internal error: firewalld is set to use the nftables backend, but the required firewalld ‘libvirt’ zone is missing. Either set the firewalld backend to ‘iptables’, or ensure that firewalld has a ‘libvirt’ zone by upgrading firewalld to a version supporting rule priorities (0.7.0+) and/or rebuilding libvirt with --with-firewalld-zone
Try this:
sudo pacman -S iptables-nft
It will ask you to replace nftables
. Then reboot and check if it’s fixed.
