Hey, its my first time on this forum, so don’t be too harsh. I’m not very good with Linux, although i have been using it for a month or so. I have tried to install Endeavour using Balena Etcher but it just booted me into the normal Arch installation (in command line) and also had the USB named as Arch. Is this normal? And if it isn’t, how do i fix it?
If you need some information about my computer to answer my question, feel free to ask below.
That’s not supposed to happen. EndeavourOS normally boots into a graphical installer (Calamares), not the plain Arch command line. It sounds like Balena Etcher didn’t flash the ISO properly. That tool sometimes has issues with Linux ISOs.
I personally prefer Ventoy. You just have to drag and drop the ISO into it.
Hi yuki & welcome here!
If you run 2 or more different Distros in one machine, maybe you should try rEFInd.
It boots the kernels directly.
But, if one of your sys needs a special feature of grub or something else, you shoud check it once more…
P.S. These ‘broken sticks’ I know, if I pull them out when some data are still pending. Give a ‘$ sync’ on commandline - I am surprised, how long I have to wait sometimes…
