Everything is OK, you can safely ignore Failed to get PCI ID, error number -13 messages, its just the driver trying different rendering nodes on older hardware. You have direct and accelerated rendering, and opengl/3d is working fine. You also confirmed that radeontop is working so the issue is with the system monitor program. You mentioned you are using KDE, so I guess you are using KSysGuard System Monitor. Well, it will not show the usage there because the driver is not exposing its GPU usage properties to kernel’s interface.
How do I know this? I’ve finally managed to find my old Radeon HD 7850 and test it
Its the same generation (Southern Islands), does not support vulkan and I am getting same PCI errors for eglinfo
My inxi -Ga
Device-1: Intel IvyBridge GT2 [HD Graphics 4000] vendor: Gigabyte
driver: i915 v: kernel arch: Gen-7 process: Intel 22nm built: 2012-13 ports:
active: none empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2, VGA-1 bus-ID: 00:02.0
chip-ID: 8086:0162 class-ID: 0380
Device-2: AMD Pitcairn PRO [Radeon HD 7850 / R7 265 R9 270 1024SP]
vendor: Micro-Star MSI driver: radeon v: kernel alternate: amdgpu
arch: GCN-1 code: Southern Islands process: TSMC 28nm built: 2011-20 pcie:
gen: 3 speed: 8 GT/s lanes: 16 ports: active: HDMI-A-3
empty: DP-3,DP-4,DVI-I-1 bus-ID: 01:00.0 chip-ID: 1002:6819 class-ID: 0300
temp: 36.0 C
Display: x11 server: X.Org v: 21.1.6 compositor: kwin_x11 driver: X:
loaded: modesetting,radeon alternate: fbdev,intel,vesa dri: radeonsi,crocus
gpu: radeon display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 676x380mm (26.61x14.96")
s-diag: 775mm (30.53")
Monitor-1: HDMI-A-3 mapped: HDMI-2 model: LG (GoldStar) Ultra HD
serial: 146047 built: 2018 res: 2560x1440 hz: 60 dpi: 108 gamma: 1.2
size: 600x340mm (23.62x13.39") diag: 690mm (27.2") ratio: 16:9 modes:
max: 3840x2160 min: 640x480
API: OpenGL v: 4.5 Mesa 22.3.3 renderer: PITCAIRN ( LLVM 15.0.7 DRM 2.50
6.1.8-arch1-1) direct render: Yes
My glxinfo -B
name of display: :0
display: :0 screen: 0
direct rendering: Yes
Extended renderer info (GLX_MESA_query_renderer):
Vendor: AMD (0x1002)
Device: PITCAIRN (, LLVM 15.0.7, DRM 2.50, 6.1.8-arch1-1) (0x6819)
Version: 22.3.3
Accelerated: yes
Video memory: 2048MB
Unified memory: no
Preferred profile: core (0x1)
Max core profile version: 4.5
Max compat profile version: 4.5
Max GLES1 profile version: 1.1
Max GLES[23] profile version: 3.2
Memory info (GL_ATI_meminfo):
VBO free memory - total: 1367 MB, largest block: 1367 MB
VBO free aux. memory - total: 1994 MB, largest block: 1994 MB
Texture free memory - total: 1367 MB, largest block: 1367 MB
Texture free aux. memory - total: 1994 MB, largest block: 1994 MB
Renderbuffer free memory - total: 1367 MB, largest block: 1367 MB
Renderbuffer free aux. memory - total: 1994 MB, largest block: 1994 MB
Memory info (GL_NVX_gpu_memory_info):
Dedicated video memory: 2048 MB
Total available memory: 4091 MB
Currently available dedicated video memory: 1367 MB
OpenGL vendor string: AMD
OpenGL renderer string: PITCAIRN (, LLVM 15.0.7, DRM 2.50, 6.1.8-arch1-1)
OpenGL core profile version string: 4.5 (Core Profile) Mesa 22.3.3
OpenGL core profile shading language version string: 4.50
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL version string: 4.5 (Compatibility Profile) Mesa 22.3.3
OpenGL shading language version string: 4.50
OpenGL context flags: (none)
OpenGL profile mask: compatibility profile
OpenGL ES profile version string: OpenGL ES 3.2 Mesa 22.3.3
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
The only thing exposed to hwmon via lm_sensors interface is the GPU temperature (rerun sensors-detect and answer yes everywhere if you don’t see it)
But not all is lost if you want GUI for monitoring the GPU. There is a cool app in AUR for displaying all kinds of info for cards using radeon driver (you can also set the power profiles and fan curve) called radeon-profile. It works good with my card and is showing the same usage as radeontop
To install it run
yay -S radeon-profile-git radeon-profile-daemon-git
sudo systemctl enable --now radeon-profile-daemon.service
