PulseAudio vs PipeWire. Both installed at once = audio issues?
Hi!
Are these two performing the same function, or are both needed? I have started having audio issues upon boot and wake from sleep. If I change between stereo and duplex, it comes back.
Uncertain how to troubleshoot this, so any help would be greatly appreciated! Thanks :smiley:
inxi -A
Device-1: Advanced Micro Devices [AMD/ATI] Radeon High Definition Audio
[Rembrandt/Strix] driver: snd_hda_intel
Device-2: Advanced Micro Devices [AMD] Audio Coprocessor
driver: snd_pci_ps
Device-3: Advanced Micro Devices [AMD] Family 17h/19h/1ah HD Audio
API: ALSA v: k6.12.53-1-lts status: kernel-api
Server-1: PipeWire v: 1.4.9 status: active
Server-2: PulseAudio v: 17.0-88-geee0 status: active
Hello,
pactl info
should tell you what you’re using, in my case, it’s Pulseaudio on Pipewire :
Server Name: PulseAudio (on PipeWire 1.4.9)
meaning it can use Pulseaudio clients on a Pipewire server.
Yes, only install one of them, usually it should be pipewire nowadays.
Reinstall the pipewire wireplumber pipewire-pulse pipewire-jack pipewire-alsa packages for a minimal pipewire audio stack, it should automatically conflict with pulseaudio and ask to remove it.
Thanks for your reply! Figured it out based on the packages you mentioned. Appreciate it.
I’ll leave what I did for anyone else having a similar issue.
_____________________________________________________________________________
Ok, I removed the dependencies and installed the packages you mentioned. Upon reboot my audio output is completely gone. I suppose the services are not running.
I removed pulseaudio, and it’s showing server name: PulseAudio (on PipeWire 1.4.9) now.
Issue now is I have no audio device :joy:
systemctl start pipewire-pulse.socket gives error:
Failed to start pipewire-pulse.service: Unit pipewire-pulse.service not found.
Which confuses me, since it is installed.
Update:
systemctl status –user pipewire-* wireplumber lists pipewire-pulse.service and .socket running.
aplay -l lists the output devices. HD-Audio Generic x3. One HDMI, one ALC287 Analogue.
Still, got no audio tab in settings menu after I removed the pulseaudio and reinstalled pipewire + dependencies. Nor any output in task tray.
Update 2:
alsamixer works! So I can adjust the volume and I get audio now, but I have lost the interface in the Os. Any idea on how to get that back? Vol hotkeys on keyboard doesn’t work either.
Update 3:
Reinstalled plasma-pa. GUI for audio in tray and in settings is now back. Though I got a bunch of audio units I am not using, so will have to figure out how to remove those. Seems to be working now though.
Source: https://wiki.archlinux.org/title/PipeWire / https://wiki.archlinux.org/title/Advanced_Linux_Sound_Architecture /
Thanks! I guess there was a conflict with both trying to run at the same time as the main audio service.
