Hi.
I’m using qtile. Inxi results for hardware at the bottom of the post. My system has been stable for a long time. Never encountered this issue before. I don’t recally doing any changes in the system. My workflow has been set for some time now.
A major part of my work is done in web applications (Firefox). But the lag also happens in other applications (such as when writing in mousepad).
Could really use some help here.
Problem description
Endeavour is at times randomly skipping characters while typing (some characters just wont appear)
OR ignoring keyboard inputs alltogether (kb inputs wont work)
OR is adding lag to inputs (when you type, it takes 10 seconds for a single character to appear)
What I tried: tried a different keyboard, changed batteries on the current keyboard (2 times).
[jj@jj-systemproductname ~]$ inxi -Faz
Kernel: 6.12.30-1-lts arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
clocksource: tsc avail: hpet,acpi_pm
parameters: initrd=\6f2941abb3a44e048ade5c95fb93952e\6.12.30-1-lts\initrd
nvme_load=YES nowatchdog rw rootflags=subvol=/@
root=UUID=ba4fefc3-d257-4b93-a18e-f78c44970bb5
resume=UUID=19e6ba33-d050-49ed-847c-26592a87422e
systemd.machine_id=6f2941abb3a44e048ade5c95fb93952e
Desktop: Qtile v: 0.31.1.dev0+g8666bfc8.d20250312 vt: 7 dm: LightDM
v: 1.32.0 Distro: EndeavourOS base: Arch Linux
Mobo: ASUSTeK model: ROG MAXIMUS X HERO v: Rev 1.xx
serial: <superuser required> part-nu: SKU uuid: <superuser required>
UEFI: American Megatrends v: 2701 date: 07/13/2021
Info: model: Intel Core i7-8700K bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xFA
Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 threads: 12 tpc: 2
smt: enabled cache: L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB
desc: 6x256 KiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 800 min/max: 800/3700 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 88824
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Vulnerabilities:
Type: gather_data_sampling mitigation: Microcode
Type: indirect_target_selection status: Not affected
Type: itlb_multihit status: KVM: VMX unsupported
Type: l1tf mitigation: PTE Inversion
Type: mmio_stale_data mitigation: Clear CPU buffers; SMT vulnerable
Type: reg_file_data_sampling status: Not affected
Type: retbleed mitigation: IBRS
Type: spec_rstack_overflow status: Not affected
prctl
sanitization
Type: spectre_v2 mitigation: IBRS; IBPB: conditional; STIBP: conditional;
RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
Type: tsx_async_abort mitigation: TSX disabled
Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: ASUSTeK
driver: i915 v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20
ports: active: HDMI-A-2 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:3e92 class-ID: 0300
Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
compositors: 1: Picom v: 12.5 2: Qtile v: 0.31.1.dev0+g8666bfc8.d20250312
driver: X: loaded: modesetting unloaded: vesa alternate: fbdev,intel
dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 507x285mm (19.96x11.22")
s-diag: 582mm (22.9")
Monitor-1: HDMI-A-2 mapped: HDMI-2 model: Sony TV 30 serial: <filter>
built: 2021 res: mode: 1920x1080 hz: 120 scale: 100% (1) dpi: 40 gamma: 1.2
size: 1218x685mm (47.95x26.97") diag: 1397mm (55") ratio: 16:9 modes:
max: 4096x2160 min: 640x480
API: EGL v: 1.5 hw: drv: intel iris platforms: device: 0 drv: iris
device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.1.1-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 630 (CFL
GT2) device-ID: 8086:3e92 memory: 29.57 GiB unified: yes
Info: Tools: api: eglinfo,glxinfo de: xfce4-display-settings x11: xdriinfo,
xdpyinfo, xprop, xrandr
Device-1: Intel 200 Series PCH HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3
chip-ID: 8086:a2f0 class-ID: 0403
Device-2: Focusrite-Novation Focusrite Scarlett 2i2 2nd Gen
driver: snd-usb-audio type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 1-3:2 chip-ID: 1235:8202 class-ID: 0102
API: ALSA v: k6.12.30-1-lts status: kernel-api
Server-1: PipeWire v: 1.4.2 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
Info: services: NetworkManager,systemd-timesyncd
Bluetooth:
Device-1: Microsoft Nano Transceiver v1.0 for Bluetooth
driver: hid-generic,usbhid type: USB rev: 2.0 speed: 12 Mb/s lanes: 1
mode: 1.1 bus-ID: 1-4:3 chip-ID: 045e:0745 class-ID: 0300
Local Storage: total: 10.23 TiB used: 9.27 TiB (90.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 960 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B7QCXE7 temp: 26.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 010 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD100EFAX-68LHPN0 size: 9.1 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
fw-rev: 0A83 scheme: GPT
ID-1: / raw-size: 921.73 GiB size: 921.73 GiB (100.00%)
used: 449.27 GiB (48.7%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-2: /home raw-size: 921.73 GiB size: 921.73 GiB (100.00%)
ID-3: /var/log raw-size: 921.73 GiB size: 921.73 GiB (100.00%)
Kernel: swappiness: 60 (default) cache-pressure: 100 (default) zswap: yes
compressor: zstd max-pool: 20%
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 34.0 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 32 GiB note: est. available: 30.28 GiB used: 5.26 GiB (17.4%)
Processes: 305 Power: uptime: 2h 20m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 0 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 12.1 GiB
services: power-profiles-daemon,upowerd Init: systemd v: 257
default: graphical tool: systemctl
Packages: 1581 pm: pacman pkgs: 1524 libs: 491 tools: yay pm: flatpak
pkgs: 57 Compilers: gcc: 15.1.1 Shell: Bash v: 5.2.37
running-in: xfce4-terminal inxi: 3.3.38
