings of firewalld and add them again afterwards?
Is that correct if I back up /etc/firewalld and add it again afterwards? Will that work? Or is there an easier way
I understand that OP wants to reinstall to get a clean disk setup but I just wanted to ask this for knowing if this may help in such cases if someone doesn’t want to reinstall:
mount the ESP to /efi and additionally mount an “Extended Boot Loader Partition” (XBOOTLDR) to /boot. This can be useful when a previously created ESP is too small to hold multiple boot loaders and/or kernels but the ESP cannot be easily resized (such as when installing Linux after Windows to dual boot). This method is supported by at least systemd-boot.
For me, a complete reinstall is easier. I have backed up all the relevant files and settings. After a reinstallation, the system is restored in a very short time.
Yes, I understood that. I wasn’t suggesting it as an option in your case. I wanted to know if that can be an option for other setups that doesn’t have EOS’ automation.
