Realtek network card 10ec:8852 not detected/working
Hello,
I am currently trying to install EndeavourOS on my lenovo laptop (I also have it on the desktop i am currently using)
However I wanted to do a online install and install it with KDE but then I realized I wasn’t connected to the wifi but I also can’t connect to it because XFCE says “No network devices available” I checked the Inxi log and saw that the network Device doesnt have a driver
Device-1 Realtek vendor: Lenovo driver: N/A port:2000 chip-ID: 10ec:8852
I also tried plugging in a usb for a another wifi connection which at least detected the wifi and also connected to it but I always get instantly disconnected.
Should I just do an offline install or is there a way I can get the wifi to work?
As a “workaround”, you might perhaps be able to usb-tether your phone’s internet connection to do an online install.
right! I forgot about this give me a second I will try it
This probably needs the rtw89-dkms-git driver from the AUR. I think support is also included in kernel 5.17.
I will see once I get my system installed currently Im trying usb-tethering (which I completely forgot) how pebcak suggested
But currently the installation is always failing because it cannot shrink the partition of the ssd (https://termbin.com/o3md)
Please show the partitioning of the disks:
lsblk -fm
sudo fdisk -l
and tell which partition are you going to use for linux.
I “fixed” it
I was going into my windows to then shrink the partition there and then booted up the live usb again and installed the system again I hope it works now
Should work. Great that you got it installed!
I can always rely on you guys :sweat_smile: not proud of that but I hope that will change in the future
so thank you!
@jonathon i think is correct that the chip will have support in the 5.17 kernel. I think this Realtek is WiFi 6 AX
So I should Install that package when I have a working system, right?
Yes for now and should work as @jonathon suggested. Then when the 5.17 kernel is out you may not need the package as it should be supported in the new kernel version hopefully.
it works!
I hope 5.17 will fix it for all users but as long as there is some way to do it im fine with that.
anyway I installed kde I connected to my wifi so thank you!
It shouldn’t be any problem either way as long as it works. :wink:
That is true :smiley:
