PSA about lib32-amdvlk on nvidia system
I just found out why I couldn’t run Elden Ring or Tomb Raider (2013), while a number of other games worked just fine. The reddit thread below put me on the right path. I had lib32-amdvlk installed. Uninstalling it instantly fixed both those games.
I checked the logs, and it was installed a second before, and likely as a dependency for, steam:
https://archlinux.org/packages/multilib/x86_64/steam/
https://www.reddit.com/r/linux_gaming/comments/rxr6d0/strange_dxvk_error_failed_to_create_instance_res1/
So this is a nice little trap… I’m not sure how I would have figure it out if I had not been lucky enough to run into that thread…
It is a possible dependency for steam. While installing steam, the installer asks you which graphic libs to install. You maybe installed amdvlk instead of nvidia-utils.
Seems that way, doesn’t it?
I don’t remember doing it at the time, but that doesn’t mean much. Anyway, the point is, so long as that package is there, it preempts its nividia counterpart and OOOOOHHHH
… I just realised that’s why Steam still reported MESA as my video driver; that was bugging me… but other places reported the correct version, so I didn’t worry overmuch… (now it reports Nvidia, as expected)
… maybe that’s because Steam is 32 bits — so is EAC, iirc; so that would match Elden Ring online being a problem (it worked with EAC deactivated).
Things start making sense…
Additional Note: I didn’t install amdvlk, just lib32-amdvlk during steam installation; which was from a script with --noconfirm.
So elder ring now works without the flat pack version of steam?
Elden ring runs fine for me. 5800x 6700xt I just install steam (not native) and vulkan-radeo then enable beta access to steam and use proton experimental.
I can make it work only on flatpak steam, strange
