Hi,
I just installed endeavouros on my DELL XPS and after rebooting (I’m using gnome) the system is using x11. Id’ like to use wayland. I issued the following commands:
sudo systemctl enable nvidia-resume.service
sudo systemctl enable nvidia-hibernate.service
sudo systemctl enable nvidia-suspend.service
the command
cat /sys/module/nvidia_drm/parameters/modeset
reports Y
I create the file /sys/module/nvidia_drm/parameters/modeset with he the following content:
options nvidia NVreg_PreserveVideoMemoryAllocations=1 NVreg_TemporaryFilePath=/var/tmp
Is there anything I can check in order to enable wayland on gnome?
Please give me (if possible) the commands to execute, It’s not easy for me finding them in the documentation.
with sddm wayland works,
With GDM and the info app I saw the the graphic card listed was the intel one. Perhaps my system is not recognizing my nvidia card and is currently using only the intel one?
Thanks again
