I am using EOS lts with i3 I installed python3 it works. But I am looking for the IDLE(I know I can use the command line - python3 - as a REPL. I was looking in the Arch/AUR for python3 IDLE. Is there no python3 idle for EOS/Arch based linux??
Cheers
idle is included in the python package.
python
If you want a .desktop for it, you can install idle from the AUR.
idle
thank you @dalto
Note: Recently I’ve also needed to install python-tests, otherwise idle would fail at launch.
Thanks I had to add the tk package
