I am having a few issue getting protonvpn to work using OpenVPN. I am following the arch wiki guide https://wiki.archlinux.org/index.php/ProtonVPN#Setup. I gotten stuck in where it says Follow these steps to make sure that all your network traffic uses VPN. In there it talks of a .conf file. This File i do not have i do have a .opvn file which does seem to contain all the elements that would be in the .conf file. I am not sure if i should separate the .opvn file into parts (cert,key and config)? I have downloaded the update-systemd-resolved script from github.
Sample config file from Arch Linux Wiki
client
remote elmer.acmecorp.org 1194
user nobody
group nobody
ca ca.crt
cert client.crt
key client.key
tls-crypt ta.key # Replaces tls-auth ta.key 1
I have seen that the certificates are inside the ovpn files provided. I have seen that perhaps this should make the client.config file different. How do I deal with inline certificates?
