So I already installed Docker-osx succesfully in Ubuntu and Arch, but macOS base system or preinstalled macOS gets stuck in the booting process in EndeavourOS. (github-repository: https://github.com/sickcodes/Docker-OSX).
I suppose it is a config problem with Endeavour, since the required packages come from the same repo like arch.
I don’t know if it’s arbitrary but the macOS boot stops at “matching deferred by IOUSBHostHIDDevice” and the display becomes all garbled up a while after getting stuck.
Please tell me how i can get further logs that can be of use.
I would like to run Endeavour as my main OS and use this, so this is quite a Problem. Thanks for checking out the issue!
