I’m running EndevourOS with i3 inside a VirtualMachine on Windows 10 (since I want to customise my theme and settings and I don’t want to do that in my live enviornment). I have everything running but even though I inserted “Guest Additions CD Image” and tried to install it with “yay” inside i3 I can’t get the screensize to change when I scale the VM window. It sadly also doesn’t work when I go into “View” and under “Virtual Screen 1” try to change the size.
I have followed the documentation on the main website how to get EndevourOS running in a VM, but still no luck. Does anyone happen to know what I might be missing / doing wrong?
I didn’t have the extpack installed I do now, not sure if I need to do anything extra to use it though?
And the output of pacman -Qs virtualbox says this:
local/linux 5.7.7.arch1-1
The Linux kernel and modules
local/virtualbox-guest-dkms 6.1.10-1
VirtualBox Guest kernel modules sources
local/virtualbox-guest-iso 6.1.10-1
The official VirtualBox Guest Additions ISO Image
local/virtualbox-guest-utils
VirtualBox Guest userspace utilities
