This is very rare, wine was uninstalled by “itsefl”?.
Then now i’m trying to install again from octopi and there are many errors. The same with the line of commands.
Installing selected packages...
resolving dependencies...
warning: dependency cycle detected:
warning: lib32-harfbuzz will be installed before its lib32-freetype2 dependency
warning: lib32-mesa will be installed before its lib32-libglvnd dependency
Packages (64) faudio-20.08-2 glu-9.0.1-2 lib32-acl-2.2.53-1 lib32-attr-2.4.48-1 lib32-bzip2-1.0.8-2 lib32-dbus-1.12.20-1
lib32-expat-2.2.9-1 lib32-faudio-20.08-1 lib32-fontconfig-2:2.13.91+48+gfcb0420-2 lib32-freetype2-2.10.2-1
lib32-gcc-libs-10.1.0-2 lib32-gettext-0.20.2-1 lib32-glib2-2.64.4-1 lib32-glibc-2.31-5 lib32-glu-9.0.1-1
lib32-harfbuzz-2.7.1-1 lib32-icu-67.1-1 lib32-lcms2-2.11-1 lib32-libcap-2.38-1 lib32-libdrm-2.4.102-1
lib32-libelf-0.180-1 lib32-libffi-3.3-2 lib32-libgcrypt-1.8.6-1 lib32-libglvnd-1.3.2-1 lib32-libgpg-error-1.38-1
lib32-libice-1.0.10-1 lib32-libjpeg-turbo-2.0.5-1 lib32-libnl-3.5.0-1 lib32-libpcap-1.9.1-1
lib32-libpciaccess-0.16-1 lib32-libpng-1.6.37-3 lib32-libsm-1.2.3-1 lib32-libtiff-4.1.0-1 lib32-libunwind-1.3.1-1
lib32-libusb-1.0.23-1 lib32-libx11-1.6.10-1 lib32-libxau-1.0.9-1 lib32-libxcb-1.14-1 lib32-libxcursor-1.2.0-1
lib32-libxdamage-1.1.5-1 lib32-libxdmcp-1.1.3-1 lib32-libxext-1.3.4-1 lib32-libxfixes-5.0.3-2
lib32-libxi-1.7.10-2 lib32-libxml2-2.9.10-2 lib32-libxrandr-1.5.2-1 lib32-libxrender-0.9.10-2
lib32-libxshmfence-1.3-2 lib32-libxxf86vm-1.1.4-2 lib32-llvm-libs-10.0.1-1 lib32-lm_sensors-3.6.0-1
lib32-lz4-1.9.2-1 lib32-mesa-20.1.5-1 lib32-ncurses-6.2-1 lib32-pcre-8.44-1 lib32-readline-8.0.0-1
lib32-sdl2-2.0.12-1 lib32-systemd-246.1-1 lib32-util-linux-2.35.2-1 lib32-wayland-1.18.0-2 lib32-xz-5.2.5-1
lib32-zlib-1.2.11-2 lib32-zstd-1.4.5-1 wine-5.15-1
Total Download Size: 229.10 MiB
Total Installed Size: 1300.78 MiB
:: Retrieving packages...
