Problems with Asus E410MA laptop with linux on the battery
Good morning, first of all thank you very much to anyone who replies to this post, my English isn’t the best but here we go. I started my Linux journey using the MINT distro. I started with a bad battery, which I replaced with a new one in December last year. I’ve had the following problems with MINT:
  • When I do something heavy on my PC, it slows down, such as transferring files from my phone to my PC.
  • POSITIVE POINT - The battery lasted
Ok, given the first problem I switched to DEBIAN 12, to test a new system and see if the problem was solved. To my surprise, no. With DEBIAN 12 I had the following problems:
  • When I do something on my PC, it goes down, for example transferring files from my phone to my PC.
  • When the battery reached 80% to 90%, the pc would die, it would turn off, IT WAS NOT CONNECTED TO THE CURRENT, ONLY THE PORTABLE WAS USING THE BATTERY. and to turn it back on I had to plug it in with the charger.
So I switched to ENDEAVOUR OS, but the problem was still the same, so I encountered the following problems:
  • When I do something heavy on the PC, it goes low, such as downloading files from the phone to the PC.
  • The battery died when it reached 80% to 90%, the pc turned off, IT WAS NOT CONNECTED TO THE CURRENT, ONLY THE PORTABLE USING THE BATTERY. and to turn it back on I had to plug it in with the charger.
The battery is new, bought on Amazon in December. But the pc dies between 80% and 90%, what do I do?
WHAT I DID
In ENDEAVOUR OS I tried to calibrate the battery in 3 ways
1 - through the pc’s BIOS, to get it to 0% but it would also die at 80% to 90%
2 - through the command # powertop --calibrate
3 - through the command # power-calibrate -r
Nothing solved the problem, I’ve been researching this but I can’t find anything that solves my problem. If you need any information, just ask
Thanks
diniss
First step is to RMA the battery.
Probably a bad battery. Return or exchange it.
How do I do this?
Well, I also think that could be it, thanks.
Reach out to the seller of the battery on Amazon or the manufacturer of the battery.
