Hi. It’s my first time using EOS and I don’t know how to install “pycharm community”. I don’t want to do this with “snap”. How to do it?
It is in the repos.
sudo pacman -Syu pycharm-community-edition
The file /var/cache/pkg/pycharm-community-edition-2022.2.2-1.x86_64.pkg.tar.zst is corrupted (Invalid or damaged package (PGP description)
Do you want to delete it?
I give yes - it does not work
I give no - does not work
nice that it works
when it comes to how to install pycharm then the comment from @dalto is the solution.
