Then I uninstall wine and install wine-staging and wine-tricks, but I have the same problem, doesn’t download the modules.
On Manjaro it works fine, I assume I might need something else to install here, and I rebember too that on Debian with ‘winehq’ it was working fine but i don’t see who to get it in AUR, any suggestions?.
Definitely the problem is with Wine, in order to check something, I go back to the e-sword application and when I pass the mouse cursor I see that the options were no longer frozen … I apply in each one of those that I need and all the modules enter; so that although it did not install wine-stable some ‘other thing’ this one put in that hour and a half that was compiling – and to confirm to me that it has been thus I went to the other machine (I am mounting Endeavouros in two laptops) and I make the same operation … same result, wine-stable fails but … it managed to install the modules.
Something is wrong with Wine that doesn’t work, something is missing; although in this ‘tricky’ way I managed to do it, I can’t consider the matter as solved – I just leave here a notification of what happened in case maybe some developer …
That software requires the Windows Media Player explicitly.
It’s just that I also have a chess program app, ‘Peshka’, that doesn’t open completely, it breaks, and it’s not the program because on other systems with wine9.9, wine9.15 and 16 installed no problems have occurred – there were no problems on them with e-sword either.
*winetricks was the first thing I installed and winetricks -q wmp11 did not solve the issue.
The problem occurs only in this version of wine.
Thanks.
[keos@keos-aspirea31558 ~]$ pacman -Qs wine
local/wine 9.20-1
A compatibility layer for running Windows programs
local/wine-gecko 2.47.4-2
Wine's built-in replacement for Microsoft's Internet Explorer
local/wine-mono 9.3.0-1
Wine's built-in replacement for Microsoft's .NET Framework
local/wine-nine 0.9-1
Gallium Nine Standalone
local/winetricks 20240105-1
Script to install various redistributable runtime libraries in Wine.
EDIT:
And to reconfirm to myself that it is this version of wine, I uninstalled > purged wine from the system and this time installed wine again from pacman like this:
