Hi,
If more information is needed or any commands that help to identify the problem, please let me know.
In the compilation of scid-vs-pc:
won@won-hpprobook455156inchg10notebookpc ~$ cd Descargas
won@won-hpprobook455156inchg10notebookpc Descargas$ ls
CHESS-DOWNLOADS E-SWORD pexels-photo-2055389.jpeg STARTDICT
won@won-hpprobook455156inchg10notebookpc Descargas$ cd CHESS-DOWNLOADS
won@won-hpprobook455156inchg10notebookpc CHESS-DOWNLOADS$ ls
Caissabase_2022_12_24 Fischer.pgn Obsidian-13.0 scid_vs_pc-4.25 ShashChess-36 stockfish
won@won-hpprobook455156inchg10notebookpc CHESS-DOWNLOADS$ cd scid_vs_pc-4.25
won@won-hpprobook455156inchg10notebookpc scid_vs_pc-4.25$ ./configure
Scid vs. PC configure - Makefile configuration program
Renaming "Makefile" to "Makefile.bak"
Tcl/Tk version: 8.6
Your operating system is: Linux 6.6.57-1-lts
NAME="EndeavourOS"
PRETTY_NAME="EndeavourOS"
ID="endeavouros"
ID_LIKE="arch"
BUILD_ID=rolling
ANSI_COLOR="38;2;23;147;209"
HOME_URL="https://endeavouros.com"
DOCUMENTATION_URL="https://discovery.endeavouros.com"
SUPPORT_URL="https://forum.endeavouros.com"
BUG_REPORT_URL="https://forum.endeavouros.com/c/general-system/endeavouros-installation"
PRIVACY_POLICY_URL="https://endeavouros.com/privacy-policy-2"
LOGO="endeavouros"
DISTRIB_ID="EndeavourOS"
DISTRIB_RELEASE="rolling"
DISTRIB_DESCRIPTION="EndeavourOS Linux"
DISTRIB_CODENAME="rolling"
Location of "tcl.h": /usr/include
Location of "tk.h": /usr/include
Location of Tcl 8.6 library: /usr/lib
Location of Tk 8.6 library: /usr/lib
Location of X11 library: /usr/lib
Checking if your system already has zlib installed: yes.
The Makefile configured for your system was written.
Now type "make" to compile Scid.
*So far so good… but …
won@won-hpprobook455156inchg10notebookpc scid_vs_pc-4.25$ LANG=C make
make -C engines/phalanx/ -f Makefile CC="gcc" LINK="g++" CFLAGS="-O2 -fno-exceptions -Wall " LDFLAGS=""
make[1]: Entering directory '/home/won/Descargas/CHESS-DOWNLOADS/scid_vs_pc-4.25/engines/phalanx'
g++ -O2 -fno-exceptions -Wall .o/phalanx.o .o/bcreate.o .o/search.o .o/io.o .o/data.o .o/evaluate.o .o/genmoves.o .o/moving.o .o/hash.o .o/static.o .o/levels.o .o/book.o .o/killers.o .o/endgame.o .o/learn.o .o/easy.o -o phalanx
/usr/bin/ld: .o/phalanx.o: relocation R_X86_64_32 against `.rodata.str1.8' can not be used when making a PIE object; recompile with -fPIE
/usr/bin/ld: failed to set dynamic section sizes: bad value
collect2: error: ld returned 1 exit status
make[1]: *** [Makefile:23: phalanx] Error 1
make[1]: Leaving directory '/home/won/Descargas/CHESS-DOWNLOADS/scid_vs_pc-4.25/engines/phalanx'
make: *** [Makefile:270: phalanx] Error 2
As a general rule, when these errors appear it is because something is missing for the compilation, but in this case, although I cannot find tcl-dev or tk-dev here in endeavouros, I tried to compile the chess engines to see if that was the reason … and they were all compiled without any problem.
I don’t know if anyone could help me with this last step, I would be very grateful since I am far from being an expert on the subject,
Regards
EDIT:
I found this at the Forum:
but do not work for me … can’t find tar-xzf
won@won-hpprobook455156inchg10notebookpc CHESS-DOWNLOADS$ tar-xzf scid_vs_pc-4.25.tgz
bash: tar-xzf: orden no encontrada
