Qgnomeplatform-qt5-git fails to build
==> Making package: qgnomeplatform-git 0.7.0.r78.g6505fb8-1 (Thu 07 Sep 2023 14:09:51 EEST)
==> Checking runtime dependencies...
==> Checking buildtime dependencies...
==> Retrieving sources...
  -> Cloning QGnomePlatform git repo...
Cloning into bare repository '/var/tmp/pamac-build-radu/qgnomeplatform-git/QGnomePlatform'...
==> Validating source files with sha256sums...
    QGnomePlatform ... Skipped
==> Removing existing $srcdir/ directory...
==> Extracting sources...
  -> Creating working copy of QGnomePlatform git repo...
Cloning into 'QGnomePlatform'...
done.
==> Starting pkgver()...
==> Updated version: qgnomeplatform-git 0.7.0.r99.gd86d6ba-1
==> Starting build()...
CMake Warning (dev) at CMakeLists.txt:1 (project):
  cmake_minimum_required() should be called prior to this top-level project()
  call.  Please see the cmake-commands(7) manual for usage documentation of
  both commands.
This warning is for project developers.  Use -Wno-dev to suppress it.
-- The C compiler identification is GNU 13.2.1
-- The CXX compiler identification is GNU 13.2.1
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: /usr/bin/cc - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++ - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
CMake Deprecation Warning at CMakeLists.txt:3 (cmake_minimum_required):
  Compatibility with CMake < 3.5 will be removed from a future version of
  CMake.
  Update the VERSION argument <min> value or use a ...<max> suffix to tell
  CMake that the project does not need compatibility with older versions.
CMake Error at /usr/lib/cmake/Qt5/Qt5Config.cmake:28 (find_package):
  Could not find a package configuration file provided by "Qt5QuickControls2"
  with any of the following names:
    Qt5QuickControls2Config.cmake
    qt5quickcontrols2-config.cmake
  Add the installation prefix of "Qt5QuickControls2" to CMAKE_PREFIX_PATH or
  set "Qt5QuickControls2_DIR" to a directory containing one of the above
  files.  If "Qt5QuickControls2" provides a separate development package or
  SDK, be sure it has been installed.
Call Stack (most recent call first):
  CMakeLists.txt:34 (find_package)
-- Configuring incomplete, errors occurred!
==> ERROR: A failure occurred in build().
    Aborting...
Any idea hot to solve this?
missing dependency?
pacman -Qs qt5-quickcontrols2
Yup, that did it.
