Ram And İntel 5th gen cpu gpu Problem
ı dont know why ıf ı open mınecraft my system crashs and ı get much more worse perfromace than wındows specs pentium 3825u hd graphıcs 4gb ram… 128gb ssd 104gb not used how ı can fix it
can you report
inxi -Fza
ok
wait
Kernel: 7.2.11-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 16.2.1
clocksource: tsc avail: hpet,acpi_pm
parameters: initrd=\0906e415b71a4e2d8e490fcb32daab64\7.2.11-arch1-1\initrd
mitigations=off nvme_load=YES nowatchdog rw
root=UUID=8db702b6-5711-4f72-965e-43d0ada3979c
systemd.machine_id=0906e415b71a4e2d8e490fcb32daab64
Desktop: Cinnamon v: 6.6.9 tk: GTK v: 3.24.52 wm: Muffin v: 6.6.3 tools:
avail: cinnamon-screensaver vt: 7 dm: LightDM v: 1.33.1 Distro: EndeavourOS
base: Arch Linux
Type: Laptop System: HP product: HP Notebook v: Type1ProductConfigId
serial: Chassis: type: 10 serial:
Mobo: HP model: 80C1 v: 96.40 serial:
part-nu: N9T10EA#AB8 uuid: Firmware: UEFI
vendor: Insyde v: F.1B date: 10/19/2015
Battery:
ID-1: BAT1 charge: 22.1 Wh (100%) condition: 22.1/41.4 Wh (53.3%)
volts: 16.93 min: 14.8 model: COMPAL PABAS0241231 type: Li-ion
serial: charging: status: full cycles: N/A
Info: model: Intel Pentium 3825U bits: 64 type: MT MCP arch: Broadwell
level: v2 built: 2015-18 process: Intel 14nm family: 6 model-id: 0x3D (61)
stepping: 4 microcode: 0x2F
Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
smt: enabled cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB
desc: 2x256 KiB L3: 2 MiB desc: 1x2 MiB
Speed (MHz): avg: 1896 min/max: 500/1900 scaling: driver: intel_cpufreq
governor: performance cores: 1: 1896 2: 1896 3: 1896 4: 1896 bogomips: 15166
Flags-basic: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Vulnerabilities:
Type: gather_data_sampling status: Not affected
Type: ghostwrite status: Not affected
Type: indirect_target_selection status: Not affected
Type: itlb_multihit status: KVM: VMX unsupported
Type: l1tf mitigation: PTE Inversion
Type: mds status: Vulnerable; SMT vulnerable
Type: meltdown status: Vulnerable
Type: old_microcode status: Not affected
Type: reg_file_data_sampling status: Not affected
Type: spec_rstack_overflow status: Not affected
Type: spec_store_bypass status: Vulnerable
Type: spectre_v1 status: Vulnerable: __user pointer sanitization and
usercopy barriers only; no swapgs barriers
Type: spectre_v2 status: Vulnerable; IBPB: disabled; STIBP: disabled;
PBRSB-eIBRS: Not affected; BHI: Not affected
Type: srbds status: Vulnerable
Type: tsa status: Not affected
Type: vmscape status: Vulnerable
Device-1: Intel Broadwell-U GT1 [HD Graphics] vendor: Hewlett-Packard
driver: i915 v: kernel arch: Gen-8 process: Intel 14nm built: 2014-15 ports:
active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:1606
class-ID: 0300
Device-2: Realtek HP Truevision HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:4 chip-ID: 0bda:57d6
class-ID: 0e02 serial:
Display: x11 server: X.Org v: 21.1.25 with: Xwayland v: 24.1.14 driver: X:
loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: ChiMei InnoLux 0x15ca built: 2014 res:
mode: 1366x768 hz: 60 scale: 100% (1) dpi: 101 gamma: 1.2
size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9
modes: 1366x768
API: EGL v: 1.5 hw: drv: intel iris platforms: device: 0 drv: iris
device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
inactive: wayland
API: OpenGL v: 4.6 vendor: intel mesa v: 26.2.6-arch1.1 glx-v: 1.4
direct-render: yes renderer: Mesa Intel HD Graphics (BDW GT1)
device-ID: 8086:1606 memory: 3.64 GiB unified: yes
API: Vulkan v: 1.4.363 layers: 3 device: 0 type: integrated-gpu name: Intel
HD Graphics (BDW GT1) driver: mesa intel v: 26.2.6-arch1.1
device-ID: 8086:1606 surfaces: N/A
Info: Tools: api: eglinfo, glxinfo, vulkaninfo
x11: xdpyinfo, xprop, xrandr
