Reboot issue after clean install I3
I’m on a hybrid laptop with Intel onboard & Nvidia discrete.
During installation I have not selected the Nvidia driver.
This results in nouveau time outs during (re)boot and takes “forever”.
After having run nvidia-installer-dkms -b, the (re)boot process goes better, but still takes too long; about 90 seconds.
I have gathered journalctl -r output of the reboot prosess in this file and hope somebody can point me in the direction of a solution.
Activation via systemd failed for unit ‘dbus-org.freedesktop.nm-dispatcher.service’: Refusing activation, D-Bus is shutting down.
Did you tried ?
systemctl restart systemd-logind
What is this dbus-org.freedesktop.nm-dispatcher.service for anyway?
Issuing
and subsequent reboot does not help.
if you imply that dbus-org.freedesktop.nm-dispatcher.service is not part of the standard I3 installation, then I might have to look deeper, because I have installed I3 while keeping my /home partition from an earlier installation (KDE) intact. Not so wsie?
Sorry, I was just asking what it actually does exactly? I wasn’t implying anything. I know it’s for networkmanager.
No need to be sorry! I just interpreted your remark about this service as maybe it’s a service that shouldn’t be there in my setup and maybe it’s a leftover from an earlier installation because I didn’t format my home directory (partiiton) during installation of I3.
I have searched (grepped) in /home and do not find any conspicuous reference to this service.
D-Bus is a message bus system, on Xfce the file org.freedesktop.nm_dispatcher.service is at /usr/share/dbus-1/system-services/
There is a tool to use to debug D-Bus called d-feet.
https://www.archlinux.org/packages/community/any/d-feet/
I don’t know if our i3 environment uses already the variable for gnome, if not you could set it up :
env XDG_CURRENT_DESKTOP=GNOME gnome-control-center
It supposes to be vanilla then I’m on Xfce. @joekamprad would help you more about i3.
I am using EOS i3 (without re-install, just got it from the source). That’s what I have:
% echo $XDG_CURRENT_DESKTOP
i3
could you give the result of ?
It’s launching the Gnome Control Center. Is it what was supposed to happen?
so you have it installed by default on i3.
just need to seutp environment then would be interesting to test d-feet
As I said though,I didn’t reinstall my system. I was using gnome control center before for the gnome-keyring, so I may have set it before.
[eljejer@spectre ~]$ echo $XDG_CURRENT_DESKTOP
i3
[eljejer@spectre ~]$ gnome-control-center
bash: gnome-control-center: command not found
It needs to be installed manually…
sudo pacman -S gnome-control-center
So we agree it’s vanilla i3 and it’s necessary to install it…
I don’t know i3, I installed once for test but prefer my Xfce…
But it seems if with this setup environment you could use GTK App…
Maybe need lxappearance also !!
At first sight, d-feet does not report errors when inspecting org.freedesktop.nm_dispatcher on my system
To see if NetworkManager works with other networks and know what is enable exactly could you give the result of :
It seems that i3 has often issue between NetworkManager and nm-applet maybe could be useful to see on this side !!
systemctl list-unit-files --state=enabled
I know it’s blind leading the blind (I am a noob and not sure what to look for in the journal), but could this be (in part) responsible in the reboot taking so much time?
april 17 06:28:36 spectre systemd[1]: session-2.scope: Failed with result 'timeout'.
april 17 06:28:36 spectre systemd[1]: session-2.scope: Killing process 1470 (gmain) with signal SIGKILL.
april 17 06:28:36 spectre systemd[1]: session-2.scope: Killing process 1094 (pcmanfm) with signal SIGKILL.
april 17 06:28:36 spectre systemd[1]: session-2.scope: Stopping timed out. Killing.
I read somewhere that removing all the .scope would resolve it but need to refind it !!!
