Raspberry Pi 5 vs 5b; the Difference?
Hi, I was wondering what the difference is between the Raspberry Pi 5 versus the 5b. I cannot find any information on what the 5b is. I was also wondering if EndeavourOS ARM would install fine on my 8 GB Raspberry Pi 5. Will the “5b” image work?
There are two models available, Raspberry Pi 5 model A and Raspberry Pi 5 model B.
This page will answer all your questions. Scroll to the bottom of the pictures chart for Raspberry PI 5 model B
https://www.raspberrypi.com/documentation/computers/raspberry-pi.html#flagship-series
I have never seen a RPi 5 model A offered anywhere, in common use, for the most part I believe that RPi 5 and RPi 5 model B are essentially the same.
If your Raspberry Pi 5 has an ethernet port, double USB 3 connector, and double USB 2 connector, then it is a Raspberry Pi 5 model B. Use this image:
Just make sure you have an adequate heat sink and adequate power supply.
Here is a pic of my Raspberry Pi 5 model B with 8 GB RAM running Plasma on an external USB3 SSD enclosure.
RPi5
I hope you enjoy your RPi 5b.
Pudge
