Hey, so i’m having an issue with trying to duel boot my system, i currently have EOS and Kali Linux installed on my system, but Kali Linux never shows up on the Grub i have tried using os-prober and it does not seem to detect it and yes i did mount it.
i also tried manually adding it, It shows up but refuses to actually boot into the OS
Any other suggestions searched high and low for a solution but cant find anything.
Generating grub configuration file ...
Found theme: /boot/grub/themes/EndeavourOS/theme.txt
Found linux image: /boot/vmlinuz-linux
Found initrd image: /boot/amd-ucode.img /boot/initramfs-linux.img
Found fallback initrd image(s) in /boot: amd-ucode.img initramfs-linux-fallback.img
Warning: os-prober will be executed to detect other bootable partitions.
Its output will be used to detect bootable binaries on them and create new boot entries.
Adding boot menu entry for UEFI Firmware Settings ...
done
sudo grub-mkconfig -o /etc/grub.d
/usr/bin/grub-mkconfig: line 305: /etc/grub.d: Is a directory
manually trying to add the boot entry with 40_custom
#!/bin/sh
exec tail -n +3 $0
# This file provides an easy way to add custom menu entries. Simply type the
# menu entries you want to add after this comment. Be careful not to change
# the 'exec tail' line above.
menuentry "Kali Linux" {
search --set=root --fs-uuid ff42a029-4943-4164-9975-a3e8413a3ba9
linux /boot/vmlinuz-5.16.0-kali7-amd64 root=UUID=ff42a029-4943-4164-9975-a3e8413a3ba9 rw quiet
No, that would be overwritten each time Grub is updated. Make instead a custom.cfg file in /boot/grub and add the menu entry to it. No need to update grub afterwards.
# DO NOT EDIT THIS FILE
# It is automatically generated by grub-mkconfig using templates
# from /etc/grub.d and settings from /etc/default/grub
### BEGIN /etc/grub.d/00_header ###
if [ -s $prefix/grubenv ]; then
set have_grubenv=true
load_env
fi
if [ "${next_entry}" ] ; then
set default="${next_entry}"
set next_entry=
save_env next_entry
set boot_once=true
else
set default="0"
fi
if [ x"${feature_menuentry_id}" = xy ]; then
menuentry_id_option="--id"
else
menuentry_id_option=""
fi
export menuentry_id_option
if [ "${prev_saved_entry}" ]; then
set saved_entry="${prev_saved_entry}"
save_env saved_entry
set prev_saved_entry=
save_env prev_saved_entry
set boot_once=true
fi
function savedefault {
if [ -z "${boot_once}" ]; then
saved_entry="${chosen}"
fi
function load_video {
if [ x$feature_all_video_module = xy ]; then
insmod all_video
else
insmod efi_gop
insmod efi_uga
insmod ieee1275_fb
insmod vbe
insmod vga
insmod video_bochs
insmod video_cirrus
fi
if [ x$feature_default_font_path = xy ] ; then
font=unicode
else
insmod part_gpt
insmod btrfs
if [ x$feature_platform_search_hint = xy ]; then
search --no-floppy --fs-uuid --set=root 2837b27c-aa88-4c89-bf8a-44664ea0089d
else
fi
font="/@/usr/share/grub/unicode.pf2"
