I’ve never really noticed it before. I have two monitors. One LG as primary and one Ilyama as secondary. Is it normal that the windows in the monitors are displayed as active and inactive windows? Active is opaque and inactive is 75% transparent.
How do I get an active window with 100% opacity on each monitor?
Yes exactly, these are the settings.
Basically, however, I would like to have each monitor set so that it does not display the window as inactive. Is that possible? I have not yet found a way to do this. Perhaps a Kwin setting?
Thank you for the detailed answer. This is exactly how I imagined it would behave, as you explained it to me.
I will probably have to deactivate transparent completely.
As soon as a terminal is open on the other screen, it’s not a problem. However, I obviously became aware of it for the first time last night when I wanted to watch a football match on one monitor and I could always see the background shining through.
It looks like my question has been answered. Thank you very much
