Realtek 8922ae On Gigabyte's Aorus Elite x870e Connection Inconsistent
After recently getting this board, the Wifi seems to drop out on occasion. It happens erratically and for 3-30 seconds, usually settling at around 5. I’ve tried entirely removing the rtw89_8922ae drivers and fully reinstalling the kernel, which has been unsuccessful. It happens only after using the computer for several minutes, but does not appear heat or component related; I’ve tested the board with a windows to go installation and the issue doesn’t occur at all.
To expediently cause the issue, I’ve found that running programs that trip it more often (in my case, specifically the curseforge app via aur and total warhammer 3 via steam and proton) will cause it after just a few minutes at most. Some combinations of programs seem to not cause the issue at all.
Following the outages, everything resumes as it was prior.
Let me know what else I can provide and what to try next.
I will also note that disabling and reenabling wifi fixes the problem immediately, until it happens again.
