Whenver I try to do anything involving yay, I get an error reading error while loading shared libraries: libalpm.so.15: cannot open shared object file: no such file or directory
I attempted the solution down here in the bottom link but I was told git and base-devel were both up to date and that destination path yay already exists and is not an empty directory.
I tried uninstalling yay through pacman, but I got the same message after attempting the solution again. What should I do?
I don’t have much knowledge on how to use rate-mirrors, and I can’t seem to open Welcome (I get an error saying "libgspell-1.so.3: cannot open shared object file: no such file or directory). Can you walk me through the steps I need to follow to resort my mirrors?
I followed the instructions and used sudo pacman -Syu, and the computer updated. However, I’m using a laptop and have a second monitor plugged in. After updating and restarting, only the monitor I’ve plugged in works, and when I go into display, the monitor I’ve got plugged in is the only one that shows up as an option. Is there some way I can ID the issue and fix this?
EDIT: I restarted my laptop with the second monitor disconnected. The laptop’s monitor does light up when booting up, but as soon as it’s done booting, it remains dark instead of revealing the login screen. I had to plug in the second monitor again to get a view of anything.
