Okay so now i don’t feel so stupid.
Are you booting it up and going into a tty and logging in as root? ctrl alt f2
Im booting it up going into tty with ctrl alt f2 and trying to log into root (i cant see what im typing so i just have to just type in my username and password and pray i get it right) and if i do stuff works like if i type poweroff my PC will turn off its just i cant see what im doing im guessing i need to somehow reinstall the NVIDIA drivers while like that lmao
So the screen is messed up in the TTY making it unreadable?
Not messed up its just not displaying anything
That’s strange? Have you tried shutting it down and unplugging the cable and reconnect it and boot back up? Could it be the cable? Do you have another to try?
Edit: Or worse is it the monitor?
im guessing its not the cable or monitor since im using them to type this at the minute lol
when i first installed EndeavourOS i didnt install with nvidia drivers and i got the effect im currently getting now i did reinstall it with drivers and it worked so im guessing its not my hardware
Have you tried updating. A new kernel just came out. It’s 5.15.4
should i just try navigate to the TTY and type
sudo pacman -Syu
Yes, no harm in trying.
Edit: Also if you ran nvidia-installer-dkms -n then it would be booting on nouveau if it uninstalled the nvidia drivers, so you would have to reinstall the nvidia drivers with
sudo nvidia-installer-dkms
my TTY is working fine after i ran sudo pacman -Syu but i got an error that was /dev/sdb1 clean: files, blocks with numbers in between
(an example would be “/deb/sdb1 clean: 128347128/6108129 files, 24192147121/128487241 blocks”)
i dont remember the exact numbers but any thoughts on what to do next?
Did you install the nvidia drivers?
Don’t reboot after.
il try that now should i run it with a -t after first to check for errors?
Sure and you could see if there are any errors.
Edit: Don’t reboot
it tells you to reboot if i remember correctly after installing drivers what should i do after should i just leave my computer or?
Don’t reboot after running the installer to install nvidia drivers as i want to add some enhancements first.
Edit: Run the test first. If okay …run the installer with sudo but no -t
Edit2: The test run doesn’t need sudo.
Edit3: Let me know when you have installed the nvidia drivers.
Actually i keep forgetting you are in a TTY so sudo isn’t necessary anyway.
Edit: So after installing the nvidia drivers we will add all the enhancements one after another and then when done you can reboot and see what happens.
I’ll post the instructions.
Okay the tests were successful I’ve installed the drivers now and not rebooted
Step 1
nano /etc/default/grub
Add the following to the default grub command line.
nvidia-drm.modeset=1
Looks like this as an example…
GRUB_CMDLINE_LINUX_DEFAULT="nvidia-drm.modeset=1 resume=UUID=...
ctrl + o then enter to save
ctrl + x to exit
Then run
Sorry i keep forgetting we don’t need sudo.
Step 2
nano /etc/mkinitcpio.conf
Add to the modules section MODULES=
MODULES="nvidia nvidia_modeset nvidia_uvm nvidia_drm"
ctrl + x to exit
Then run
mkinitcpio -P
