I installed processing language, and I am able to open it up just fine.
However when I run it I get a bunch of different errors:
Exception in thread "Thread-7" java.lang.RuntimeException: Exception while attempting /usr/lib/jvm/java-8-openjdk/bin/java -agentlib:jdwp=transport=dt_socket,address=8200,server=y,suspend=y,quiet=y -Djna.nosys=true -Djava.ext.dirs=/usr/lib/jvm/java-8-openjdk/lib/ext -Djava.library.path=:/usr/share/processing/core/library:/usr/java/packages/lib/amd64:/usr/lib64:/lib64:/lib:/usr/lib -cp /tmp/sketch_201013a610259254011698223temp:/usr/share/processing/core/library/gluegen-rt-natives-linux-i586.jar:/usr/share/processing/core/library/jogl-all-natives-windows-i586.jar:/usr/share/processing/core/library/core.jar:/usr/share/processing/core/library/jogl-all-natives-macosx-universal.jar:/usr/share/processing/core/library/gluegen-rt-natives-linux-armv6hf.jar:/usr/share/processing/core/library/gluegen-rt-natives-macosx-universal.jar:/usr/share/processing/core/library/gluegen-rt-natives-linux-amd64.jar:/usr/share/processing/core/library/jogl-all-natives-linux-aarch64.jar:/usr/share/processing/core/library/gluegen-rt.jar:/usr/share/processing/core/library/jogl-all-natives-linux-i586.jar:/usr/share/processing/core/library/jogl-all.jar:/usr/share/processing/core/library/jogl-all-natives-linux-armv6hf.jar:/usr/share/processing/core/library/gluegen-rt-natives-windows-i586.jar:/usr/share/processing/core/library/gluegen-rt-natives-linux-aarch64.jar:/usr/share/processing/core/library/jogl-all-natives-windows-amd64.jar:/usr/share/processing/core/library/gluegen-rt-natives-windows-amd64.jar:/usr/share/processing/core/library/jogl-all-natives-linux-amd64.jar:/usr/lib/jvm/java-8-openjdk/jre/lib/rt.jar:/usr/share/processing/lib/ant.jar:/usr/share/processing/lib/ant-launcher.jar:/usr/share/processing/lib/jna.jar:/usr/share/processing/lib/jna-platform.jar:/usr/share/processing/lib/pde.jar:/usr/share/processing/core/library/core.jar:/usr/share/processing/core/library/gluegen-rt.jar:/usr/share/processing/core/library/gluegen-rt-natives-linux-aarch64.jar:/usr/share/processing/core/library/gluegen-rt-natives-linux-amd64.jar:/usr/share/processing/core/library/gluegen-rt-natives-linux-armv6hf.jar:/usr/share/processing/core/library/gluegen-rt-natives-linux-i586.jar:/usr/share/processing/core/library/gluegen-rt-natives-macosx-universal.jar:/usr/share/processing/core/library/gluegen-rt-natives-windows-amd64.jar:/usr/share/processing/core/library/gluegen-rt-natives-windows-i586.jar:/usr/share/processing/core/library/jogl-all.jar:/usr/share/processing/core/library/jogl-all-natives-linux-aarch64.jar:/usr/share/processing/core/library/jogl-all-natives-linux-amd64.jar:/usr/share/processing/core/library/jogl-all-natives-linux-armv6hf.jar:/usr/share/processing/core/library/jogl-all-natives-linux-i586.jar:/usr/share/processing/core/library/jogl-all-natives-macosx-universal.jar:/usr/share/processing/core/library/jogl-all-natives-windows-amd64.jar:/usr/share/processing/core/library/jogl-all-natives-windows-i586.jar:/usr/share/processing/modes/java/mode/antlr.jar:/usr/share/processing/modes/java/mode/classpath-explorer-1.0.jar:/usr/share/processing/modes/java/mode/com.ibm.icu.jar:/usr/share/processing/modes/java/mode/JavaMode.jar:/usr/share/processing/modes/java/mode/jdi.jar:/usr/share/processing/modes/java/mode/jdimodel.jar:/usr/share/processing/modes/java/mode/jdtCompilerAdapter.jar:/usr/share/processing/modes/java/mode/jsoup-1.7.1.jar:/usr/share/processing/modes/java/mode/org