error: failed retrieving file 'lib32-glibc-2.31-5-x86_64.pkg.tar.zst' from mirror.wdc1.us.leaseweb.net : The requested URL returned error: 404
error: failed retrieving file 'lib32-glibc-2.31-5-x86_64.pkg.tar.zst' from arch.mirror.square-r00t.net : The requested URL returned error: 404
error: failed retrieving file 'lib32-glibc-2.31-5-x86_64.pkg.tar.zst' from mirror.dal10.us.leaseweb.net : The requested URL returned error: 404
error: failed retrieving file 'lib32-glibc-2.31-5-x86_64.pkg.tar.zst' from mirror.kaminski.io : The requested URL returned error: 404
error: failed retrieving file 'lib32-glibc-2.31-5-x86_64.pkg.tar.zst' from mirror.mia11.us.leaseweb.net : The requested URL returned error: 404
error: failed retrieving file 'lib32-glibc-2.31-5-x86_64.pkg.tar.zst' from arch.mirror.constant.com : The requested URL returned error: 404
error: failed retrieving file 'lib32-glibc-2.31-5-x86_64.pkg.tar.zst' from mirror.stephen304.com : The requested URL returned error: 404
error: failed retrieving file 'lib32-glibc-2.31-5-x86_64.pkg.tar.zst' from mirror.sfo12.us.leaseweb.net : The requested URL returned error: 404
error: failed retrieving file 'lib32-glibc-2.31-5-x86_64.pkg.tar.zst' from iad.mirrors.misaka.one : The requested URL returned error: 404
error: failed retrieving file 'lib32-glibc-2.31-5-x86_64.pkg.tar.zst' from mirror.dc02.hackingand.coffee : SSL certificate problem: certificate has expired
warning: failed to retrieve some files
error: failed retrieving file 'lib32-gcc-libs-10.1.0-2-x86_64.pkg.tar.zst' from mirror.wdc1.us.leaseweb.net : The requested URL returned error: 404
error: failed retrieving file 'lib32-gcc-libs-10.1.0-2-x86_64.pkg.tar.zst' from arch.mirror.square-r00t.net : The requested URL returned error: 404
error: failed retrieving file 'lib32-gcc-libs-10.1.0-2-x86_64.pkg.tar.zst' from mirror.dal10.us.leaseweb.net : The requested URL returned error: 404
error: failed retrieving file 'lib32-gcc-libs-10.1.0-2-x86_64.pkg.tar.zst' from mirror.kaminski.io : The requested URL returned error: 404
error: failed retrieving file 'lib32-gcc-libs-10.1.0-2-x86_64.pkg.tar.zst' from mirror.mia11.us.leaseweb.net : The requested URL returned error: 404
error: failed retrieving file 'lib32-gcc-libs-10.1.0-2-x86_64.pkg.tar.zst' from arch.mirror.constant.com : The requested URL returned error: 404
error: failed retrieving file 'lib32-gcc-libs-10.1.0-2-x86_64.pkg.tar.zst' from mirror.stephen304.com : The requested URL returned error: 404
error: failed retrieving file 'lib32-gcc-libs-10.1.0-2-x86_64.pkg.tar.zst' from mirror.sfo12.us.leaseweb.net : The requested URL returned error: 404
error: failed retrieving file 'lib32-gcc-libs-10.1.0-2-x86_64.pkg.tar.zst' from iad.mirrors.misaka.one : The requested URL returned error: 404
error: failed retrieving file 'lib32-gcc-libs-10.1.0-2-x86_64.pkg.tar.zst' from mirror.dc02.hackingand.coffee : SSL certificate problem: certificate has expired
(1/64) glu-9.0.1-2-x86_64
(2/64) faudio-20.08-2-x86_64
(3/64) lib32-expat-2.2.9-1-x86_64
(4/64) lib32-zlib-1.2.11-2-x86_64
(5/64) lib32-bzip2-1.0.8-2-x86_64
(6/64) lib32-libpng-1.6.37-3-x86_64
(7/64) lib32-pcre-8.44-1-x86_64
