I figured I’d ask here first in case anyone else has tried to build 32bit mesa on Arch or EndeavourOS.
I logged a bug with mesa, and they want me to bisect to find the commit that is causing the issue. I can build the 64bit version not problem, but in this case I need to build 32bit. I read through their documentation and can’t seem to get it to work.
The command I’m running to configure is:
meson --cross-file=x86-linux-gnu --prefix=“${PWD}/build_22.2.1” build_22.2.1/
The x86-linux-gnu file is the one from here that the documentation says to use.
The first time I ran it, it complained that pkconfig could not find wayland-protocols. Sure enough, the file wasn’t under /usr/lib32/pkconfig but under /usr/share/pkgconfig/, so I copied the file over and that seemed to work. Now it’s complaining that it can’t find the x11 dependency. The file /usr/lib32/pkgconfig/x11.pc does exist and the paths in the file are valid. The entire log file can be found here: https://pastebin.com/MUn1JvKK
Any help would be appreciated.
