While using, I’ve been getting random freezes with the caps lock blinking regularly, I thought it was the nvidia driver, so i removed dkms and installed the open ones. still happened.
What do?
Also I’m on a laptop using xfce
@user639163
To avoid kernel panic try lts kernel first
sudo pacman -S linux-lts linux-lts-headers
Can i just install and it will replace itself next boot?
You will see it. How do you boot?
Grub encrypted install
As far as I recall grub is updated otherwise
Alright, its running on lts. I’ll report back any crashes
Nope still had a kernel panic, while updating im pretty sure too. Came with some pretty crazy graphical glitches
https://wiki.archlinux.org/title/Systemd/Journal
https://forum.endeavouros.com/t/kernel-panic-during-update-broke-my-system-thanks-god-and-linux-community-for-the-arch-chroot/51839
There are experienced riders here, not like me.
Show us first.
inxi
inxi -m
in BIOS are there power/speed? profiles?
user@machine ~]$ inxi
CPU: 6-core 11th Gen Intel Core i5-11400H (-MT MCP-)
speed/min/max: 859/800/4500 MHz Kernel: 6.6.52-1-lts x86_64 Up: 4m
Mem: 3.22/15.37 GiB (21.0%) Storage: 1.38 TiB (0.9% used) Procs: 324
Shell: Bash inxi: 3.3.35
[user@machine ~]$ inxi -m
Memory:
System RAM: total: 16 GiB available: 15.37 GiB used: 3.22 GiB (20.9%)
Array-1: capacity: 128 GiB slots: 4 modules: 2 EC: None
Device-1: Controller0-ChannelA-DIMM1 type: no module installed
Device-2: Controller1-ChannelA-DIMM1 type: no module installed
Device-3: Controller0-ChannelA-DIMM0 type: DDR4 size: 8 GiB
speed: 3200 MT/s
Device-4: Controller1-ChannelA-DIMM0 type: DDR4 size: 8 GiB
speed: 3200 MT/s
Still an issue for me btw ):