(8/64) lib32-libffi-3.3-2-x86_64
(9/64) lib32-util-linux-2.35.2-1-x86_64
error: failed retrieving file 'lib32-glib2-2.64.4-1-x86_64.pkg.tar.zst' from mirror.wdc1.us.leaseweb.net : The requested URL returned error: 404
error: failed retrieving file 'lib32-glib2-2.64.4-1-x86_64.pkg.tar.zst' from arch.mirror.square-r00t.net : The requested URL returned error: 404
error: failed retrieving file 'lib32-glib2-2.64.4-1-x86_64.pkg.tar.zst' from mirror.dal10.us.leaseweb.net : The requested URL returned error: 404
error: failed retrieving file 'lib32-glib2-2.64.4-1-x86_64.pkg.tar.zst' from mirror.kaminski.io : The requested URL returned error: 404
error: failed retrieving file 'lib32-glib2-2.64.4-1-x86_64.pkg.tar.zst' from mirror.mia11.us.leaseweb.net : The requested URL returned error: 404
error: failed retrieving file 'lib32-glib2-2.64.4-1-x86_64.pkg.tar.zst' from arch.mirror.constant.com : The requested URL returned error: 404
error: failed retrieving file 'lib32-glib2-2.64.4-1-x86_64.pkg.tar.zst' from mirror.stephen304.com : The requested URL returned error: 404
error: failed retrieving file 'lib32-glib2-2.64.4-1-x86_64.pkg.tar.zst' from mirror.sfo12.us.leaseweb.net : The requested URL returned error: 404
error: failed retrieving file 'lib32-glib2-2.64.4-1-x86_64.pkg.tar.zst' from iad.mirrors.misaka.one : The requested URL returned error: 404
error: failed retrieving file 'lib32-glib2-2.64.4-1-x86_64.pkg.tar.zst' from mirror.dc02.hackingand.coffee : SSL certificate problem: certificate has expired
(10/64) lib32-harfbuzz-2.7.1-1-x86_64
(11/64) lib32-freetype2-2.10.2-1-x86_64
(12/64) lib32-fontconfig-2:2.13.91+48+gfcb0420-2-x86_64
(13/64) lib32-libjpeg-turbo-2.0.5-1-x86_64
(14/64) lib32-xz-5.2.5-1-x86_64
(15/64) lib32-lz4-1.9.2-1-x86_64
(16/64) lib32-zstd-1.4.5-1-x86_64
(17/64) lib32-libtiff-4.1.0-1-x86_64
(18/64) lib32-lcms2-2.11-1-x86_64
(19/64) lib32-ncurses-6.2-1-x86_64
(20/64) lib32-readline-8.0.0-1-x86_64
(21/64) lib32-icu-67.1-1-x86_64
(22/64) lib32-libxml2-2.9.10-2-x86_64
(23/64) lib32-libxdmcp-1.1.3-1-x86_64
(24/64) lib32-libxau-1.0.9-1-x86_64
(25/64) lib32-libxcb-1.14-1-x86_64
error: failed retrieving file 'lib32-libx11-1.6.10-1-x86_64.pkg.tar.zst' from mirror.wdc1.us.leaseweb.net : The requested URL returned error: 404
error: failed retrieving file 'lib32-libx11-1.6.10-1-x86_64.pkg.tar.zst' from arch.mirror.square-r00t.net : The requested URL returned error: 404
error: failed retrieving file 'lib32-libx11-1.6.10-1-x86_64.pkg.tar.zst' from mirror.dal10.us.leaseweb.net : The requested URL returned error: 404
error: failed retrieving file 'lib32-libx11-1.6.10-1-x86_64.pkg.tar.zst' from mirror.kaminski.io : The requested URL returned error: 404
error: failed retrieving file 'lib32-libx11-1.6.10-1-x86_64.pkg.tar.zst' from mirror.mia11.us.leaseweb.net : The requested URL returned error: 404
error: failed retrieving file 'lib32-libx11-1.6.10-1-x86_64.pkg.tar.zst' from arch.mirror.constant.com : The requested URL returned error: 404
error: failed retrieving file 'lib32-libx11-1.6.10-1-x86_64.pkg.tar.zst' from mirror.stephen304.com : The requested URL returned error: 404
