Recommendations for optimizing system performance
Not sure if I should really do anything at all but it doesn’t hurt to ask.
This is a custom-built desktop with no discrete graphics. Specs pasted below.
Will I benefit from a zen kernel and/or system tweaks?
I run Windows 10 in VirtualBox. In the VM, I run light apps such as Microsoft Word.
Sometimes, on the host machine, I convert videos to a different format, using Handbrake.
Otherwise, I don’t do anything heavy. And I am not a gamer.
My memory usage is usually between 40% and 60% of my 16 Gb RAM.
Should I just leave things as is, or tweak?
inxi -F
  Host: shmuel-arch Kernel: 5.13.10-arch1-1 x86_64 bits: 64
  Desktop: KDE Plasma 5.22.4 Distro: EndeavourOS
  Type: Desktop Mobo: ASUSTeK model: PRIME B365M-A v: Rev X.0x
  serial: <superuser required> UEFI: American Megatrends v: 1203
  date: 10/10/2019
  Info: 8-Core model: Intel Core i7-9700 bits: 64 type: MCP cache:
  L2: 12 MiB
  Speed: 1148 MHz min/max: 800/4700 MHz Core speeds (MHz): 1: 1148
  2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800
  Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] driver: i915
  v: kernel
  Device-2: IMC Networks XHC Camera type: USB driver: uvcvideo
  Display: x11 server: X.org 1.20.13 driver: loaded: intel
  unloaded: fbdev,modesetting,vesa resolution: <missing: xdpyinfo>
  Device-1: Intel 200 Series PCH HD Audio driver: snd_hda_intel
  Device-2: JMTek LLC. USB PnP Audio Device type: USB
  driver: hid-generic,snd-usb-audio,usbhid
  Sound Server-1: ALSA v: k5.13.10-arch1-1 running: yes
  Sound Server-2: PipeWire v: 0.3.33 running: yes
  driver: r8168
  IF: enp3s0 state: up speed: 1000 Mbps duplex: full
  mac: a8:5e:45:e2:87:3c
  Device-2: Realtek 802.11ac NIC type: USB driver: rtl8821cu
  IF: wlan0 state: down mac: fe:aa:bd:65:7c:f7
Bluetooth:
  Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
  type: USB driver: btusb
  Report: rfkill ID: hci0 state: up address: see --recommends
  Local Storage: total: 2.26 TiB used: 907.15 GiB (39.3%)
  ID-1: /dev/sda vendor: Kingston model: SA400S37480G size: 447.13 GiB
  ID-2: /dev/sdb vendor: Toshiba model: HDWD120 size: 1.82 TiB
  ID-1: / size: 38.51 GiB used: 18.85 GiB (49.0%) fs: ext4
  dev: /dev/sda6
  ID-2: /boot/efi size: 96 MiB used: 37 MiB (38.5%) fs: vfat
  dev: /dev/sda2
  System Temperatures: cpu: 29.8 C mobo: 27.8 C
  Fan Speeds (RPM): N/A
  Processes: 274 Uptime: 54m Memory: 15.49 GiB used: 6.6 GiB (42.6%)
  Shell: fish inxi: 3.3.05
You can try/use the zen kernel, the gains are more noticeable on older cpus under heavy load and I believe it has the esync patch integrated for wine and support for anbox
The golden rule is “tweak it until it breaks, then tweak it a little bit less”. :grin:
I would start with inxi command using -z to filter out private information when you post on internet. But that is probably my paranoia talking. :wink:
Anyway, with 40-60% memory used I would consider enabling swap. You have ssd disk so that could help in some edge conditions when you decide you want to run something fancy parallel to virtualbox.
It is also important to consider how is your filesystem split into those 2 drives. There are some tweaks for specific applications as well. For example I like this firefox on RAM. It helps a lot if you have your home directory on HDD.