.eclipse.core.contenttype.jar:/usr/share/processing/modes/java/mode/org.eclipse.core.jobs.jar:/usr/share/processing/modes/java/mode/org.eclipse.core.resources.jar:/usr/share/processing/modes/java/mode/org.eclipse.core.runtime.jar:/usr/share/processing/modes/java/mode/org.eclipse.equinox.common.jar:/usr/share/processing/modes/java/mode/org.eclipse.equinox.preferences.jar:/usr/share/processing/modes/java/mode/org.eclipse.jdt.core.jar:/usr/share/processing/modes/java/mode/org.eclipse.osgi.jar:/usr/share/processing/modes/java/mode/org.eclipse.text.jar:/usr/share/processing/modes/java/mode/org.netbeans.swing.outline.jar -ea processing.core.PApplet --display=-1 --sketch-path=/tmp/untitled1894016874808851229sketches/sketch_201013a sketch_201013a
at processing.core.PApplet.exec(PApplet.java:3570)
at processing.mode.java.runner.Runner$1.run(Runner.java:498)
at java.lang.Thread.run(Thread.java:748)
Caused by: java.io.IOException: Cannot run program "/usr/lib/jvm/java-8-openjdk/bin/java": error=2, No such file or directory
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1048)
at java.lang.Runtime.exec(Runtime.java:621)
at java.lang.Runtime.exec(Runtime.java:486)
at processing.core.PApplet.exec(PApplet.java:3568)
... 2 more
Caused by: java.io.IOException: error=2, No such file or directory
at java.lang.UNIXProcess.forkAndExec(Native Method)
at java.lang.UNIXProcess.<init>(UNIXProcess.java:247)
at java.lang.ProcessImpl.start(ProcessImpl.java:134)
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1029)
... 5 more
It appears that Java is installed on my system as when I type java in terminal, then it outputs some java related stuff:
Usage: java [-options] class [args...]
(to execute a class)
or java [-options] -jar jarfile [args...]
(to execute a jar file)
where options include:
-d32 use a 32-bit data model if available
-d64 use a 64-bit data model if available
-server to select the "server" VM
The default VM is server,
because you are running on a server-class machine.
-cp <class search path of directories and zip/jar files>
-classpath <class search path of directories and zip/jar files>
A : separated list of directories, JAR archives,
and ZIP archives to search for class files.
-D<name>=<value>
set a system property
-verbose:[class|gc|jni]
enable verbose output
-version print product version and exit
-version:<value>
Warning: this feature is deprecated and will be removed
in a future release.
require the specified version to run
-showversion print product version and continue
-jre-restrict-search | -no-jre-restrict-search
include/exclude user private JREs in the version search
-? -help print this help message
-X print help on non-standard options
-ea[:<packagename>...|:<classname>]
-enableassertions[:<packagename>...|:<classname>]
enable assertions with specified granularity
-da[:<packagename>...|:<classname>]
-disableassertions[:<packagename>...|:<classname>]
disable assertions with specified granularity
-esa | -enablesystemassertions
enable system assertions
-dsa | -disablesystemassertions
disable system assertions
-agentlib:<libname>[=<options>]
load native agent library <libname>, e.g. -agentlib:hprof
see also, -agentlib:jdwp=help and -agentlib:hprof=help
-agentpath:<pathname>[=<options>]
load native agent library by full pathname
-javaagent:<jarpath>[=<options>]
load Java programming language agent, see java.lang.instrument
-splash:<imagepath>
show splash screen with specified image
See http://www.oracle.com/technetwork/java/javase/documentation/index.html