error: failed retrieving file 'lib32-libx11-1.6.10-1-x86_64.pkg.tar.zst' from mirror.sfo12.us.leaseweb.net : The requested URL returned error: 404
error: failed retrieving file 'lib32-libx11-1.6.10-1-x86_64.pkg.tar.zst' from iad.mirrors.misaka.one : The requested URL returned error: 404
error: failed retrieving file 'lib32-libx11-1.6.10-1-x86_64.pkg.tar.zst' from mirror.dc02.hackingand.coffee : SSL certificate problem: certificate has expired
(26/64) lib32-libxfixes-5.0.3-2-x86_64
(27/64) lib32-libxrender-0.9.10-2-x86_64
(28/64) lib32-libxcursor-1.2.0-1-x86_64
(29/64) lib32-libxext-1.3.4-1-x86_64
(30/64) lib32-libxrandr-1.5.2-1-x86_64
(31/64) lib32-libxdamage-1.1.5-1-x86_64
(32/64) lib32-libxi-1.7.10-2-x86_64
(33/64) lib32-attr-2.4.48-1-x86_64
(34/64) lib32-acl-2.2.53-1-x86_64
(35/64) lib32-gettext-0.20.2-1-x86_64
(36/64) lib32-libpciaccess-0.16-1-x86_64
(37/64) lib32-libdrm-2.4.102-1-x86_64
(38/64) lib32-wayland-1.18.0-2-x86_64
(39/64) lib32-libxxf86vm-1.1.4-2-x86_64
(40/64) lib32-libxshmfence-1.3-2-x86_64
(41/64) lib32-libelf-0.180-1-x86_64
(42/64) lib32-libunwind-1.3.1-1-x86_64
(43/64) lib32-llvm-libs-10.0.1-1-x86_64
(44/64) lib32-lm_sensors-3.6.0-1-x86_64
error: failed retrieving file 'lib32-mesa-20.1.5-1-x86_64.pkg.tar.zst' from mirror.wdc1.us.leaseweb.net : The requested URL returned error: 404
error: failed retrieving file 'lib32-mesa-20.1.5-1-x86_64.pkg.tar.zst' from arch.mirror.square-r00t.net : The requested URL returned error: 404
error: failed retrieving file 'lib32-mesa-20.1.5-1-x86_64.pkg.tar.zst' from mirror.dal10.us.leaseweb.net : The requested URL returned error: 404
error: failed retrieving file 'lib32-mesa-20.1.5-1-x86_64.pkg.tar.zst' from mirror.kaminski.io : The requested URL returned error: 404
error: failed retrieving file 'lib32-mesa-20.1.5-1-x86_64.pkg.tar.zst' from mirror.mia11.us.leaseweb.net : The requested URL returned error: 404
error: failed retrieving file 'lib32-mesa-20.1.5-1-x86_64.pkg.tar.zst' from arch.mirror.constant.com : The requested URL returned error: 404
error: failed retrieving file 'lib32-mesa-20.1.5-1-x86_64.pkg.tar.zst' from mirror.stephen304.com : The requested URL returned error: 404
error: failed retrieving file 'lib32-mesa-20.1.5-1-x86_64.pkg.tar.zst' from mirror.sfo12.us.leaseweb.net : The requested URL returned error: 404
error: failed retrieving file 'lib32-mesa-20.1.5-1-x86_64.pkg.tar.zst' from iad.mirrors.misaka.one : The requested URL returned error: 404
error: failed retrieving file 'lib32-mesa-20.1.5-1-x86_64.pkg.tar.zst' from mirror.dc02.hackingand.coffee : SSL certificate problem: certificate has expired
(45/64) lib32-libglvnd-1.3.2-1-x86_64
(46/64) lib32-glu-9.0.1-1-x86_64
(47/64) lib32-libice-1.0.10-1-x86_64
(48/64) lib32-libsm-1.2.3-1-x86_64
(49/64) lib32-libnl-3.5.0-1-x86_64
(50/64) lib32-libcap-2.38-1-x86_64
(51/64) lib32-libgpg-error-1.38-1-x86_64
(52/64) lib32-libgcrypt-1.8.6-1-x86_64
(53/64) lib32-libusb-1.0.23-1-x86_64
(54/64) lib32-libpcap-1.9.1-1-x86_64
(55/64) lib32-dbus-1.12.20-1-x86_64
(56/64) lib32-sdl2-2.0.12-1-x86_64
(57/64) lib32-faudio-20.08-1-x86_64
(58/64) wine-5.15-1-x86_64
error: failed to commit transaction (unexpected error)
Command finished with errors!
