When I update my endeavour mirrors, I see this warning:
and wonder if there is a way t o remove these mirrors so I don’t have to wait until they are addressed?
Remove them from /etc/pacman.d/endeavouros.mirrorlist
This should work
They are just warnings, sometimes mirrors fail either temporarily or permanently. That doesn’t cause a problem because those mirrors are ignored from the generated list.
You can ignore them in file /etc/eos-rankmirrors.conf, for example:
EOS_IGNORED_MIRRORS=(
hacktegic
sjtu
Sorry I could only choose I for solution ![]()
