Problems with audio crackling/interference (even muted) Realtek ALC1220
My new PC has some sort of audio interference and crackling (even muted) that intensifies when I open some (but not all) games or programs (Mostly Steam, tested in both steam and steam-native packages and some wine and native games) ; there it even intensifies. (This doesn’t happen when I manually increase Case/CPU/GPU fans.)
This interference doesn’t exist in Bluetooth, but in analog audio outputs (case front panel, motherboard, HDMI, DisplayPort) with different speakers and headphones. I have tested it, and the same issue occurs in an Ubuntu live ISO.
My motherboard’s (The bios is updated) integrated sound card is a realtek alc1220, I have seen even a 2017 article mentioning a similar issue https://www.muylinux.com/2017/11/30/realtek-alc1220-un-chip-de-sonido-problematico-con-linux/.
My specs are:
OS: EndeavourOS x86_64
Host: B550M DS3H AC R2 (Default string-CF)
Kernel: Linux 6.15.2-arch1-1
Shell: bash 5.2.37
Display (LM24-E231): 1920x1080 @ 165 Hz in 24" [External]
DE: GNOME 48.2
WM: Mutter (Wayland)
Terminal: GNOME Console 48.0.1
CPU: AMD Ryzen 5 5600 (12) @ 4.47 GHz
GPU: AMD Radeon RX 5700.
I am using Pipewire.
Welcome back @Facni :smiley::enos_flag:
The front case jack, and motherboard jack, I would expect are using the ALC1220.
HDMI out from your RX 5700 however, would be bypassing the ALC1220. I assume you’re connecting your headphones/speakers to the audio jack on the display in that test?
If the issue is consistent when using HDMI, I’d have to wonder if it is the headphones / speakers, or some EMF in the room causing an interference of some sort?
Is “Bluetooth” a separate device entirely?
Thank you for answering.
Yes, that’s what I did but I was using DisplayPort not HDMI, Idk if that changes something.
They don’t have this problem when they are plugged to other devices, but I just was able to test it with a cabled earphone (pretty bad quality), an old monitor speaker, and two normals speakers wich for some reason have their volume so low that I don’t know if they just don’t have the inerference.
Yes, I tested two Speakers and a Bluetooth earphone.
It could be, but I don’t have this problem when plugging other computer and devices in the room, also, the interference reacts some how to things done in computer for example moving the mouse or a webpage (in both monitors). Maybe my old second monitor is generating the EMF.
I have to clarify that my old computer was in the same place connected to the same monitors setup without any problem
I was able to test the pc connected to a TV in a different room. At the end the problem was the old monitor
