Quick question: Do I still need unzip
when Ark
is installed?
I also installed unrar
and libunrar
because I occasionally need to unpack rar
archives. Ark
seems to be able to handle it. What makes unzip
better?
when Ark
is installed?
and libunrar
archives. Ark
better?
I don’t think you need unzip
. However, some of the other tools are used by ark
$ yay -Si ark
Repository : extra
Version : 21.04.2-1
Description : Archiving Tool
Architecture : x86_64
URL : https://apps.kde.org/ark/
Licenses : GPL
Groups : kde-applications kde-utilities
Provides : None
Depends On : kparts kpty libarchive libzip kitemmodels hicolor-icon-theme
Optional Deps : p7zip: 7Z format support
unrar: RAR decompression support
unarchiver: RAR format support
lzop: LZO format support
lrzip: LRZ format support
Conflicts With : None
Replaces : None
Download Size : 1411.83 KiB
Installed Size : 4415.79 KiB
Packager : Antonio Rojas <arojas@archlinux.org>
Build Date : Tue 08 Jun 2021 06:08:14 AM CDT
Validated By : MD5 Sum SHA-256 Sum Signature
I think it is not about one being “better”, more a matter of what you prefer.
thx @dalto
I don’t think so either. I just installed Ark on an Arch install and it gives me right click extract archive here etc.
If you use KDE, just enable “open archives as (in?) folders” in Dolphin. Problem solved. Just one click on the archive.
