Wait for it…Wait for it…Wait for it…
Pudge
Pudge
We were old pals in an earlier life!
Gobble, gobble… yeah… they are really something aren’t they? Here is a selfie I made back in those days. That’s Corn, right behind me staring into the camera. Who would have imagined that one day they would reach that high. Wait a minute…but the one at the right, is that you? Gobble Gobble [turkeys]
Maybe unrealistic, but I’d take the machine to a friend’s house using a different ISP and see what happens.
thats what that was for:
can you try to use your mobile phone’s mobile data connection (via tethering or WiFi hotspot) and check if it works that way?
Using my phone via USB tethering works
Since when do owls gobble gobble?
Also gobble gobble <3
Owls tend tend to gobble gobble after they catch catch - especially mice mice!
The polyglot owls do!
Lately, I have been specially interested in sociolects of the different populations of turkeys in Minnesota.
Gobllee Gobllee!
PS - sorry for my accent I’m working on it.
Gobble gobble gobble
Hi, I seem to be having this problem right now, and tried all of the things here, even removed the lts kernel as I use zen, but still get the same issue when trying to update.
kernel-lts.db failed to download
error: failed retrieving file 'kernel-lts.db' from repo.m2x.dev : Could not resolve host: repo.m2x.dev
warning: too many errors from repo.m2x.dev, skipping for the remainder of this transaction
error: failed to synchronize all databases (unexpected error)
You need to remove the repo from /etc/pacman.conf
it should be neat the bottom.
/etc/pacman.conf
Interestingly, your reply to @atl was tagged as a reply to me. Is that because I’m the OP? The repo in question is gone, so this thread should be closed.
It wasn’t tagged to you that I can see. You probably have the topic set to “Watching”
This error has bitten me as well. Could you elaborate on what exactly to remove from pacman.conf, @dalto? Removing only the reference to the repo gave me an error when trying to update.
Here’s what’s at the bottom of my pacman.conf:
[kernel-lts]
SigLevel = Required
Server = https://repo.m2x.dev/current/$repo/$arch
You should be removing all those three lines.
and if you are using any kernel or nvidia package from late jonathon you will need to replace that with AUR build or by removal.
Thank you very much, that did it!
What a terrible loss. RIP