fi
if loadfont $font ; then
set gfxmode=1280x720,1280x800,auto
load_video
insmod gfxterm
set locale_dir=$prefix/locale
set lang=en_GB
insmod gettext
fi
terminal_output gfxterm
insmod part_gpt
insmod btrfs
else
fi
insmod gfxmenu
loadfont ($root)/@/boot/grub/themes/kali/unifont-regular-16.pf2
insmod png
set theme=($root)/@/boot/grub/themes/kali/theme.txt
export theme
if [ "${recordfail}" = 1 ] ; then
set timeout=30
else
if [ x$feature_timeout_style = xy ] ; then
set timeout_style=menu
set timeout=5
# Fallback normal timeout code in case the timeout_style feature is
# unavailable.
else
set timeout=5
fi
fi
### END /etc/grub.d/00_header ###
### BEGIN /etc/grub.d/05_debian_theme ###
insmod part_gpt
insmod btrfs
else
fi
insmod png
if background_image /@/usr/share/grub/themes/kali/grub-16x9.png; then
set color_normal=white/black
set color_highlight=black/white
else
set menu_color_normal=cyan/blue
set menu_color_highlight=white/blue
fi
### END /etc/grub.d/05_debian_theme ###
### BEGIN /etc/grub.d/06_dark_theme ###
set menu_color_normal=white/black
set menu_color_highlight=yellow/black
set color_highlight=yellow/black
background_image
### END /etc/grub.d/06_dark_theme ###
### BEGIN /etc/grub.d/10_linux ###
function gfxmode {
set gfxpayload="${1}"
set linux_gfx_mode=
export linux_gfx_mode
menuentry 'Kali GNU/Linux' --class kali --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-2837b27c-aa88-4c89-bf8a-44664ea0089d' {
load_video
insmod gzio
if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi
insmod part_gpt
insmod btrfs
else
fi
echo 'Loading Linux 5.16.0-kali7-amd64 ...'
linux /@/boot/vmlinuz-5.16.0-kali7-amd64 root=UUID=2837b27c-aa88-4c89-bf8a-44664ea0089d ro rootflags=subvol=@ quiet splash
echo 'Loading initial ramdisk ...'
initrd /@/boot/initrd.img-5.16.0-kali7-amd64
submenu 'Advanced options for Kali GNU/Linux' $menuentry_id_option 'gnulinux-advanced-2837b27c-aa88-4c89-bf8a-44664ea0089d' {
menuentry 'Kali GNU/Linux, with Linux 5.16.0-kali7-amd64' --class kali --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.16.0-kali7-amd64-advanced-2837b27c-aa88-4c89-bf8a-44664ea0089d' {
load_video
insmod gzio
insmod part_gpt
insmod btrfs
else
fi
menuentry 'Kali GNU/Linux, with Linux 5.16.0-kali7-amd64 (recovery mode)' --class kali --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.16.0-kali7-amd64-recovery-2837b27c-aa88-4c89-bf8a-44664ea0089d' {
load_video
insmod gzio
insmod part_gpt
insmod btrfs
else
fi
linux /@/boot/vmlinuz-5.16.0-kali7-amd64 root=UUID=2837b27c-aa88-4c89-bf8a-44664ea0089d ro single rootflags=subvol=@
menuentry 'Kali GNU/Linux, with Linux 5.15.0-kali3-amd64' --class kali --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.15.0-kali3-amd64-advanced-2837b27c-aa88-4c89-bf8a-44664ea0089d' {
load_video
insmod gzio
insmod part_gpt
insmod btrfs
else
fi
echo 'Loading Linux 5.15.0-kali3-amd64 ...'
linux /@/boot/vmlinuz-5.15.0-kali3-amd64 root=UUID=2837b27c-aa88-4c89-bf8a-44664ea0089d ro rootflags=subvol=@ quiet splash
initrd /@/boot/initrd.img-5.15.0-kali3-amd64
menuentry 'Kali GNU/Linux, with Linux 5.15.0-kali3-amd64 (recovery mode)' --class kali --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.15.0-kali3-amd64-recovery-2837b27c-aa88-4c89-bf8a-44664ea0089d' {
load_video
insmod gzio
insmod part_gpt
insmod btrfs
else
fi
linux /@/boot/vmlinuz-5.15.0-kali3-amd64 root=UUID=2837b27c-aa88-4c89-bf8a-44664ea0089d ro single rootflags=subvol=@
### END /etc/grub.d/10_linux ###
### BEGIN /etc/grub.d/20_linux_xen ###
### END /etc/grub.d/20_linux_xen ###
### BEGIN /etc/grub.d/30_os-prober ###
### END /etc/grub.d/30_os-prober ###
### BEGIN /etc/grub.d/30_uefi-firmware ###
menuentry 'System setup' $menuentry_id_option 'uefi-firmware' {
fwsetup
### END /etc/grub.d/30_uefi-firmware ###
### BEGIN /etc/grub.d/40_custom ###
### END /etc/grub.d/40_custom ###
### BEGIN /etc/grub.d/41_custom ###
if [ -f ${config_directory}/custom.cfg ]; then
source ${config_directory}/custom.cfg
elif [ -z "${config_directory}" -a -f $prefix/custom.cfg ]; then
source $prefix/custom.cfg;
fi
### END /etc/grub.d/41_custom ###
