Hopefully this will help others.
As per:
I wanted to increase the size of the swap file.
Every time I submitted this command in terminal:
sudo dd if=/dev/zero of=/swapfile bs=1G count=8
the terminal app crashed, and no swap file was created.
Looking at the journal with
journalctl --since <timestamp>
I found the reason:
oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,global_oom,task_memcg=/user.slice/user-1000.slice/user@1000.service/app.slice/app-org.kde.konsole@31d13f64a4394511a13cf05cb2f5f687.service,task=dd,pid=2282,uid=0
aug 16 08:42:04 EOS001 kernel: Out of memory: Killed process 2282 (dd) total-vm:1054496kB, anon-rss:1048680kB, file-rss:528kB, shmem-rss:0kB, UID:0 pgtables:2108kB oom_score_adj:200
In short: the laptop is very low spec and did not even have enough memory to run the process to create the swap file.
Solution was: close all apps leaving only terminal running, then submit the command
Then no crash occurred and the swapfile was created:
total used free shared buff/cache available
Mem: 3,7Gi 2,5Gi 188Mi 796Mi 2,1Gi 1,3Gi
Swap: 8,0Gi 1,0Gi 7,0Gi
And i swapped happily ever after.
Hope this may help others.
