Hello everyone,
When installing EndeavourOS, I noticed I have the Realtek problem where my NIC will connect just fine sometimes, other times it won’t at all or it does connect but I sit with over 50% packet loss. Wi-Fi works just fine.
Packet Loss Problem Example:
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=2 ttl=60 time=8.51 ms
64 bytes from 8.8.8.8: icmp_seq=4 ttl=60 time=7.72 ms
64 bytes from 8.8.8.8: icmp_seq=5 ttl=60 time=7.82 ms
64 bytes from 8.8.8.8: icmp_seq=6 ttl=60 time=8.31 ms
--- 8.8.8.8 ping statistics ---
9 packets transmitted, 4 received, 55.5556% packet loss, time 8091ms
rtt min/avg/max/mdev = 7.721/8.091/8.514/0.330 ms
NIC:
inxi -Na
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
vendor: Hewlett-Packard driver: r8168 v: 8.052.01-NAPI modules: r8169 pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 3c:00.0
chip-ID: 10ec:8168 class-ID: 0200
One thing, I do notice is the card is still using the 8169 module, is that causing the problem? How do I change that?
I have read the wiki as well as the forums and I see that there are issues with the specific NIC. There has been suggestions on forums as well as the wiki to resolve the issue:
- Install the r8168 drivers and blacklist r8169 drivers
- Disable the firewall to see if that was the issue
- Move to the LTS kernel and use those r8168-lts (This seems to have made it worse)
- Disable IPv6 to see if that is causing the issue
My problem still persists unfortunately and I am unsure what to do. Is there anything else I am missing or not trying?
I have never experienced this problem before, this machine has run Windows, Ubuntu, Arch and Debian distros before with no connectivity issues at all.
