Hello, I am on nvidia using gnome, i notused that on wayland the clipboard sometimes wont work. I tried various clipboard indicator extensions. Most of the times when i press one of the entries in the clipboard indicator it will not work. When i go to paste it will paste nothing. The clipboard woth 1 time out of 5. no idea what is going on.
I don’t have Nvidia card so I cannot talk to that.
However on GNOME-Wayland, I use clipboard-history:
https://extensions.gnome.org/extension/4839/clipboard-history/
It works fine on my end.
There is also gpaste in the repos. Have a go at it and see it works for you.
$ pacman -Si gpaste
Repository : extra
Version : 45-1
Description : Clipboard management system
Architecture : x86_64
URL : https://www.imagination-land.org/tags/GPaste.html
Licenses : BSD
Groups : None
Provides : None
Depends On : gcr-4 gtk3 gtk4 libadwaita
Optional Deps : wgetpaste: Upload clipboard contents
Conflicts With : None
Replaces : None
Download Size : 258.63 KiB
Installed Size : 1574.00 KiB
Packager : Jan Alexander Steffens (heftig) <heftig@archlinux.org>
Build Date : Wed 04 Oct 2023 01:44:07 AM CEST
Validated By : MD5 Sum SHA-256 Sum Signature
that clipboard-history plugin when i enable it, it wont even display on the app bar.
Works just fine on my end.
Can’t tell what might be the issue on your side since nothing of what you have tried so far has worked for you.
i isntalled gpanel and nothing changed, still the extension will work when it feels like… most of the times i click on a history item and when i paste it doesnt do anything. this is a clean endeavour install
It is definitely a problem with wayland i jsut dont know how to troubleshoot
Actually, since it works for the rest of us (AMD), I’m pretty sure you should say it’s a problem with Nvidia.
If I’m not mistaken the standard wayland behavior is to forget clipboard content from a window, if the window is closed. I don’t think that’s the root of your problem, but maybe check if that’s the issue before looking somewhere else.
Just copy some text from a window and then close the window. Then try to paste the clipboard content.
What environment are you using? this sounds like it could be caused by your compositor somehow since i think it’s supposed to be what handles basic copy-paste actions.
Make sure first that you have wl-clipboard installed
You could try using wl-clip-persist to make your clipboard persistent (remember clipboard after the application you copied from closes)
It hasn’t been updated in 2 years though and i’ve found it to be quite buggy, so I created a cliphist solution for persistent clipboard. (You need cliphist and wl-clipboard for this to work)
#!/bin/sh
previous="$(cliphist list | head -1 | awk '{$1=null; print $0}')"
cliphist store
current="$(cliphist list | head -1 | awk '{$1=null; print $0}')"
if [ "$current" != "$previous" ]; then
cliphist list | head -1 | cliphist decode | wl-copy
fi
Save the script as cliphist-persist
Then run it like this:
wl-paste --type text --watch /path/to/cliphist-persist
wl-paste --type image --watch /path/to/cliphist-persist