Device-1: Intel Broadwell-U Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:160c
class-ID: 0403
Device-2: Intel Wildcat Point-LP High Definition Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:9ca0 class-ID: 0403
API: ALSA v: k7.2.11-arch1-1 status: kernel-api
Server-1: sndiod v: N/A status: off tools: aucat,midicat,sndioctl
Server-2: PipeWire v: 1.6.10 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Hewlett-Packard
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 4000
bus-ID: 07:00.0 chip-ID: 10ec:8136 class-ID: 0200
IF: enp7s0 state: down mac:
Device-2: Realtek RTL8723BE PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtl8723be v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 0d:00.0 chip-ID: 10ec:b723
class-ID: 0280
IF: wlan0 state: up mac:
Info: services: NetworkManager, systemd-timesyncd, wpa_supplicant
Bluetooth:
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 2.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:3 chip-ID: 0bda:b006
class-ID: e001 serial:
Report: btmgmt ID: hci0 rfk-id: 2 state: down bt-service: disabled
Local Storage: total: 119.24 GiB used: 20.44 GiB (17.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: KUIJIA model: Dahua C800 2.5 inch
SATA 128GB SSD size: 119.24 GiB block-size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s tech: SSD serial: fw-rev: 14B5 scheme: GPT
ID-1: / raw-size: 117.24 GiB size: 114.84 GiB (97.95%)
used: 20.31 GiB (17.7%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
Kernel: swappiness: 10 (default 60) cache-pressure: 50 (default 100)
zswap: no
ID-1: swap-1 type: zram size: 3.73 GiB used: 423.4 MiB (11.1%)
priority: 100 comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842
dev: /dev/zram0
System Temperatures: cpu: 47.0 C pch: 44.5 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 4 GiB available: 3.73 GiB used: 1.58 GiB (42.2%)
Processes: 207 Power: uptime: 2h 57m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 1 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 1.4 GiB services: csd-power,
power-profiles-daemon, upowerd Init: systemd v: 262 default: graphical
tool: systemctl
Packages: 1127 pm: pacman pkgs: 1114 libs: 295 tools: yay pm: flatpak
pkgs: 13 Compilers: clang: 23.1.4 gcc: 16.2.1 Shell: Bash v: 5.3.20
running-in: gnome-terminal inxi: 3.3.41
  • you should update your UEFI motherboard
  • you can add lm_sensors ( choose only uppercase value Y/n or y/N )
sudo pacman - S lm_sensors
sudo sensors-detect
sensors
cpupower frequency-info
sudo journalctl -b0 -p err
no ı dont want update my uefı ı lıke my mıcro code ı want FRESH speed
That is a misconception, the BIOS of your machine is most likely in its earliest revision when the system has been sold.
Updating the BIOS will not result in a worse performance, it’s most likely that I will function more reliably after upgrading it to the latest BIOS. And that critical system vulnerabilities might be fixed that way.
WHY meltdown spectre ıs so heavy for thıs cpu
It’s a Broadwell chip and it does support PCID as well as INVPCID instruction sets, that would reduce the performance penalty for the Spectre as well as Meltdown mitigations.
Additionally, the performance hit on windows systems didn’t translate directly to linux, as only specific workloads has been affected.
thank you but ı want smooth gamıng thanks
“Smooth gaming” is not a realistic expectation with these..
  • Intel Pentium Processor 3825U - An entry-level, ultra-low-voltage mobile CPU launched by Intel in Q1 2015 based on the 5th generation Broadwell architecture.
  • Intel Broadwell-U GT1 [HD Graphics] - An integrated graphics processor released by Intel in Q1 2015 based on the Generation 8.0 architecture
  • RAM - 4 GiB available: 3.73 GiB used: 1.58 GiB (42.2%)
ı know ıts too bad ıcant afford a new one
